Using a Flink Client
Updated on 2022-12-08 GMT+08:00
This section describes how to use Flink to run wordcount jobs.
  • Flink has been installed in an MRS cluster.
  • The cluster runs properly and the client has been correctly installed, for example, in the /opt/hadoopclient directory. The client directory in the following operations is only an example. Change it to the actual installation directory.
Using the Flink Client (Versions Earlier Than MRS 3.x)
  1. Log in to the node where the client is installed as the client installation user.
  2. Run the following command to go to the client installation directory:
    cd /opt/hadoopclient
  3. Run the following command to initialize environment variables:
    source /opt/hadoopclient/bigdata_env
  4. If Kerberos authentication is enabled for the cluster, perform the following steps. If not, skip this whole step.
    1. Prepare a user for submitting Flink jobs..
    2. Log in to Manager as the newly created user.
      Log in to Manager of the cluster. For details, see Accessing Manager. Choose System Settings > User Management. In the Operation column of the row that contains the added user, choose More > Download Authentication Credential.
    3. Decompress the downloaded authentication credential package and copy the user.keytab file to the client node, for example, to the /opt/hadoopclient/Flink/flink/conf directory on the client node. If the client is installed on a node outside the cluster, copy the krb5.conf file to the /etc/ directory on this node.
    4. Configure security authentication by adding the keytab path and username in the /opt/hadoopclient/Flink/flink/conf/flink-conf.yaml configuration file.
      security.kerberos.login.keytab: <user.keytab file path>
      security.kerberos.login.principal: <Username>
      Example:
      security.kerberos.login.keytab: /opt/hadoopclient/Flink/flink/conf/user.keytab
      security.kerberos.login.principal: test
    5. Generate the generate_keystore.sh script and save it to the bin directory of the Flink client. In the bin directory of the Flink client, run the following command to harden the security. Set password to a new password for submitting jobs.
      sh generate_keystore.sh <password>
      The script automatically replaces the SSL value in the /opt/hadoopclient/Flink/flink/conf/flink-conf.yaml file.
    6. Configure paths for the client to access the flink.keystore and flink.truststore files.
      • Absolute path: After the script is executed, the file path of flink.keystore and flink.truststore is automatically set to the absolute path /opt/hadoopclient/Flink/flink/conf/ in the flink-conf.yaml file. In this case, you need to move the flink.keystore and flink.truststore files from the conf directory to this absolute path on the Flink client and Yarn nodes.
      • Relative path: Perform the following steps to set the file path of flink.keystore and flink.truststore to the relative path and ensure that the directory where the Flink client command is executed can directly access the relative paths.
        1. Create a directory, for example, ssl, in /opt/hadoopclient/Flink/flink/conf/.
        2. Move the flink.keystore and flink.truststore files to the /opt/hadoopclient/Flink/flink/conf/ssl/ directory.
        3. Change the values of the following parameters to relative paths in the flink-conf.yaml file:
          security.ssl.internal.keystore: ssl/flink.keystore
          security.ssl.internal.truststore: ssl/flink.truststore
    7. Add the IP addresses of the nodes where the client is located to the following configuration items in the configuration file (for example, /opt/hadoopclient/Flink/fink/conf/flink-conf.yaml). Use commas (,) to separate IP addresses.
      web.access-control-allow-origin: xx.xx.xxx.xxx
      jobmanager.web.allow-access-address: xx.xx.xxx.xxx
  5. Run a wordcount job.
    NOTICE:
    To submit or run jobs on Flink, the user must have the following permissions:
    • If Ranger authentication is enabled, the current user must belong to the hadoop group or the user has been granted the /flink read and write permissions in Ranger.
    • If Ranger authentication is disabled, the current user must belong to the hadoop group.
    • Normal cluster (Kerberos authentication disabled)
      • Run the following commands to start a session and submit a job in the session:
        yarn-session.sh -nm "session-name"
        flink run /opt/hadoopclient/Flink/flink/examples/streaming/WordCount.jar
      • Run the following command to submit a single job on Yarn:
        flink run -m yarn-cluster /opt/hadoopclient/Flink/flink/examples/streaming/WordCount.jar
    • Security cluster (Kerberos authentication enabled)
      • If the flink.keystore and flink.truststore file are stored in the absolute path:
      • If the flink.keystore and flink.truststore file are stored in the relative path:
        • In the same directory of SSL, run the following commands to start a session and submit jobs in the session. The SSL directory is a relative path. For example, if the SSL directory is opt/hadoopclient/Flink/flink/conf/, then run the following commands in this directory:
          yarn-session.sh -t ssl/ -nm "session-name"
          flink run -m yarn-cluster -yt ssl/ /opt/hadoopclient/Flink/flink/examples/streaming/WordCount.jar
  6. After the job has been successfully submitted, the following information is displayed on the client:
    Figure 1 Job submitted successfully on Yarn
    Figure 2 Session started successfully
    Figure 3 Job submitted successfully in the session
  7. Go to the native page of the Yarn service, find the application of the job, and click the application name to go to the job details page. For details, see .
