Viewing Backup and Restoration Tasks
This section describes how to view created backup and restoration tasks and check their running status on MRS Manager.
- On MRS Manager, click System.
 - Click Back Up Data or Restore Data.
 - In the task list, obtain the previous execution result in the Task Progress column. Green indicates that the task is executed successfully, and red indicates that the execution fails.
 - In the Operation column of a specified task in the task list, choose  to view the historical record of backup and restoration execution.
In the displayed window, click View in the Details column. The task execution logs and paths are displayed.
Related Tasks
- Modifying a backup task
For details, see Modifying a Backup Task.
 - Viewing a restoration task
In the Operation column of the specified task in the task list, click View Details to view the restoration task. You can only view but cannot modify the parameters of a restoration task.
 - Executing a backup or restoration task
In the task list, locate a specified task and click in the Operation column to start a backup or restoration task that is ready or fails to be executed. Executed restoration tasks cannot be repeatedly executed.
 - Stopping backup tasks
In the task list, locate a specified task and click in the Operation column to stop a backup task that is running.
 - Deleting a backup or restoration task
In the Operation column of the specified task in the task list, choose to delete the backup or restoration task. After a task is deleted, the backup data is retained by default.
 - Suspending a backup task
In the Operation column of the specified task in the task list, choose to suspend the backup task. Only periodic backup tasks can be suspended. Suspended backup tasks are no longer executed automatically. When you suspend a backup task that is being executed, the task execution stops. To cancel the suspension status of a task, click .
