Manually Scaling Out a Cluster
The storage and computing capabilities of MRS can be improved by simply adding Core nodes or Task nodes instead of modifying system architecture, reducing O&M costs. Core nodes can process and store data. You can add Core nodes to expand the node quantities and handle peak loads. Task nodes are used for computing and do not store persistent data.
Background
The MRS cluster supports a maximum of 500 Core and Task nodes. If more than 500 Core/Task nodes are required, contact technical support engineers or invoke a background interface to modify the database.
Core nodes and Task nodes can be added, excluding the Master node. Here, the maximum number of Core/Task nodes to be added is 500 minus the number of Core/Task nodes. For example, the current number of Core nodes is 3, the number of Core nodes to be added must be less than or equal to 497. If the cluster scale-out fails, you can add node to the cluster again.
If no node is added during cluster creation, you can specify the number of nodes to be added during scale-out. However, you cannot specify the nodes to be added.
The operations for scaling out a cluster vary depending on the selected version.
- Log in to the MRS management console.
- Choose , select a running cluster, and click its name to switch to the cluster details page.
- Click the Nodes tab. In the Operation column of the node group, click Scale Out. The Scale Out page is displayed.
The scale-out operation can only be performed on the running clusters.
- Set Scaled Out Nodes, Enable Component, and Run Bootstrap Action, and click OK
- If the Task node group does not exist in the cluster, configure the Task node by referring to Configure Task Node.
- If a bootstrap action is added during cluster creation, the Run Bootstrap Action parameter is valid. If this function is enabled, the bootstrap actions added during cluster creation will be run on all the scaled out nodes.
- If the New Specifications parameter is available, the specifications that are the same as those of the original nodes have been sold out or discontinued. Nodes with new specifications will be added.
- Before scaling out the cluster, check whether its security group configuration is correct. Ensure that an inbound security group rule contains a rule in which Protocol & Port is set to All, and Source is set to a trusted accessible IP address range.
- In the Scale Out Node dialog box, click OK.
- A dialog box is displayed, indicating that the scale-out task is submitted successfully.
The following parameters explain the cluster scale-out process:
- Expanding: If a cluster is being expanded, its status is Scaling out. The submitted jobs will be executed and you can submit new jobs. You are not allowed to continue to scale out, or delete the cluster. You are advised not to restart the cluster or modify the cluster configuration.
- Expansion succeeded: If a cluster is expanded successfully, its status is Running.
- Failed scale-out: The cluster status is Running when the cluster scale-out failed. You can execute jobs and scale out the cluster again.
After the cluster is scaled out, you can view the node information of the cluster on the Nodes tab page of the cluster details page.
Configure Task Node
- On the cluster details page, click the Nodes tab and click Configure Task Node. The Configure Task Node page is displayed.
- On the Configure Task Node page, set Node Type, Instance Specifications, Nodes, System Disk. In addition, if Add Data Disk is enabled, configure the storage type, size, and number of data disks.
- Click OK.
Adding a Node Group
Used to add node groups and applies to customized clusters of MRS 3.x.
- On the cluster details page, click the Nodes tab and click Add Node Group. The Add Node Group page is displayed.
- Set the parameters as needed.
Table 1 Parameters for adding a node group Parameter
Select the flavor type of the hosts in the node group.
Nodes
Set the number of nodes in the node group.
System Disk
Set the specifications and capacity of the system disk on the new node.
Data Disk (GB)
Set the specifications, capacity, and number of data disks of the new node.
Deploy Roles
Deploy the instances of each node in the new node group. The setting can be manually adjusted.
- Click OK.
