On this page
Quick Search
Updated on 2023-11-29 GMT+08:00
To search for logs using a keyword repeatedly, perform the following operations to configure quick search.
  1. On the LTS console, choose Log Management in the navigation pane on the left.
  2. In the log group list, click on the left of a log group name.
  3. In the log stream list, click the name of the target log stream.
  4. Click the Raw Logs tab, click , and specify Name and Keyword.
    Figure 1 Configuring quick search
    • A quick search name is used to distinguish multiple quick search statements. The name can be customized and must meet the following requirements:
      • Can contain only letters, digits, hyphens (-), underscores (_), and periods (.).
      • Cannot start with a period (.) or underscore (_) or end with a period (.).
      • Can contain 1 to 64 characters.
    • A quick search statement is used to repeatedly search for logs, for example, error*.
  5. Click OK.
    Click the name of a quick search statement to view log details.
Viewing Context of a Log
You can check the logs generated before and after a log for quick fault locating.
  1. On the Raw Logs tab of the log details page, click to view the context.
    The context of the log is displayed.
    Figure 2 Viewing logs
  2. On the displayed View Context page, check the log context.
    Figure 3 Viewing context of a log
    Table 1 Introduction to log context viewing
    Feature
    Search Rows
    Number of rows to search. The options are 100, 200, and 500.
    Highlighting
    Enter a string to be highlighted and press Enter.
    Filter
    Enter a string to be filtered and press Enter. When both Highlighting and Filter are configured, the filtered string can also be highlighted.
    Fields
    The default field for viewing log context is content. Click Fields to view the context of other fields.
    Prev
    View half the number of Search Rows leading to the current position. For example, if Search Rows is set to 100 and you click Prev, 50 rows prior to the current position are displayed. In this case, the current line number is -50. If you click Prev again, the line number will become -100, -150, -200, and so on.
    Current
    Current log position. When Prev or Update is set, you can click Current to return to the position where the context starts (when the line number is 0).
    Update
    View half the number of Search Rows following the current position. For example, if Search Rows is set to 100 and you click Update, 50 rows following the current position are displayed. In this case, the current line number is 50. If you click Update again, the line number will become 100, 150, 200, and so on.
    Summary Mode
    If this mode is enabled, only the line number and content are displayed. If this mode is disabled, log details are displayed.
