About Logs
Log Description
MRS cluster logs are stored in the /var/log/Bigdata directory. The following table lists the log types.
Type |
Description |
Installation log |
Installation logs record information about FusionInsight Manager, cluster, and service installation to help users locate installation errors. |
Run logs |
Run logs record the running track information, debugging information, status changes, potential problems, and error information generated during the running of services. |
Audit logs |
Audit logs record information about users' activities and operation instructions, which can be used to locate fault causes in security events and determine who are responsible for these faults. |
The following table lists the MRS log directories.
File Directory |
Log Content |
/var/log/Bigdata/audit |
Component audit log. |
/var/log/Bigdata/controller |
Log collecting script log. Controller process log. Controller monitoring log. |
/var/log/Bigdata/dbservice |
DBService log. |
/var/log/Bigdata/flume |
Flume log. |
/var/log/Bigdata/hbase |
HBase log. |
/var/log/Bigdata/hdfs |
HDFS log. |
/var/log/Bigdata/hive |
Hive log. |
/var/log/Bigdata/httpd |
HTTPD log. |
/var/log/Bigdata/hue |
Hue log. |
/var/log/Bigdata/kerberos |
Kerberos log. |
/var/log/Bigdata/ldapclient |
LDAP client log. |
/var/log/Bigdata/ldapserver |
LDAP server log. |
/var/log/Bigdata/loader |
Loader log. |
/var/log/Bigdata/logman |
logman script log management log. |
/var/log/Bigdata/mapreduce |
MapReduce log. |
/var/log/Bigdata/nodeagent |
NodeAgent log. |
/var/log/Bigdata/okerberos |
OMS Kerberos log. |
/var/log/Bigdata/oldapserver |
OMS LDAP log. |
/var/log/Bigdata/omm |
oms: complex event processing log, alarm service log, HA log, authentication and authorization management log, and monitoring service run log of the omm server. oma: installation log and run log of the omm agent. core: dump log generated when the omm agent and the HA process are suspended. |
/var/log/Bigdata/spark |
Spark log. |
/var/log/Bigdata/sudo |
Log generated when the sudo command is executed by user omm. |
/var/log/Bigdata/timestamp |
Time synchronization management log. |
/var/log/Bigdata/tomcat |
Tomcat log. |
/var/log/Bigdata/yarn |
Yarn log. |
/var/log/Bigdata/zookeeper |
ZooKeeper log. |
/var/log/Bigdata/kafka |
Kafka log. |
/var/log/Bigdata/storm |
Storm log. |
/var/log/Bigdata/patch |
Patch log. |
Run logs
Table 3 describes the running information recorded in run logs.
Run Log |
Description |
Installation preparation log |
Records information about preparations for the installation, such as the detection, configuration, and feedback operation information. |
Process startup log |
Records information about the commands executed during the process startup. |
Process startup exception log |
Records information about exceptions during process startup, such as dependent service errors and insufficient resources. |
Process run log |
Records information about the process running track information and debugging information, such as function entries and exits as well as cross-module interface messages. |
Process running exception log |
Records errors that cause process running errors, for example, the empty input objects or encoding or decoding failure. |
Process running environment log |
Records information about the process running environment, such as resource status and environment variables. |
Script logs |
Records information about the script execution process. |
Resource reclamation log |
Records information about the resource reclaiming process. |
Uninstallation clearing logs |
Records information about operations performed during service uninstallation, such as directory deletion and execution time |
Audit logs
Audit information recorded in audit logs includes FusionInsight Manager audit information and component audit information.
