Performing Rolling Restart
After modifying the configuration items of a big data component, you need to restart the corresponding service to make new configurations take effect. If you use a normal restart mode, all services or instances are restarted concurrently, which may cause service interruption. To ensure that services are not affected during service restart, you can restart services or instances in batches by rolling restart. For instances in active/standby mode, a standby instance is restarted first and then an active instance is restarted. Rolling restart takes longer than normal restart.
Table 1 provides services and instances that support or do not support rolling restart in the MRS cluster.
Table 1 Services and instances that support or do not support rolling restart
Service
Instance
Whether to Support Rolling Restart
HDFS
NameNode
Yes
Zkfc
JournalNode
HttpFS
DataNode
Yarn
ResourceManager
Yes
NodeManager
Hive
MetaStore
Yes
WebHCat
HiveServer
Mapreduce
JobHistoryServer
Yes
HBase
HMaster
Yes
RegionServer
ThriftServer
RESTServer
Spark
JobHistory
Yes
JDBCServer
SparkResource
No
Hue
Hue
No
Tez
TezUI
No
Loader
Sqoop
No
Zookeeper
Quorumpeer
Yes
Kafka
Broker
Yes
MirrorMaker
No
Flume
Flume
Yes
MonitorServer
Storm
Nimbus
Yes
UI
Supervisor
Logviewer
Restrictions
  • Perform a rolling restart during off-peak hours.
    • Otherwise, a rolling restart failure may occur. For example, if the throughput of Kafka is high (over 100 MB/s) during the Kafka rolling restart, the Kafka rolling restart may fail.
    • For example, if the requests per second of each RegionServer on the native interface exceed 10,000 during the HBase rolling restart, you need to increase the number of handles to prevent a RegionServer restart failure caused by heavy loads during the restart.
  • Before the restart, check the number of current requests of HBase. If the number of requests of each RegionServer on the native interface exceeds 10,000, increase the number of handles to prevent a failure.
  • If the number of Core nodes in a cluster is less than six, services may be affected for a short period of time.
  • Preferentially perform a rolling instance or service restart and select Only restart instances whose configurations have expired.
Performing a Rolling Service Restart
  1. Choose Clusters > Active Clusters and click a cluster name to go to the cluster details page.
  2. Click Components and select a service for which you want to perform a rolling restart.
  3. On the Service Status tab page, click More and select Rolling-restart Service.
  4. The Rolling-restart Service page is displayed. Select Only restart instances whose configurations have expired and click OK to perform rolling restart for the service.
  5. After the rolling restart task is complete, click Finish.
Performing a Rolling Instance Restart
  3. On the Instance tab page, select the instance to be restarted. Click More and select Rolling-restart Instance.
  4. After you enter the administrator password, the Rolling-restart Instance page is displayed. Select Only restart instances whose configurations have expired and click OK to perform rolling restart for the instance.
Perform a Rolling Cluster Restart
  2. In the upper right corner of the page, choose Management Operations > Perform Rolling Cluster Restart.
  3. The Rolling-restart Cluster page is displayed. Select Only restart instances whose configurations have expired and click OK to perform rolling restart for the cluster.
  4. After the rolling restart task is complete, click Finish.
Rolling Restart Parameter Description
Table 2 describes rolling restart parameters.
Table 2 Rolling restart parameter description
Specifies whether to restart only the modified instances in a cluster.
Data Node Instances to Be Batch Restarted
Specifies the number of instances that are restarted in each batch when the batch rolling restart strategy is used. The default value is 1. The value ranges from 1 to 20. This parameter is valid only for data nodes.
Batch Interval
Specifies the interval between two batches of instances for rolling restart. The default value is 0. The value ranges from 0 to 2147483647. The unit is second.
Note: Setting the batch interval parameter can increase the stability of the big data component process during the rolling restart. You are advised to set this parameter to a non-default value, for example, 10.
Batch Fault Tolerance Threshold
Specifies the tolerance times when the rolling restart of instances fails to be executed in batches. The default value is 0, which indicates that the rolling restart task ends after any batch of instances fails to be restarted. The value ranges from 0 to 2147483647.
Procedure in a Typical Scenario
  2. Click Components and select HBase. The HBase service page is displayed.
  3. Click the Service Configuration tab, and modify an HBase parameter. After the following dialog box is displayed, click OK to save the configurations.
    Do not select Restart the affected services or instances. This option indicates a normal restart. If you select this option, all services or instances will be restarted, which may cause service interruption.
  4. After saving the configurations, click Finish.
  5. Click the Service Status tab.
  6. On the Service Status tab page, click More and select Rolling-restart Service.
  7. After you enter the administrator password, the Rolling-restart Service page is displayed. Select Only restart instances whose configurations have expired and click OK to perform rolling restart.
  8. After the rolling restart task is complete, click Finish.
