On this page
Manager Log List
Updated on 2022-12-08 GMT+08:00
Log Description
Log path: The default storage path of Manager log files is /var/log/Bigdata/Manager component.
  • ControllerService: /var/log/Bigdata/controller/ (operation & maintenance system (OMS) installation and run logs)
  • Httpd: /var/log/Bigdata/httpd (httpd installation and run logs)
  • logman: /var/log/Bigdata/logman (log packaging tool logs)
  • NodeAgent: /var/log/Bigdata/nodeagent (NodeAgent installation and run logs)
  • okerberos: /var/log/Bigdata/okerberos (okerberos installation and run logs)
  • oldapserver: /var/log/Bigdata/oldapserver (oldapserver installation and run logs)
  • MetricAgent: /var/log/Bigdata/metric_agent (MetricAgent run log)
  • omm: /var/log/Bigdata/omm (omm installation and run logs)
  • timestamp: /var/log/Bigdata/timestamp (NodeAgent startup time logs)
  • tomcat: /var/log/Bigdata/tomcat (Web process logs)
  • Patch: /var/log/Bigdata/patch (patch installation log)
  • Sudo: /var/log/Bigdata/sudo (sudo script execution log)
  • OS: /var/log/message file (OS system log)
  • OS Performance: /var/log/osperf (OS performance statistics log)
  • OS Statistics: /var/log/osinfo/statistics (OS parameter configuration log)
Log archiving rule:
The automatic compression and archiving function is enabled for Manager logs. By default, when the size of a log file exceeds 10 MB, the log file is automatically compressed. The naming rule of a compressed log file is as follows: <Original log name>-<yyyy-mm-dd_hh-mm-ss>.[ID].log.zip A maximum of 20 latest compressed files are reserved.
Table 1 Manager logs
Type
Log File Name
Controller run log
controller.log
Log that records component installation, upgrade, patch installation, configuration, monitoring, alarms, and routine O&M operations
controller_client.log
Run log of the Representational State Transfer (REST) API
acs.log
ACS run log file
acs_spnego.log
spnego user log in ACS
aos.log
AOS run log
plugin.log
AOS plug-in log
backupplugin.log
Log that records the backup and restoration operations
controller_config.log
Configuration run log
controller_nodesetup.log
Controller loading task log
controller_root.log
System log of the Controller process
controller_trace.log
Log that records the remote procedure call (RPC) communication between Controller and NodeAgent
controller_monitor.log
Monitoring log
controller_fsm.log
State machine log
controller_alarm.log
Controller alarm log
controller_backup.log
Controller backup and recovery log
install.log, distributeAdapterFiles.log, install_os_optimization.log
OMS installation log
oms_ctl.log
OMS startup and stop log
installntp.log
NTP installation log
modify_manager_param.log
Manager parameter modification log
backup.log
OMS backup script run log
supressionAlarm.log
Alarm script run log
om.log
OM certificate generation log
backupplugin_ctl.log
Startup log of the backup and restoration plug-in process
getLogs.log
Run log of the collection log script
backupAuditLogs.log
Run log of the audit log backup script
certStatus.log
Log that records regular certificate checks
distribute.log
Certificate distribution log
ficertgenetrate.log
Certificate replacement logs, including logs of level-2 certificates, CAS certificates, and httpd certificates
genPwFile.log
Log that records the generation of certificate password files
modifyproxyconf.log
Log that records the modification of the HTTPD proxy configuration
importTar.log
Log that records the process of importing certificates into the trust library
Httpd
install.log
Httpd installation log
access_log, error_log
Httpd run log
logman
logman.log
Log packaging tool log
NodeAgent
install.log, install_os_optimization.log
NodeAgent installation log
installntp.log
start_ntp.log
NTP startup log
ntpChecker.log
NTP check log
ntpMonitor.log
NTP monitoring log
heartbeat_trace.log
Log that records heartbeats between NodeAgent and Controller
alarm.log
Alarm log
monitor.log
Monitoring log
nodeagent_ctl.log, start-agent.log
NodeAgent startup log
agent.log
NodeAgent run log
cert.log
Certificate log
agentplugin.log
Agent plug-in running status monitoring log
omaplugin.log
OMA plug-in run log
diskhealth.log
Disk health check log
supressionAlarm.log
updateHostFile.log
Host list update log
collectLog.log
Run log of the node log collection script
host_metric_collect.log
Host index collection run log
checkfileconfig.log
Run log file of file permission check
entropycheck.log
Entropy check run log
timer.log
Log of periodic node scheduling
pluginmonitor.log
Component monitoring plug-in log
agent_alarm_py.log
Log that records alarms upon insufficient NodeAgent file permission
okerberos
addRealm.log, modifyKerberosRealm.log
Domain handover log
checkservice_detail.log
Okerberos health check log
genKeytab.log
keytab generation log
KerberosAdmin_genConfigDetail.log
Run log that records the generation of kadmin.conf when starting the kadmin process
KerberosServer_genConfigDetail.log
Run log that records the generation of krb5kdc.conf when starting the krb5kdc process
oms-kadmind.log
Run log of the kadmin process