Audit Log |
Operation Type |
Operation |
Manager audit log |
User management |
Creating a user Modifying a user Deleting a user Creating a user group Modifying a user group Deleting a user group Adding a role Modifying a role Deleting a role Changing a password policy Changing a password Resetting a password User login User logout Unlocking the screen Downloading the authentication credential Unauthorized operation Unlocking a user account Locking a user account Locking the screen Exporting user information Exporting a user group Exporting a role |
Tenant management |
Saving the static configuration Adding a tenant Deleting a tenant Associating a service with a tenant Deleting a service from a tenant Configuring resources Creating resources Deleting resources Adding a resource pool Modifying a resource pool Deleting a resource pool Restoring tenant data |
Cluster management |
Starting a cluster Stopping a cluster Saving configurations Synchronizing cluster configurations Customizing cluster monitoring indicators Saving monitoring thresholds Downloading a client configuration file Configuring the northbound API Configuring the northbound SNMP API Creating a threshold template Deleting a threshold template Applying a threshold template Saving cluster monitoring configuration data Exporting configuration data Importing cluster configuration data Exporting an installation template Modifying a threshold template Canceling the application of a threshold template Masking alarms Sending an alarm Changing the OMS database password Changing the component database password Starting the health check of a cluster Updating the health check configuration Exporting cluster health check results Importing a certificate file Deleting historical health check reports Exporting historical health check reports Customizing report monitoring indicators Exporting report monitoring data Customizing monitoring indicators for static resource pools Exporting monitoring data of a static resource pool |
Service management |
Starting a service Stopping a service Synchronizing service configurations Refreshing a service queue Customizing service monitoring indicators Restarting a service Exporting service monitoring data Importing service configuration data Starting the health check of a service Exporting service health check results Configuring the service Uploading a configuration file Downloading a configuration file |
Instance management |
Synchronizing instance configurations Commissioning an instance Decommissioning an instance Starting an instance Stopping an instance Customizing instance monitoring indicators Restarting an instance Exporting instance monitoring data Importing instance configuration data |
Host management |
Setting a node rack Starting all roles Stopping all roles Isolating a host Canceling host isolation Customizing host monitoring indicators Exporting host monitoring data Starting the health check of a host Exporting the health check result of a host |
Maintenance management |
Exporting alarms Clearing alarms Exporting events Clearing alarms in batches Clearing alarm through SNMP Adding a trap target through SNMP Deleting a trap target through SNMP Checking alarms through SNMP Synchronizing alarms through SNMP Modifying audit dump configurations Exporting audit logs Collecting log files Downloading log files Uploading a file Deleting an uploaded file Creating a backup task Executing a backup task Stopping a backup task Deleting a backup task Modifying a backup task Locking a backup task Unlocking a backup task Creating a restoration task Executing a backup restoration task Stopping a restoration task Retrying a restoration task Deleting a restoration task |
Audit Log |
Operation Type |
Operation |
DBService audit log |
Performing backup restoration operations |
HBase audit log |
Data definition language (DDL) statement |
Creating a table Deleting a table Modifying a table Adding a column family Modifying a column family Deleting a column family Enabling a table Disabling a table Modify the user information Changing a password User login |
Data manipulation language (DML) statement |
Putting data (to the hbase:meta, _ctmeta_, and hbase:acl tables) Deleting data (from the hbase:meta, _ctmeta_, and hbase:acl tables) Checking and putting data (to the hbase:meta, _ctmeta_, and hbase:acl tables) Checking and deleting data (from the hbase:meta, _ctmeta_, and hbase:acl tables) |
Permission control |
Assigning permissions to a user Canceling permission assigning |
