Terminating a Cluster
You can terminate an MRS cluster after job execution is complete.
Background
You can manually terminate a cluster after data analysis is complete or when the cluster encounters an exception. A cluster failed to be deployed will be automatically terminated.
- Log in to the MRS console.
 - In the navigation tree of the MRS console, choose .
 - Locate the cluster to be terminated, and click Terminate in the Operation column.
The cluster status changes from Running to Terminating, and finally to Terminated. You can view the clusters in Terminated state in Cluster History.