    • If the job is not completed, click Tracking URL to go to the native Flink page and view the job running information.
    • If the job submitted in a session has been completed, you can click Tracking URL to log in to the native Flink service page to view job information.
      Figure 4 Application
Using the Flink Client (MRS 3.x or Later)
      Log in to Manager. For details, see Accessing Manager. Choose System > Permission > Manage User. On the displayed page, locate the row that contains the added user, click More in the Operation column, and select Download authentication credential.
    4. In security mode, append the service IP address of the node where the client is installed and floating IP address of Manager to the jobmanager.web.allow-access-address configuration item in the /opt/hadoopclient/Flink/flink/conf/flink-conf.yaml file. Use commas (,) to separate IP addresses.
      • To obtain the service IP address of the node where the client is installed, perform the following operations:
        • Node inside the cluster:
          In the navigation tree of the MRS management console, choose Clusters > Active Clusters, select a cluster, and click its name to switch to the cluster details page.
          On the Nodes tab page, view the IP address of the node where the client is installed.
        • Node outside the cluster: IP address of the ECS where the client is installed.
      • To obtain the floating IP address of Manager, perform the following operations:
        • In the navigation tree of the MRS management console, choose Clusters > Active Clusters, select a cluster, and click its name to switch to the cluster details page.
          On the Nodes tab page, view the Name. The node that contains master1 in its name is the Master1 node. The node that contains master2 in its name is the Master2 node.
        • Log in to the Master2 node remotely, and run the ifconfig command. In the command output, eth0:wsom indicates the floating IP address of MRS Manager. Record the value of inet. If the floating IP address of MRS Manager cannot be queried on the Master2 node, switch to the Master1 node to query and record the floating IP address. If there is only one Master node, query and record the cluster manager IP address of the Master node.
    5. Configure security authentication by adding the keytab path and username in the /opt/hadoopclient/Flink/flink/conf/flink-conf.yaml configuration file.
      Example:
    6. Generate the generate_keystore.sh script and save it to the bin directory of the Flink client. For details, see . In the bin directory of the Flink client, run the following command to harden the security. For details see . Set password to a new password for submitting jobs.
      After operations in are performed, the flink.keystore and flink.truststore files are generated in the conf directory of the Flink client and the following configuration items in the flink-conf.yaml client configuration file are set by default:
      • Set security.ssl.keystore to the absolute path of the flink.keystore file.
      • Set security.ssl.truststore to the absolute path of the flink.truststore file.
      • Set security.cookie to a random password automatically generated by the generate_keystore.sh script.
      • By default, security.ssl.encrypt.enabled is set to false in the flink-conf.yaml file by default. The generate_keystore.sh script sets security.ssl.key-password, security.ssl.keystore-password, and security.ssl.truststore-password to the password entered when the generate_keystore.sh script is called.
      • If ciphertext is required and security.ssl.encrypt.enabled is set to true in the flink-conf.yaml file, the generate_keystore.sh script does not set security.ssl.key-password, security.ssl.keystore-password, and security.ssl.truststore-password. To obtain the values, use the Manager plaintext encryption API by running the following command: curl -k -i -u Username:Password -X POST -HContent-type:application/json -d '{"plainText":"Password"}' 'https://x.x.x.x:28443/web/api/v2/tools/encrypt'
        In the preceding command, Username:Password indicates the user name and password for logging in to the system. The password of "plainText" indicates the one used to call the generate_keystore.sh script. x.x.x.x indicates the floating IP address of Manager.
    7. Configure paths for the client to access the flink.keystore and flink.truststore files.
          security.ssl.keystore: ssl/flink.keystore
          security.ssl.truststore: ssl/flink.truststore
    8. Add the IP addresses of the nodes where the client is located to the following configuration items in the configuration file (for example, /opt/hadoopclient/Flink/fink/conf/flink-conf.yaml). Use commas (,) to separate IP addresses.
    NOTICE:
    Figure 5 Job submitted successfully on Yarn
    Figure 6 Session started successfully
    Figure 7 Job submitted successfully in the session
      Figure 8 Application
