Host Health Check Indicators
Swap Usage
Indicator: Swap Usage
Description: Swap usage of the system. The value is calculated using the following formula: Swap usage = Used swap size/Total swap size. Assume that the current threshold is set to 75.0%. If the usage of the file handles in the system exceeds the threshold, the system is unhealthy.
Recovery Guide:
- Check the swap usage of the node.
Log in to the unhealthy node and run the free -m command to check the total swap space and used swap space. If the swap space usage exceeds the threshold, go to 2.
 - If the swap usage exceeds the threshold, you are advised to expand the system capacity, for example, add nodes.
Host File Handle Usage
Indicator: Host File Handle Usage
Description: This indicator indicates the file handle usage in the system. Host file handle usage = Number of used handles/Total number of handles. If the usage exceeds the threshold, the system is unhealthy.
Recovery Guide:
- Check the file handle usage of the host.
Log in to the unhealthy node and run the cat /proc/sys/fs/file-nr command. In the command output, the first and third columns indicate the number of used handles and the total number of handles, respectively. If the usage exceeds the threshold, go to 2.
 - If the file handle usage of the host exceeds the threshold, you are advised to check the system and analyze the file handle usage.
NTP Offset
Indicator: NTP Offset
Description: This indicator indicates the NTP time offset. If the time deviation exceeds the threshold, the system is unhealthy.
Recovery Guide:
- Check the NTP time offset.
Log in to the unhealthy node and run the /usr/sbin/ntpq -np command to view the information. In the command output, the Offset column indicates the time offset. If the time offset is greater than the threshold, go to 2.
 - If the indicator is abnormal, check whether the clock source configuration is correct. Contact O&M personnel.
average load
Indicator: Average Load
Description: Average system load, indicating the average number of processes in the running queue in a specified period. The system average load is calculated using the load value obtained by the uptime command. Calculation method: (Load of 1 minute + Load of 5 minutes + Load of 15 minutes)/(3 x Number of CPUs). Assume that the current threshold is set to 2. If the average load exceeds 2, the system is unhealthy.
Recovery Guide:
- Log in to the unhealthy node and run the uptime command. The last three columns in the command output indicate the load in 1 minute, 5 minutes, and 15 minutes, respectively. If the average system load exceeds the threshold, go to 2.
 - If the system average load exceeds the threshold, you are advised to perform system capacity expansion, such as adding nodes.
D State Process
Indicator: D State Process
Description: This indicator indicates the unstoppable sleep process, that is, the process in the D state. A process that is in the D state is waiting for I/O, such as disk I/O and network I/O, and experiences an I/O exception. If any process in the D state exists in the system, the system is unhealthy.
Recovery Guide: If the indicator is abnormal, the system generates an alarm. You are advised to handle the alarm by referring to ALM-12028.
Hardware Status
Indicator: Hardware Status
Description: This indicator is used to check the system hardware status, including the CPU, memory, disk, power supply, and fan. This indicator obtains related hardware information using ipmitool sdr elist. If the hardware status is abnormal, the hardware is abnormal.
Recovery Guide:
- Log in to the node where the check result is unhealthy. Run the ipmitool sdr elist command to check system hardware status. The last column in the command output indicates the hardware status. If the status is included in the following fault description table, the check result is unhealthy.
Module
Symptom
Processor
IERR
Thermal Trip
FRB1/BIST failure
FRB2/Hang in POST failure
FRB3/Processor startup/init failure
Configuration Error
SM BIOS Uncorrectable CPU-complex Error
Disabled
Throttled
Uncorrectable machine check exception
Power Supply
Failure detected
Predictive failure
Power Supply AC lost
AC lost or out-of-range
AC out-of-range, but present
Config Error: Vendor Mismatch
Config Error: Revision Mismatch
Config Error: Processor Missing
Config Error: Power Supply Rating Mismatch
Config Error: Voltage Rating Mismatch
Config Error
Power Unit
240VA power down
Interlock power down
AC lost
Soft-power control failure
Failure detected
Predictive failure
Memory
Uncorrectable ECC
Parity
Memory Scrub Failed
Memory Device Disabled
Correctable ECC logging limit reached
Configuration Error
Throttled
Critical Overtemperature
Drive Slot
Drive Fault
Predictive Failure
Parity Check In Progress
In Critical Array
In Failed Array
Rebuild In Progress
Rebuild Aborted
Battery
Low
Failed
 - If the indicator is abnormal, contact O&M personnel.
Host Name
Indicator: Host Name
Description: This indicator is used to check whether the host name is set. If the host name is not set, the system is unhealthy. If the indicator is abnormal, you are advised to set the host name properly.
Recovery Guide:
 - Run the hostname host name command to change the host name to ensure that the host name is consistent with the planned host name.
hostnamehost name For example, to change the host name to Bigdata-OM-01, run the hostname Bigdata-OM-01 command.
 - Modify the host name configuration file.
Run the vi /etc/HOSTNAME command to edit the file. Change the file content to Bigdata-OM-01. Save the file, and exit.
Umask
Indicator: Umask
Description: This indicator is used to check whether the umask setting of user omm is correct. If Umask is not 0077, the system is unhealthy.
Recovery Guide:
- If the indicator is abnormal, you are advised to set umask of user omm to 0077. Log in to the unhealthy node and run the su - omm command to switch to user omm.
 - Run the vi ${BIGDATA_HOME}/.om_profile command and change the value of umask to 0077. Save and exit.
OMS HA Status
Indicator: OMS HA Status
Description: This indicator is used to check whether the OMS two-node cluster resources are normal. You can run the ${CONTROLLER_HOME}/sbin/status-oms.sh command to view the detailed information about the status of the OMS two-node cluster resources. If any module is abnormal, the OMS is unhealthy.
