On this page
Introduction
Overview
MRS provides backup and restoration for user data and system data. The backup function is provided based on components to back up Manager data (including OMS data and LdapServer data), Hive user data, component metadata saved in DBService, and HDFS metadata.
Backup is used in the following scenarios:
  • Routine backup is performed to ensure the data security of the system and components.
  • If the system is faulty, the data backup can be used to recover the system.
  • If the active cluster is completely faulty, an image cluster identical to the active cluster needs to be created. You can use the backup data to restore the active cluster.
Table 1 Backing up metadata
Backup Type
Backup Content
OMS
Database data (excluding alarm data) and configuration data in the cluster management system (by default)
LdapServer
User information (about usernames, passwords, keys, password policies, and user groups)
DBService
Metadata of the components (Hive) managed by DBService
NameNode
HDFS metadata
Principles
Task
Before backup or restoration, you need to create a backup or restoration task and set task parameters, such as the task name, backup data source, and type of backup file save path. Data backup and restoration can be performed by executing backup and restoration tasks. When MRS is used to recover the data of HDFS, HBase, Hive, and NameNode, no cluster can be accessed.
Each backup task can back up data of different data sources and generates an independent backup file for each data source. All the backup files generated in each backup task form a backup file set, which can be used in restoration tasks. Backup data can be stored on Linux local disks, local cluster HDFS, and standby cluster HDFS. The backup task provides the full backup or incremental backup policies. HDFS and Hive backup tasks support the incremental backup policy, while OMS, LdapServer, DBService, and NameNode backup tasks support only the full backup policy.
Task execution rules:
  • If a task is being executed, the task cannot be executed repeatedly and other tasks cannot be started, either.
  • The interval at which a periodical task is automatically executed must be greater than 120s; otherwise, the task is postponed and executed in the next period. Manual tasks can be executed at any interval.
  • When a period task is to be automatically executed, the current time cannot be 120s later than the task start time; otherwise, the task is postponed and executed in the next period.
  • When a periodical task is locked, it cannot be automatically executed and needs to be manually unlocked.
  • Before an OMS, LdapServer, DBService, or NameNode backup task starts, ensure that the LocalBackup partition on the active management node has more than 20 GB available space. Otherwise, the backup task cannot be started.
  • When you are planning backup and restoration tasks, select the data to be backed up or restored strictly based on the service logic, data store structure, and database or table association. The system creates a default periodic backup task default whose execution interval is 24 hours to perform full backup of OMS, LdapServer, DBService, and NameNode data to the Linux local disk.
Specifications
Table 2 Backup and restoration feature specifications
Item
Specifications
Maximum number of backup or restoration tasks
100
Number of concurrent running tasks
Maximum number of waiting tasks
199
Maximum size of backup files on a Linux local disk (GB)
600
Table 3 Specifications of the default task
Item
OMS
LdapServer
DBService
NameNode
Backup period
1 hour
Maximum number of copies
2
Maximum size of a backup file
10 MB
20 MB
100 MB
1.5 GB
Maximum size of disk space used
20 MB
40 MB
200 MB
3 GB
Save path of backup data
Save path/LocalBackup/ of the active and standby management nodes
The backup data of the default task must be periodically transferred and saved outside the cluster based on the enterprise O&M requirements.
