OMS Health Check Indicators
OMS Status Check
Indicator: OMS Status Check
Description: The OMS status check includes the HA status check and resource status check. The HA status includes active, standby, and NULL, indicating the active node, standby node, and unknown, respectively. The resource status includes normal, abnormal, and NULL. If the HA status is NULL, the HA status is unhealthy. If the resource status is NULL or abnormal, the resource status is unhealthy.
Item |
Description |
HA state |
active indicates the active node. standby indicates the standby node. NULL: unknown |
Resource status |
normal: All resources are normal. abnormal: indicates that abnormal resources exist. NULL: unknown |
Recovery Guide:
- Log in to the active management node and run the su - omm command to switch to user omm. Run the ${CONTROLLER_HOME}/sbin/status-oms.sh command to check the status of OMS.
- If the HA status is NULL, the system may be restarting. NULL is an intermediate state, and the HA status will automatically change to a normal state.
- If the resource status is abnormal, certain component resources of FusionInsight Manager are abnormal. Check whether the status of components such as acs, aos cep, controller, feed_watchdog, fms, gaussDB, httpd, iam, ntp, okerberos, oldap, pms, and tomcat component is normal.
- If any Manager component resource is abnormal, see Manager component status check to rectify the fault.
Manager Component Status Check
Indicator: Manager Component Status Check
Description: This indicator is used to check the running status and HA status of Manager components. The resource running status includes Normal and Abnormal, and the resource HA status includes Normal and Exception. Manager components include Acs, Aos, Cep, Controller, feed_watchdog, Floatip, Fms, GaussDB, HeartBeatCheck, httpd, IAM, NTP, Okerberos, OLDAP, PMS, and Tomcat. If the running status and HA status is not Normal, the check result is unhealthy.
Item |
Description |
Resource running status: |
Normal: The system is running properly. Abnormal: The running is abnormal. Stopped: The task is stopped. Unknown: The status is unknown. Starting: The process is being started. Stopping: The task is being stopped. Active_normal: The active node is running properly. Standby_normal: The standby node is running properly. Raising_active: The node is being promoted to be the active node. Lowing_standby: The node is being set to be the standby node. No_action: the action does not exist. Repairing: The disk is being repaired. NULL: unknown |
Resource HA status |
Normal the status is normal. Exception: indicates a fault. Non_steady: indicates the non-steady state. Unknown: unknown NULL: unknown |
Recovery Guide:
- If floatip, okerberos, and oldap are abnormal, see ALM-12002, ALM-12004, and ALM-12005 respectively to resolve the problems.
- If other resources are abnormal, you are advised to view the logs of the faulty modules.
If controller resources are abnormal, view /var/log/Bigdata/controller/controller.log of the faulty node.
If the CEP resource is abnormal, check the /var/log/Bigdata/omm/oms/cep/cep.log of the abnormal node.
If aos resources are abnormal, view /var/log/Bigdata/controller/aos/aos.log of the faulty node.
If the feed_watchdog resource is abnormal, view the /var/log/Bigdata/watchdog/watchdog.log file on the abnormal node.
If the httpd resource is abnormal, view /var/log/Bigdata/httpd/error_log of the abnormal node.
If the fms resource is abnormal, check /var/log/Bigdata/omm/oms/fms/fms.log of the abnormal node.
If the pms resource is abnormal, check the /var/log/Bigdata/omm/oms/pms/pms.log of the abnormal node.
If the IAM resource is abnormal, view the /var/log/Bigdata/omm/oms/iam/iam.log of the abnormal node.
If the gaussDB resource is abnormal, check the /var/log/Bigdata/omm/oms/db/omm_gaussdba.log of the abnormal node.
If the NTP resource is abnormal, check the /var/log/Bigdata/omm/oms/ha/scriptlog/ha_ntp.log of the abnormal node.
If the Tomcat resource is abnormal, check the /var/log/Bigdata/tomcat/catalina.log of the abnormal node.
- If the fault cannot be rectified based on the logs, contact O&M personnel and send the collected fault logs.
OMA Running Status
Indicator: OMA running status
Description: This indicator is used to check the running status of the OMA. The status can be Running or Stopped. If the OMA is Stopped, the OMA is unhealthy.
Recovery Guide:
- Log in to the unhealthy node and run the su - omm command to switch to user omm.
- Run ${OMA_PATH}/restart_oma_app to manually start the OMA and check again. If the check result is still unhealthy, go to 3.
- If manually starting the OMA cannot resolve the problem, you are advised to check the OMA logs in /var/log/Bigdata/omm/oma/omm_agent.log.
SSH Trust Between Each Node and the Active Management Node
Indicator: SSH Trust Between Each Node and the Active Management Node
Description: This indicator is used to check whether the SSH mutual trust is normal. If you can switch to another node through SSH from the active OMS node as user omm without the need of entering the password, SSH communication is normal. Otherwise, SSH communication is abnormal. In addition, if you can switch to another node through SSH from the active OMS node but fail to switch to the active OMS node from the other nodes, SSH communication is abnormal.
Recovery Guide:
- If the indicator check result is abnormal, the SSH trust relationships between the nodes and the active management node are abnormal. In this case, check whether the permission of the /home/omm directory is omm. If non-omm users have the directory permission, the SSH trust relationship may be abnormal. You are advised to run chown omm:wheel to modify the permission and check again. If the permission on the /home/omm directory is normal, go to 2.
- The SSH trust relationship exception may cause heartbeat exceptions between Controller and NodeAgent, resulting in node fault alarms. In this case, rectify the fault by referring to the handling procedure of ALM-12006.
Process Running Time
Indicator: NodeAgent running time, Controller running time, and Tomcat running time
Description: This indicator is used to check the running time of the NodeAgent, Controller, and Tomcat processes. If the time is less than half an hour (1800s), the process may have been restarted. You are advised to check the process after half an hour. If multiple check results indicate that the process runs for less than half an hour, the process is abnormal.
Recovery Guide:
- Run the following command to check the PID based on the process name:
- Run the following command to check the process startup time based on the PID:
- Check whether the process start time is normal. If the process restarts repeatedly, go to 5.
- View the related logs and analyze restart causes.
If the runtime of NodeAgent is abnormal, check /var/log/Bigdata/nodeagent/agentlog/agent.log.
If the Controller running time is abnormal, check the /var/log/Bigdata/controller/controller.log file.
If the Tomcat running time is abnormal, check the /var/log/Bigdata/tomcat/web.log file.
Account and Password Expiration Check
Indicator: Account and Password Expiration Check
Description: This indicator checks the two operating system users omm and ommdba of MRS. For OS users, both the account and password expiration time must be checked. If the validity period of the account or password is not greater than 15 days, the account is abnormal.
Recovery Guide: If the validity period of the account or password is less than or equal to 15 days, contact O&M personnel.