oms_kerberos_install.log, postinstall_detail.log
Okerberos installation log
oms-krb5kdc.log
Run log of the krbkdc process
start_detail.log
Okerberos startup log
realmDataConfigProcess.log
Log rollback for domain handover failure
stop_detail.log
Okerberos stop log
oldapserver
ldapserver_backup.log
Oldapserver backup log
ldapserver_chk_service.log
Oldapserver health check log
ldapserver_install.log
Oldapserver installation log
ldapserver_start.log
Oldapserver startup log
ldapserver_status.log
Log that records the status of the Oldapserver process
ldapserver_stop.log
Oldapserver stop log
ldapserver_wrap.log
Oldapserver service management log
ldapserver_uninstall.log
Oldapserver uninstallation log
restart_service.log
Oldapserver restart log
ldapserver_unlockUser.log
Log that records information about unlocking LDAP users and managing accounts
omm
omsconfig.log
OMS configuration log
check_oms_heartbeat.log
OMS heartbeat log
monitor.log
OMS monitoring log
ha_monitor.log
HA_Monitor operation log
ha.log
HA operation log
fms.log
Alarm log
fms_ha.log
HA alarm monitoring log
fms_script.log
Alarm control log
config.log
Alarm configuration log
iam.log
IAM log
iam_script.log
IAM control log
iam_ha.log
IAM HA monitoring log
config.log
IAM configuration log
operatelog.log
IAM operation log
heartbeatcheck_ha.log
OMS heartbeat HA monitoring log
install_oms.log
pms_ha.log
HA monitoring log
pms_script.log
Monitoring control log
config.log
Monitoring configuration log
plugin.log
Monitoring plug-in run log
pms.log
Monitoring log
ha.log
HA run log
cep_ha.log
CEP HA monitoring log
cep_script.log
CEP control log
cep.log
CEP log
config.log
CEP configuration log
omm_gaussdba.log
GaussDB HA monitoring log
gaussdb-<SERIAL>.log
GaussDB run log
gs_ctl-<DATE>.log
GaussDB control log archive log
gs_ctl-current.log
GaussDB control log
gs_guc-current.log
GaussDB operation log
encrypt.log
Omm encryption log
omm_agent_ctl.log
OMA control log
oma_monitor.log
OMA monitoring log
install_oma.log
OMA installation log
config_oma.log
OMA configuration log
omm_agent.log
OMA run log
acs.log
ACS resource log
aos.log
AOS resource log
controller.log
Controller resource log
feed_watchdog.log
feed_watchdog resource log
floatip.log
Floating IP address resource log
ha_ntp.log
NTP resource log
httpd.log
Httpd resource log
okerberos.log
Okerberos resource log
oldap.log
OLdap resource log
tomcat.log
Tomcat resource log
send_alarm.log
Run log of the HA alarm sending script of the management node
timestamp
restart_stamp
NodeAgent start time log
tomcat
cas.log, localhost_access_cas_log.log
CAS run log
catalina.log, catalina.out, host-manager.log, localhost.log, manager.log
Tomcat run log
localhost_access_web_log.log
Log that records the access to REST APIs of FusionInsight Manager
web.log
Run log of the web process
northbound_ftp_sftp.log, snmp.log
Northbound log
watchdog
watchdog.log, feed_watchdog.log
watchdog run log
patch
oms_installPatch.log
OMS patch installation log
agent_installPatch.log
Agent patch installation log
agent_uninstallPatch.log
Agent patch uninstallation log
NODE_AGENT_restoreFile.log
Agent patch restoration log
NODE_AGENT_updateFile.log
Agent patch update log
OMA_restoreFile.log
OMA patch restoration file log
OMA_updateFile.log
OMA patch update file log
CONTROLLER_restoreFile.log
CONTROLLER patch restoration file log
CONTROLLER_updateFile.log
CONTROLLER patch update file log
OMS_restoreFile.log
OMS patch restoration file log
oms_uninstallPatch.log
OMS patch uninstallation log
OMS_updateFile.log
OMS patch update file log
createStackConf.log, decompress.log, decompress_OMS.log, distrExtractPatchOnOMS.log, slimReduction.log, switch_adapter.log
Patch installation log
sudo
sudo.log
Sudo script execution log
Log Levels
Table 2 describes the log levels provided by Manager. The priorities of log levels are FATAL, ERROR, WARN, INFO, and DEBUG in descending order. Logs whose levels are higher than or equal to the specified level are printed. The number of printed logs decreases as the specified log level increases.
Table 2 Log levels
Level
FATAL
Logs of this level record fatal error information about the current event processing that may result in a system crash.
ERROR
Logs of this level record error information about the current event processing, which indicates that system running is abnormal.
WARN
Abnormal information about the current event processing. These abnormalities will not result in system faults.
INFO
Normal running status information about the system and events.
DEBUG
Logs of this level record the system information and system debugging information.
Log Formats
The following table lists the Manager log formats.
Table 3 Log formats
Type
Component
Format
Example
Controller, Httpd, logman, NodeAgent, okerberos, oldapserver, omm, tomcat, upgrade
<yyyy-MM-dd HH:mm:ss,SSS>|<Log level>|<Name of the thread that generates the log>|<Message in the log>|<Location where the log event occurs>
2015-06-30 00:37:09,067 INFO [pool-1-thread-1] Completed Discovering Node. com.xxx.hadoop.om.controller.tasks.nodesetup.DiscoverNodeTask.execute(DiscoverNodeTask.java:299)
