Resource Monitoring
Some services in the cluster provide service-level resource monitoring metrics. By default, the monitoring data of the latest 12 hours is displayed. You can click
 to customize a time range. The default time ranges are as follows: 12 hours, 1 day, 1 week, and 1 month. You can click
 to export the corresponding report information. If a monitoring item has no data, the report cannot be exported. Table 1 lists the services and monitoring items that support resource monitoring.
Log in to FusionInsight Manager, choose Cluster > Name of the desired cluster > Services, and click Resource. The resource monitoring page is displayed.
       Service  |
       Metrics  |
       Description  |
       HDFS  |
       Resource Usage (by Tenant)  |
       Resource Usage (by User)  |
       Resource Usage (by Directory)  |
       Resource Usage (by Replica)  |
       Resource Usage (by File Size)  |
       Recycle Bin (by User)  |
       Operation Count  |
       Automatic Balancer  |
       NameNode RPC Open Connections (by User)  |
       Slow DataNodes  |
       Displays DataNode that transmits or processes data slowly in the cluster.  |
       Slow Disks  |
       Displays the disk that processes data slowly on the DataNode in the cluster.  |
       HBase  |
       Operation Requests in Tables  |
       Displays the number of PUT, DELETE, GET, SCAN, INCREMENT, and APPEND operation requests in all tables on all RegionServers.  |
       Operation Requests on RegionServers  |
       Displays the number of PUT, DELETE, GET, SCAN, INCREMENT, and APPEND operation requests and number of all operation requests in RegionServer.  |
       Operation Requests for Service  |
       Displays the number of PUT, DELETE, GET, SCAN, INCREMENT, and APPEND operation requests in all regions on RegionServers.  |
       HFiles on RegionServers  |
       Displays the number of HFiles in all RegionServers.  |
       Hive  |
       HiveServer2-Background-Pool Threads (by IP)  |
       Displays the number of HiveServer2-Background-Pool threads of top users. These threads are measured and displayed in a measurement period.  |
       HiveServer2-Handler-Pool Threads (by IP)  |
       Displays the number of HiveServer2-Handler-Pools of top users collected and displayed in a period.  |
       Used MetaStore Number (by IP)  |
       Collects statistics on and displays the MetaStore usage of top users in a period.  |
       Number of Hive jobs  |
       Displays the number of user-related jobs collected by Hive in a period.  |
       Number of Files Accessed in the Split Phase  |
       Displays the number of files accessed by the underlying file storage system (HDFS by default) in the Split phase in a period.  |
       Hive Basic Operation Time  |
       Collects time for creating a directory (mkdirTime), creating a file (touchTime), writing a file (writeFileTime), renaming a file (renameTime), moving a file (moveTime), deleting a file (deleteFileTime), and deleting a directory (deleteCatalogTime) in a period of time.  |
       Table Partitions  |
       Displays the number of partitions in all Hive tables, which is displayed in the following format: database # table name, number of table partitions.  |
       HQL Map Count  |
       Collects statistics on HQL statements executed in a period and the number of Map statements invoked during the execution. The displayed information includes users, HQL statements, and the number of Map statements.  |
       HQL Access Statistics  |
       Displays the number of HQL access times in a period.  |
       Kafka  |
       Kafka Disk Usage Distribution  |
       Displays the disk usage distribution statistics of the Kafka cluster.  |
       Spark2x  |
       Collects HQL access statistics in a period, including the username, HQL statement, and HQL statement execution times.  |
       Yarn  |
       Used resources (by task)  |
       Resource usage (by tenant)  |
       Resource usage ratio (by tenant)  |
       Task Duration Ranking  |
       Displays Yarn tasks sorted by time consumption.  |
       ResourceManager RPC Open Connections (by User)  |
       Displays the number of client RPC connections to ResourceManager by user.  |
       Operation Count  |
       Collects statistics on the number and proportion of operations corresponding to each Yarn operation type.  |
       Ranking of Tasks in a Queue by Resource Usage  |
       Ranking of Users in a Queue by Resource Usage  |
       ZooKeeper  |
       Used Resources (By Second-Level Znode)  |
       Number of Connections (by Client IP Address)  |
       Displays the ZooKeeper client connection resource status.  |
