- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Granting LTS Permissions to IAM Users
- Purchasing LTS Resource Packages
- Log Management
Log Ingestion
- Overview
Using ICAgent to Collect Logs
- Overview
- Installing ICAgent (Intra-Region Hosts)
- Installing ICAgent (Extra-Region Hosts)
- Managing ICAgent
- Managing Host Groups
- Ingesting BMS Text Logs to LTS
- Ingesting CCE Application Logs to LTS
- Ingesting ECS Text Logs to LTS
- Ingesting ServiceStage Containerized Application Logs to LTS
- Ingesting ServiceStage Cloud Host Logs to LTS
- Ingesting Self-Built Kubernetes Application Logs to LTS
- Setting ICAgent Structuring Parsing Rules
Ingesting Cloud Service Logs to LTS
- Overview
- Ingesting AOM Logs to LTS
- Ingesting APIG Logs to LTS
- Ingesting CBH Logs to LTS
- Ingesting CFW Logs to LTS
- Ingesting CTS Logs to LTS
- Ingesting DDS Logs to LTS
- Ingesting DMS for Kafka Logs to LTS
- Ingesting DRS Logs to LTS
- Ingesting GaussDB(DWS) Logs to LTS
- Ingesting ELB Logs to LTS
- Ingesting Enterprise Router Logs to LTS
- Ingesting FunctionGraph Logs to LTS
- Ingesting GaussDB Logs to LTS
- Ingesting GES Logs to LTS
- Ingesting TaurusDB Logs to LTS
- Ingesting GeminiDB Logs to LTS
- Ingesting GeminiDB Mongo Logs to LTS
- Ingesting GeminiDB Cassandra Logs to LTS
- Ingesting IoTDA Logs to LTS
- Ingesting ModelArts Logs to LTS
- Ingesting MRS Logs to LTS
- Ingesting RDS for MySQL Logs to LTS
- Ingesting RDS for PostgreSQL Logs to LTS
- Ingesting RDS for SQL Server Logs to LTS
- Ingesting ROMA Connect Logs to LTS
- Ingesting SMN Logs to LTS
- Ingesting SecMaster Logs to LTS
- Ingesting OBS Files to LTS (Beta)
- Ingesting VPC Logs to LTS
- Ingesting WAF Logs to LTS
- Using APIs to Ingest Logs to LTS
- Ingesting Logs to LTS Across IAM Accounts
- Using Kafka to Report Logs to LTS
- Using Flume to Report Logs to LTS
- Log Search and Analysis
Log Visualization
- Overview
- Visualizing Logs in Statistical Charts
Visualizing Logs in Dashboards
- Creating a Dashboard
- Adding a Dashboard Filter
Dashboard Templates
- APIG Dashboard Templates
- CCE Dashboard Templates
- CDN Dashboard Templates
- CFW Dashboard Templates
- CSE Dashboard Templates
- DCS Dashboard Template
- DDS Dashboard Template
- DMS Dashboard Template
- DSL Dashboard Template
- ER Dashboard Template
- METRIC Dashboard Template
- Nginx Dashboard Templates
- VPC Dashboard Template
- WAF Dashboard Templates
- Log Alarms
- Log Transfer
- Log Processing
- Configuration Center
- Querying Real-Time LTS Traces
Best Practices
- Overview
Log Ingestion
- Collecting Logs from Third-Party Cloud Vendors, Internet Data Centers, and Other Huawei Cloud Regions to LTS
- Collecting Kubernetes Logs from Third-Party Clouds, IDCs, and Other Huawei Cloud Regions to LTS
- Collecting Syslog Aggregation Server Logs to LTS
- Importing Logs of Self-built ELK to LTS
- Collecting Zabbix Data Through ECS Log Ingestion
- Collecting Logs from Multiple Channels to LTS
- Log Transfer
- Billing
- Developer Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- API Calling Examples
- Examples
APIs
- Host Group Management
- Log Group Management
- Log Stream Management
- Log Management
- Log Ingestion
- Log Transfer
- Log Collection Beyond Free Quota
- Cloud Log Structuring
- Container Log Ingestion from AOM to LTS
- Alarm Topics
- Message Template Management
- SQL Alarm Rules
- Keyword Alarm Rules
- Alarm List
- Tag Management
- Dashboard Management
- Log Charts
- Quick Search
- Multi-Account Log Aggregation
- Appendix
- SDK Reference
- Overview
- Consultation
- Log Management
Host Management
- What Do I Do If ICAgent Installation Fails in Windows and the Message "SERVICE STOP" Is Displayed?
