Help Center/
      MapReduce Service/
        User Guide (ME-Abu Dhabi Region)/
        Managing an Existing Cluster/
        Tenant Management/
      Modifying a Resource Pool
You can modify members of an existing resource pool on MRS.
You have synchronized IAM users (on the Dashboard tab page, click Click to synchronize on the right side of IAM User Sync to synchronize IAM users).
- On the MRS details page, click Tenants.
 - Click the Resource Pools tab.
 - Locate the row that contains the specified resource pool, and click Modify in the Operation column.
 - In Modify Resource Pool, modify Added Hosts.
- Adding a host: In the host list on the left, select the specified host name and add it to the resource pool.
 - Deleting a host: In the host list on the right, click
 next to a host to remove the host from the resource pool. The host list of a resource pool can be left blank.
 - Click OK.
   Parent topic: Tenant Management
