Configuring the Alarm Masking Status
If you do not want FusionInsight Manager to report specified alarms in the following scenarios, you can manually mask the alarms.
- Some unimportant alarms and minor alarms need to be masked.
 - When a third-party product is integrated with FusionInsight, some alarms of the product are duplicated with the alarms of FusionInsight and need to be masked.
 - When the deployment environment is special, certain alarms may be falsely reported and need to be masked.
After an alarm is masked, new alarms with the same ID as the alarm are neither displayed on the Alarm page nor counted. The reported alarms are still displayed.
 - Choose O&M > Alarm > Masking.
 - In the Masking area, select the specified service or module.
 - Select an alarm from the alarm list.
    Figure 1 Masking an alarm
    The information about the alarm is displayed, including the alarm name, ID, severity, masking status, and operations can be performed on the alarm.- The masking status includes Display and Mask.
 - Operations include Mask and View Help.
      You can filter specified alarms based on the masking status and alarm severity.
 - Set the masking status for an alarm:
- Click Mask. In the displayed dialog box, click OK to change the alarm masking status to Mask.
 - Click Cancel Masking. In the displayed dialog box, click OK to change the masking status of the alarm to Display.
