Default Users of Clusters with Kerberos Authentication Enabled
User Classification
The MRS cluster provides the following three types of users. Users are advised to periodically change the passwords. It is not recommended to use the default passwords.
User Type
System user
  • User created on Manager for MRS cluster O&M and service scenarios. There are two types of users:
    • Human-machine user: used for Manager O&M scenarios and component client operation scenarios.
    • Machine-machine user: used for MRS cluster application development scenarios.
  • User who runs OMS processes.
Internal system user
Internal user who performs process communications, saves user group information, and associates user permissions.
Database user
  • User who manages OMS database and accesses data.
  • User who runs the database of service components (Hive, Hue, Loader, and DBService)
System User
  • User Idap of the OS is required in the MRS cluster. Do not delete this account. Otherwise, the cluster may not work properly. Password management policies are maintained by the operation users.
  • Reset the passwords when you change the passwords of user ommdba and user omm for the first time. Change the passwords periodically after retrieving them.
Type
Username
Initial Password
System administrator of the MRS cluster
admin
Specified by the user during the cluster creation.
Manager administrator
with the following permissions:
  • Common HDFS and ZooKeeper user permissions.
  • Permissions to submit and query MapReduce and Yarn tasks, manage Yarn queues, and access the Yarn web UI.
  • Permissions to submit, query, activate, deactivate, reassign, delete topologies, and operate all topologies of the Storm service.
  • Permissions to create, delete, authorize, reassign, consume, write, and query topics of the Kafka service.
MRS cluster node OS user
omm
Randomly generated by the system.
Internal running user of the MRS cluster system. This user is an OS user generated on all nodes and does not require a unified password.
root
Set by the user.
User for logging in to the node in the MRS cluster. This user is an OS user generated on all nodes.
Internal System Users
Do not delete the following internal system users. Otherwise, the cluster or components may not work properly.
Type
Default User
Initial Password
Component running user
hdfs
Hdfs@123
This user is the HDFS system administrator and has the following permissions:
  1. File system operation permissions:
    • Views, modifies, and creates files.
    • Views and creates directories.
    • Views and modifies the groups where files belong.
    • Views and sets disk quotas for users.
  2. HDFS management operation permissions:
    • Views the web UI status.
    • Views and sets the active and standby HDFS status.
    • Enters and exits the HDFS in security mode.
    • Checks the HDFS file system.
hbase
Hbase@123
This user is the HBase system administrator and has the following permissions:
  • Cluster management permission: Enable and Disable operations on tables to trigger MajorCompact and ACL operations.
  • Grants and revokes permissions, and shuts down the cluster.
  • Table management permission: Creates, modifies, and deletes tables.
  • Data management permission: Reads and writes data in tables, column families, and columns.
  • Accesses the HBase web UI.
mapred
Mapred@123
This user is the MapReduce system administrator and has the following permissions:
  • Submits, stops, and views the MapReduce tasks.
  • Modifies the Yarn configuration parameters.
  • Accesses the Yarn and MapReduce web UI.
spark
Spark@123
This user is the Spark system administrator and has the following permissions:
  • Accesses the Spark web UI.
  • Submits Spark tasks.
User Group Information
Default User Group
hadoop
Users added to this user group have the permission to submit tasks to all Yarn queues.
hbase
Common user group. Users added to this user group will not have any additional permission.
hive
Users added to this user group can use Hive.
spark
supergroup
Users added to this user group can have the administrator permission of HBase, HDFS, and Yarn and can use Hive.
check_sec_ldap
Used to test whether the active LDAP works properly. This user group is generated randomly in a test and automatically deleted after the test is complete. This is an internal system user group used only between components.
Manager_tenant
Tenant system user group, which is an internal system user group used only between components.
System_administrator
MRS cluster system administrator group, which is an internal system user group used only between components.
Manager_viewer
MRS Manager system viewer group, which is an internal system user group used only between components.
Manager_operator
MRS Manager system operator group, which is an internal system user group used only between components.
Manager_auditor
MRS Manager system auditor group, which is an internal system user group used only between components.
Manager_administrator
MRS Manager system administrator group, which is an internal system user group used only between components.
compcommon
Internal system group for accessing public resources in a cluster. All system users and system running users are added to this user group by default.
default_1000
User group created for tenants, which is an internal system user group used only between components.
kafka
Kafka common user group. Users added to this group need to be granted with read and write permission by users in the kafkaadmin group before accessing the desired topics.
kafkasuperuser
Users added to this group have permissions to read data from and write data to all topics.
kafkaadmin
Kafka administrator group. Users added to this group have the permissions to create, delete, authorize, as well as read from and write data to all topics.
storm
Storm common user group. Users added to this group have the permissions to submit topologies and manage their own topologies.
stormadmin
Storm administrator user group. Users added to this group have the permissions to submit topologies and manage their own topologies.
opentsdb
presto
flume
launcher-job
MRS internal group, which is used to submit jobs using V2 APIs.
OS User Group
wheel
Primary group of MRS internal running user omm.
ficommon
MRS cluster common group that corresponds to compcommon for accessing public resource files stored in the OS of the cluster.
Database User
MRS cluster system database users include OMS database users and DBService database users.
Do not delete database users. Otherwise, the cluster or components may not work properly.
Type
Default User
Initial Password
OMS database
ommdba
dbChangeMe@123456
OMS database administrator who performs maintenance operations, such as creating, starting, and stopping applications.
omm
ChangeMe@123456
User for accessing OMS database data.
DBService database
omm
dbserverAdmin@123
Administrator of the GaussDB database in the DBService component.
hive
HiveUser@
User for Hive to connect to the DBService database.
hue
HueUser@123
User for Hue to connect to the DBService database.
sqoop
SqoopUser@
User for Loader to connect to the DBService database.
ranger
RangerUser@
User for Ranger to connect to the DBService database.
