Synchronizing Role Instance Configuration
When Configuration Status of a role instance is Configuration expired or Configuration failed, you can synchronize the configuration data of the role instance with the background configuration.
Impact on the System
After synchronizing a role instance configuration, you need to restart the role instance whose configuration has expired. The role instance is unavailable during restart.
You have synchronized IAM users (on the Dashboard tab page, click Click to synchronize on the right side of IAM User Sync to synchronize IAM users).
- On the MRS cluster details page, click Components.
 - Select a service name.
 - Click the Instances tab.
 - Click the target role instance from the role instance list.
 - Choose More > Synchronize Configuration above the role instance status and indicator information.
 - In the dialog box that is displayed, select Restart the service or instances whose configurations have expired and click Yes to restart the role instance.
