On this page
Configuring Audit Log Exporting Parameters
If MRS audit logs are stored in the system for a long time, the disk space of the data directory may be insufficient. Therefore, you can set export parameters to automatically export audit logs to a specified directory on the OBS server timely, facilitating audit log management.
Audit logs exported to the OBS server include service audit logs and management audit logs.
  • Service audit logs are automatically compressed and stored in the /var/log/Bigdata/audit/bk/ directory on the active management node at 03:00 every day. The file name format is <yyyy-MM-dd_HH-mm-ss>.tar.gz. By default, a maximum of seven log files can be stored. If more than seven log files are stored, the system automatically deletes the log files generated seven days ago.
  • The data range of management audit logs exported to OBS each time is from the last date when the logs are successfully exported to OBS to the date when the task is executed. When the number of management audit logs reaches 100,000, the system automatically dumps the first 90,000 audit logs to a local file and retains 10,000 audit logs in the database. The dumped log files are saved in the ${BIGDATA_DATA_HOME}/dbdata_om/dumpData/iam/operatelog directory on the active management node. The file name format is OperateLog_store_YY_MM_DD_HH_MM_SS.csv. A maximum of 50 historical audit log files can be saved.
  • You have obtained the access key ID (AK) and secret access key (SK) of the account.
  • A parallel file system has been created in OBS.
  1. On MRS Manager, click System.
  2. Choose Export Audit Log under Maintenance.
    Table 1 Parameters for exporting audit logs
    Value
    Start Time
    7/24/2017 09:00:00 (example value)
    (Mandatory) Specifies the start time for exporting audit logs.
    Period (days)
    1 day (example value)
    (Mandatory) Specifies the interval for exporting audit logs. The interval ranges from 1 to 5 days.
    Bucket
    mrs-bucket (example value)
    (Mandatory) Specifies the name of the OBS file system to which audit logs are exported.
    OBS path
    /opt/omm/oms/auditLog (example value)
    (Mandatory) Specifies the OBS path to which audit logs are exported.
    AK
    XXX (example value)
    (Mandatory) Specifies the user's access key ID.
    SK
    XXX (example value)
    (Mandatory) Specifies the user's secret access key.
    Audit logs are stored in service_auditlog and manager_auditlog on OBS, which are used to store service audit logs and management audit logs, respectively.