Recovery Guide:
- Log in to the active management node and run the su - omm command to switch to user omm. Run the ${CONTROLLER_HOME}/sbin/status-oms.sh command to check the OMS status.
 - If floatip, okerberos, and oldap are abnormal, see ALM-12002, ALM-12004, and ALM-12005 respectively to resolve the problems.
 - If other resources are abnormal, you are advised to view the logs of the faulty modules.
If controller resources are abnormal, view /var/log/Bigdata/controller/controller.log of the faulty node.
If the CEP resource is abnormal, check the /var/log/Bigdata/omm/oms/cep/cep.log of the abnormal node.
If aos resources are abnormal, view /var/log/Bigdata/controller/aos/aos.log of the faulty node.
If the feed_watchdog resource is abnormal, view the /var/log/Bigdata/watchdog/watchdog.log file on the abnormal node.
If the httpd resource is abnormal, view /var/log/Bigdata/httpd/error_log of the abnormal node.
If the fms resource is abnormal, check /var/log/Bigdata/omm/oms/fms/fms.log of the abnormal node.
If the pms resource is abnormal, check the /var/log/Bigdata/omm/oms/pms/pms.log of the abnormal node.
If the IAM resource is abnormal, view the /var/log/Bigdata/omm/oms/iam/iam.log of the abnormal node.
If the gaussDB resource is abnormal, check the /var/log/Bigdata/omm/oms/db/omm_gaussdba.log of the abnormal node.
If the NTP resource is abnormal, check the /var/log/Bigdata/omm/oms/ha/scriptlog/ha_ntp.log of the abnormal node.
If the Tomcat resource is abnormal, check the /var/log/Bigdata/tomcat/catalina.log of the abnormal node.
 - If the fault cannot be rectified based on the logs, contact O&M personnel and send the collected fault logs.
Checking the Installation Directory and Data Directory
Indicator: Checking the Installation Directory and Data Directory
Description: This indicator checks the lost+found directory in the root directory of the disk partition where the installation directory (/opt/Bigdata by default) is located. If the directory contains the files of user omm, there are exceptions. When a node is abnormal, related files are stored in the lost+found directory. This indicator is used to check whether files are lost in such scenarios. Check the installation directory (for example, /opt/Bigdata) and data directory (for example, /srv/BigData). If any files of non-omm users exist in the two directories, the system is unhealthy.
Recovery Guide:
- Log in to the unhealthy node and run the su - omm command to switch to user omm. Check whether files or folders of user omm exist in the lost+found directory.
If the omm user file exists, you are advised to restore it and check again. If the omm user file does not exist, go to 2.
 - Check the installation directory and data directory. Check whether the files or folders of non-omm users exist in the installation directory and data directory. If the files and folders are manually generated temporary files, you are advised to delete them and check again.
CPU Usage
Indicator: CPU Usage
Description: This indicator is used to check whether the CPU usage exceeds the threshold. If the usage exceeds the threshold, it is unhealthy.
Recovery Guide: If the indicator is abnormal, the system generates an alarm. You are advised to handle the alarm by referring to ALM-12016.
Memory Usage
Indicator: Memory Usage
Description: This indicator is used to check whether the memory usage exceeds the threshold. If the usage exceeds the threshold, it is unhealthy.
Recovery Guide: If the indicator is abnormal, the system generates an alarm. You are advised to handle the alarm by referring to ALM-12018.
Host Disk Usage
Indicator: Host Disk Usage
Description: This indicator is used to check whether the host disk usage exceeds the threshold. If the usage exceeds the threshold, it is unhealthy.
Recovery Guide: If the indicator is abnormal, the system generates an alarm. You are advised to handle the alarm by referring to ALM-12017.
Host Disk Write Rate
Indicator: Host Disk Write Rate
Description: This indicator is used to check the disk write rate of a host. The write rate of the host disk may vary according to the service scenario. Therefore, the value of this indicator reflects only the specified value. You need to determine whether the indicator is normal in specified service scenarios.
Recovery Guide: Determine whether the current disk write rate is normal based on the service scenario.
Host Disk Read Rate
Indicator: Host Disk Read Rate
Description: This indicator is used to check the disk read rate of a host. The read rate of the host disk may vary by service scenario. Therefore, the value of this indicator reflects only the specified value. You need to determine whether the indicator is normal in specified service scenarios.
Recovery Guide: Determine whether the current disk read rate is normal based on the service scenario.
Host Service Plane Network Status
Indicator: Host Service Plane Network Status
Description: This indicator is used to check the connectivity of the service plane network of the cluster host. If the hosts are disconnected, the cluster is unhealthy.
Recovery Guide: If the single-plane networking is used, check the IP address of the single plane. For a dual-plane network, the operation procedure is as follows:
- Check the network connectivity between the service plane IP addresses of the active and standby management nodes.
If the network is abnormal, go to 3.
If the network is normal, go to 2.
 - Check the network connectivity between the IP address of the active management node and the IP address of the abnormal node in the cluster.
 - If the network is disconnected, contact O&M personnel to rectify the network fault to ensure that the network meets service requirements.
Host Status
Indicator: host status
Description: This indicator is used to check whether the host status is normal. If a node is faulty, the HDFS service is unhealthy.
Recovery Guide: If the indicator is abnormal, rectify the fault by referring to ALM-12006.
Checking Alarms
Indicator: Checking Alarms
Description: This indicator is used to check whether alarms exist on the host. If alarms exist, the service is unhealthy.
Recovery Guide: If this indicator is abnormal, you can rectify the fault by referring to the alarm handling guide.
