Overview
Tenants are used in resource control and service isolation scenarios. You need to confirm the service scenarios of cluster resources, and then plan tenants.
- By default, the Yarn component of the newly installed cluster uses the Superior scheduler. For details, see Using the Superior Scheduler in Multi-Tenant Scenarios.
- When the Yarn component of a cluster uses the Capacity scheduler, see Using the Capacity Scheduler in Multi-Tenant Scenarios.
- You can query the value of yarn.resourcemanager.scheduler.class of Yarn to obtain the scheduler type. For details about how to switch the scheduler type, see Switching the Scheduler.
Multi-tenant involves three types of operations: creating a tenant, managing tenants, and managing resources. Table 1 describes the operations.
Operation |
Action |
Description |
Creating a tenant |
During the creation of a tenant, you can configure its computing resources, storage resources, and associated services based on service requirements. In addition, you can add users to the tenant and bind necessary roles to these users. A user who creates level-1 tenants must be bound to the Manager_administrator or System_administrator role. A user who creates sub-tenants must be bound to the role of the parent tenant at least. |
Managing tenants |
Modifies tenants as the services change. A user who manages or deletes level-1 tenants and restores tenants' data must be bound to the Manager_administrator or System_administrator role. A user who manages or deletes sub-tenants must be bound to the role of the parent tenant at least. |
Managing resources |
Reconfigure resources for tenants as the services change. A user who manages resources must be bound to the Manager_administrator or System_administrator role. |
