Managing Backup and Backup Restoration Tasks
You can also maintain and manage backup restoration tasks on FusionInsight Manager.
 - Choose O&M > Backup and Restoration > Backup Management or O&M > Backup and Restoration > Restoration Management.
 - In the Operation column of the specified task in the task list, select the operation to be performed.
Table 1 Maintenance and management operations Operation Entry
Modify parameters for the backup task.
Recover
After some service data is successfully backed up, you can use this function to quickly restore data.
More > Back Up Now
Perform this operation to execute the backup task immediately.
More > Stop
Perform this operation to stop a running task.
More > Delete or Delete
This operation is used to delete tasks.
More > Suspend
Perform this operation to disable the automatic backup task function.
More > Resume
Perform this operation to enable the automatic backup task function.
More > View History or View History
Perform this operation to switch to the task run log page to view the task running details and backup path.
View
Perform this operation to check the parameter settings of the restoration task.
Start
Perform this operation to run the restoration task.
