Help Center/
      MapReduce Service/
        User Guide (ME-Abu Dhabi Region)/
        FusionInsight Manager Operation Guide (Applicable to 3.x)/
        System Configuration/
        OMS Management/
      Changing the OMS Database Password
Periodically change the password for the OMS data access user to ensure the system O&M security.
Impact on the System
The OMS service needs to be restarted for the password changing to take effect. The FusionInsight Manager is unavailable during the restart.
- Choose System > OMS > gaussDB > Change Password on FusionInsight Manager.
 - Locate the row that contains user omm and click Change Password in the Operation to change the password for the OMS database user.
 - In the displayed window, enter the password of the current login administrator user and click OK.
 - Enter the old and new passwords as prompted.
    The password complexity requirements are as follows:
- The password ranges from 8 to 32 characters.
 - The password must contain at least three types of the following: lowercase letters, uppercase letters, digits, and special characters which can only be ~`!@#$%^&*()-+_=\|[{}];",<.>/?
 - The password cannot be the same as the username or reverse username.
 - The password cannot be the same as the last 20 historical passwords.
 - Click OK. After the system displays Operation succeeded, click Finish.
 - Locate the row that contains user omm and click Restart OMS Service in the Operation to restart the OMS database.
 - In the dialog box that is displayed, click OK, and then restart the OMS service.
   Parent topic: OMS Management