Hive audit logs |
Metadata operation |
Defining metadata, such as creating databases and tables Deleting metadata, such as deleting databases and tables Modifying metadata, such as adding columns and renaming tables Importing and exporting metadata |
Data maintenance |
Loading data to a table Inserting data into a table |
Permissions management |
Creating or deleting roles Granting/Reclaiming roles Granting/Reclaiming permissions |
HDFS audit log |
Managing permissions on files or folders Managing permissions on owner information files or folders |
File operation |
Creating a folder Creating a file Opening a file Appending file content Changing a file name Deleting a file or folder Setting time property of a file Setting the number of file copies Merging files Checking the file system File links |
MapReduce audit log |
Application running |
Starting a Container request Stopping a Container request After Container request is completed, the status of the request is displayed as succeeded. After Container request is completed, the status of the request is displayed as failed. After Container request is completed, the status of the request is displayed as suspended. Submitting a task Ending a task |
LdapServer audit log |
Adding an operating system user Adding a user group Adding a user to user group Deleting a user Deleting a group |
KrbServer audit log |
Changing the password of a Kerberos account Adding a Kerberos account Deleting a Kerberos account Authenticating a user |
Loader audit log |
Security management |
User login |
Metadata management |
Querying connector information Querying a framework Querying step information |
Managing data source connections |
Querying a data source connection Adding a data source connection Updating a data source connection Deleting a data source connection Activating a data source connection Disabling a data source connection |
Job management |
Querying a job Creating a Job Updating a Job Deleting a job Activating a job Disabling a job Querying all execution records of a job Querying the latest execution record of a job Submitting a job Stopping a job |
Hue audit log |
Service startup |
Starting Hue |
User operation |
User login User logout |
Task operation |
Creating a job Modifying a job Deleting a job Submitting a task Saving a task Updating the status of a task |
ZooKeeper audit log |
Setting the access permission to Znode |
Znode operation |
Creating a Znode Deleting a Znode Configuring Znode data |
Storm audit log |
Nimbus |
Submitting a topology Stopping a topology Reallocating a topology Deactivating a topology Activating a topology |
UI |
MRS audit logs are stored in the database. You can view and export audit logs on the Audit page.
The following table lists the directories to store component audit logs. Audit log files of some components are stored in /var/log/Bigdata/audit, such as HDFS, HBase, MapReduce, Hive, Hue, Yarn, Storm, and ZooKeeper. The component audit logs are automatically compressed and backed up to /var/log/Bigdata/audit/bk at 03: 00 every day. A maximum of latest 90 compressed backup files are retained, and the backup time cannot be changed.
Audit log files of other components are stored in the component log directory.
Component |
Audit Log Directory |
DBService |
/var/log/Bigdata/audit/dbservice/dbservice_audit.log |
HDFS |
/var/log/Bigdata/audit/hdfs/nn/hdfs-audit-namenode.log /var/log/Bigdata/audit/hdfs/dn/hdfs-audit-datanode.log /var/log/Bigdata/audit/hdfs/jn/hdfs-audit-journalnode.log /var/log/Bigdata/audit/hdfs/zkfc/hdfs-audit-zkfc.log /var/log/Bigdata/audit/hdfs/httpfs/hdfs-audit-httpfs.log /var/log/Bigdata/audit/hdfs/router/hdfs-audit-router.log |
Mapreduce |
/var/log/Bigdata/audit/mapreduce/jobhistory/mapred-audit-jobhistory.log |
Hive |
/var/log/Bigdata/audit/hive/hiveserver/hive-audit.log /var/log/Bigdata/audit/hive/metastore/metastore-audit.log /var/log/Bigdata/audit/hive/webhcat/webhcat-audit.log |
Loader |
/var/log/Bigdata/loader/audit/default.audit |
Hue |
/var/log/Bigdata/audit/hue/hue-audits.log |
ZooKeeper |
/var/log/Bigdata/audit/zookeeper/quorumpeer/zk-audit-quorumpeer.log |
Spark |
/var/log/Bigdata/audit/spark/jdbcserver/jdbcserver-audit.log /var/log/Bigdata/audit/spark/jobhistory/jobhistory-audit.log |
Yarn |
/var/log/Bigdata/audit/yarn/rm/yarn-audit-resourcemanager.log /var/log/Bigdata/audit/yarn/nm/yarn-audit-nodemanager.log |
Storm |
/var/log/Bigdata/audit/storm/nimbus/audit.log /var/log/Bigdata/audit/storm/ui/audit.log |
