Using a Flume Client
You can use Flume to import collected log information to Kafka.
  • A streaming cluster with Kerberos authentication enabled has been created.
  • The Flume client has been installed on the node where logs are generated, for example, in the /opt/Flumeclient directory. For details about how to install the Flume client, see . The client directory in the following operations is only an example. Change it to the actual installation directory.
  • The streaming cluster can properly communicate with the node where logs are generated.
Using the Flume Client (Versions Earlier Than MRS 3.x)
You do not need to perform 2 to 5 for a normal cluster.
  1. Install the client.
    For details, see .
  2. Copy the configuration file of the authentication server from the Master1 node to the Flume client installation directory/fusioninsight-flume-Flume component version number/conf directory on the node where the Flume client resides.
    The full file path is ${BIGDATA_HOME}/MRS_Current/1_X_KerberosClient/etc/kdc.conf.
    In the preceding path, X indicates a random number. Change it based on the site requirements. The file must be saved by the user who installs the Flume client, for example, user root.
  3. Copy the user authentication file from this node to the Flume client installation directory/fusioninsight-flume-Flume component version number/conf directory on the Flume client node.
    The full file path is ${BIGDATA_HOME}/MRS_XXX/install/FusionInsight-Flume-Flume component version number/flume/conf/flume.keytab.
    In the preceding paths, XXX indicates the product version number. Change it based on the site requirements. The file must be saved by the user who installs the Flume client, for example, user root.
  4. Copy the jaas.conf file from this node to the conf directory on the Flume client node.
    The full file path is ${BIGDATA_HOME}/MRS_Current/1_X_Flume/etc/jaas.conf.
  5. Log in to the Flume client node and go to the client installation directory. Run the following command to modify the file:
    vi conf/jaas.conf
    Change the full path of the user authentication file defined by keyTab to the Flume client installation directory/fusioninsight-flume-Flume component version number/conf saved in 3, and save the modification and exit.
  6. Run the following command to modify the flume-env.sh configuration file of the Flume client:
    vi Flume client installation directory/fusioninsight-flume-Flume component version number/conf/flume-env.sh
    Add the following information after -XX:+UseCMSCompactAtFullCollection:
    -Djava.security.krb5.conf=Flume client installation directory/fusioninsight-flume-1.9.0/conf/kdc.conf -Djava.security.auth.login.config=Flume client installation directory/fusioninsight-flume-1.9.0/conf/jaas.conf -Dzookeeper.request.timeout=120000
    For example, "-XX:+UseCMSCompactAtFullCollection -Djava.security.krb5.conf=Flume client installation directory/fusioninsight-flume-Flume component version number/conf/kdc.conf -Djava.security.auth.login.config=Flume client installation directory/fusioninsight-flume-Flume component version number/conf/jaas.conf -Dzookeeper.request.timeout=120000"
    Change Flume client installation directory to the actual installation directory. Then save and exit.
  7. Assume that the Flume client installation path is /opt/FlumeClient. Run the following command to restart the Flume client:
    cd /opt/FlumeClient/fusioninsight-flume-Flume component version number/bin
    ./flume-manage.sh restart
  8. Run the following command to modify the properties.properties configuration file of the Flume client:
    vi Flume client installation directory/fusioninsight-flume-Flume component version number/conf/properties.properties
    Add the following information to the file:
    client.sources = static_log_source
    client.channels = static_log_channel
    client.sinks = kafka_sink
    #LOG_TO_HDFS_ONLINE_1
    client.sources.static_log_source.type = spooldir
    client.sources.static_log_source.spoolDir = PATH
    client.sources.static_log_source.fileSuffix = .COMPLETED
    client.sources.static_log_source.ignorePattern = ^$
    client.sources.static_log_source.trackerDir = PATH
    client.sources.static_log_source.maxBlobLength = 16384
    client.sources.static_log_source.batchSize = 51200
    client.sources.static_log_source.inputCharset = UTF-8
    client.sources.static_log_source.deserializer = LINE
    client.sources.static_log_source.selector.type = replicating
    client.sources.static_log_source.fileHeaderKey = file
    client.sources.static_log_source.fileHeader = false
    client.sources.static_log_source.basenameHeader = true
    client.sources.static_log_source.basenameHeaderKey = basename
    client.sources.static_log_source.deletePolicy = never
    client.channels.static_log_channel.type = file
    client.channels.static_log_channel.dataDirs = PATH
    client.channels.static_log_channel.checkpointDir = PATH
    client.channels.static_log_channel.maxFileSize = 2146435071
    client.channels.static_log_channel.capacity = 1000000
    client.channels.static_log_channel.transactionCapacity = 612000
    client.channels.static_log_channel.minimumRequiredSpace = 524288000
    client.sinks.kafka_sink.type = org.apache.flume.sink.kafka.KafkaSink
    client.sinks.kafka_sink.kafka.topic = flume_test
    client.sinks.kafka_sink.kafka.bootstrap.servers = XXX.XXX.XXX.XXX:210079092,XXX.XXX.XXX.XXX:21007,XXX.XXX.XXX.XXX:21007
    client.sinks.kafka_sink.flumeBatchSize = 1000
    client.sinks.kafka_sink.kafka.producer.type = sync
    client.sinks.kafka_sink.kafka.security.protocol  = SASL_PLAINTEXT
    client.sinks.kafka_sink.kafka.kerberos.domain.name = hadoop.XXX.com
    client.sinks.kafka_sink.requiredAcks = 0
    client.sources.static_log_source.channels = static_log_channel
    client.sinks.kafka_sink.channel = static_log_channel
    Modify the following parameters as required. Then save and exit the file.
    • spoolDir
    • trackerDir
    • dataDirs
    • checkpointDir
    • topic
      If the topic does not exist in Kafka, the topic is automatically created by default.
    • kafka.bootstrap.servers
      By default, the port for a security cluster is port 21007 and that for a normal cluster is port 9092.
    • kafka.security.protocol
      Set this parameter to SASL_PLAINTEXT for a security cluster and PLAINTEXT for a normal cluster.
    • kafka.kerberos.domain.name
      You do not need to set this parameter for a normal cluster. For a security cluster, the value of this parameter is the value of kerberos.domain.name in the Kafka cluster.
      You can check ${BIGDATA_HOME}/MRS_Current/1_X_Broker/etc/server.properties on the node where the broker instance resides.
      In the preceding paths, X indicates a random number. Change it based on the site requirements. The file must be saved by the user who installs the Flume client, for example, user root.
  9. The Flume client automatically loads the information in the properties.properties file.
    After new log files are generated in the directory specified by spoolDir, the logs will be sent to Kafka producers and can be consumed by Kafka consumers.
Using the Flume Client (MRS 3.x or Later)
    For details, see .
    The full file path is ${BIGDATA_HOME}/FusionInsight_Current/1_X_KerberosClient/etc/kdc.conf. In the preceding path, X indicates a random number. Change it based on the site requirements. The file must be saved by the user who installs the Flume client, for example, user root.
    The full file path is ${BIGDATA_HOME}/FusionInsight_Porter_XXX/install/FusionInsight-Flume-Flume component version number/flume/conf/flume.keytab.
    The full file path is ${BIGDATA_HOME}/FusionInsight_Current/1_X_Flume/etc/jaas.conf.
    vi conf/jaas.conf
    • spoolDir
    • trackerDir
    • dataDirs
    • checkpointDir
    • topic
      For details, check ${BIGDATA_HOME}/FusionInsight_Current/1_X_Broker/etc/server.properties on the node where the broker instance resides.
