Web UIs of Open Source Components
Web UIs of different components are created and hosted on the Master or Core nodes in the MRS cluster by default. You can view information about the components on these web UIs.
Procedure for accessing the web UIs of open-source component:
- Select an access method.
MRS provides the following methods for accessing the web UIs of open-source components:
- EIP-based Access: This method is recommended because it is easy to bind an EIP to a cluster.
 - Access Using a Windows ECS: Independent ECSs need to be created and configured.
 - Creating an SSH Channel for Connecting to an MRS Cluster and Configuring the Browser: Use this method when the user and the MRS cluster are on different networks.
 - Access the web UIs. For details, see Table 1.
Web UIs
        Cluster Type  |
        Web UI Type  |
        Web UI Address  |
        All Types  |
        MRS Manager  |
        Analysis cluster  |
        HDFS NameNode  |
        HBase HMaster  |
        MapReduce JobHistoryServer  |
        YARN ResourceManager  |
        Spark JobHistory  |
        Hue  |
 Loader is a graphical data migration management tool based on the open-source Sqoop web UI, and its interface is hosted on the Hue web UI.  |
        Tez  |
        Presto  |
        Ranger  |
        Stream processing cluster  |
        Storm  |