- What Do I Do If ICAgent Upgrade Fails on the LTS Console?
- What Do I Do If I Could Not Query New Logs on LTS?
- What Do I Do If ICAgent Restarts Repeatedly After Being Installed?
- What Do I Do If ICAgent Is Displayed as Offline on the LTS Console After Installation?
- What Do I Do If I Do Not See a Host with ICAgent Installed on the LTS Console?
- How Do I Create a VPC Endpoint on the VPCEP Console?
- How Do I Obtain an AK/SK Pair?
- How Do I Install ICAgent by Creating an Agency?
Log Ingestion
- What Do I Do If LTS Cannot Collect Logs After I Configure Host Log Ingestion?
- Will LTS Stop Collecting Logs After the Free Quota Is Used Up If I Disable "Continue to Collect Logs When the Free Quota Is Exceeded" in AOM?
- What Do I Do If the CPU Usage Is High When ICAgent Is Collecting Logs?
- What Kinds of Logs and Files Does LTS Collect?
- How Do I Disable the Function of Collecting CCE Standard Output Logs to AOM on the LTS Console?
- What Log Rotation Scheme Should I Use for ICAgent to Collect Logs?
- Does LTS Use the Log4j Plug-in to Report Logs?
- How Long Does It Take to Generate Logs After Configuring Log Ingestion?
- What Do I Do If LTS Cannot Collect Logs After I Configure Log Ingestion with ICAgent?
Log Transfer
- Does LTS Delete Logs That Have Been Transferred to OBS Buckets?
- What Are the Common Causes of LTS Log Transfer Abnormalities?
- How Do I Transfer CTS Logs to an OBS Bucket?
- What Do I Do If I Cannot View Historical Data in an OBS Bucket After Transferring Data from LTS to OBS?
- What Do I Do If I Cannot Find a New Partition in a DLI Table After Logs Are Transferred to DLI?
More Documents
- User Guide (ME-Abu Dhabi Region)
- API Reference (ME-Abu Dhabi Region)
- User Guide(Paris Regions)
- API Reference(Paris Regions)
- User Guide (Kuala Lumpur Region)
- API Reference (Kuala Lumpur Region)
- User Guide (Ankara Region)
API Reference (Ankara Region)
- Before You Start
- Calling APIs
- APIs
- Appendix
- Change History
- Videos
Show all
Log Search
Follow the directions below to search logs by keyword and time range:
- On the LTS console, choose Log Management in the navigation pane on the left.
- In the log group list, click
on the left of a log group name.
- In the log stream list, click a log stream name.
Figure 1 Log details
- In the upper right corner, select a time range.
There are three types of time range: relative time from now, relative time from last, and specified time. Select a time range as required.
- From now: queries log data generated in a time range that ends with the current time, such as the previous 1, 5, or 15 minutes. For example, if the current time is 19:20:31 and 1 hour is selected as the relative time from now, the charts on the dashboard display the log data that is generated from 18:20:31 to 19:20:31.
- From last: queries log data generated in a time range that ends with the current time, such as the previous 1 or 15 minutes. For example, if the current time is 19:20:31 and 1 hour is selected as the relative time from last, the charts on the dashboard display the log data that is generated from 18:00:00 to 19:00:00.
- Specified: queries log data that is generated in a specified time range.
- On the log stream details page, you can search for logs using the following methods:
- In the search area, click in the search box. The drop-down list contains the following items:
- Structured fields or index fields: Built-in fields are not displayed in the drop-down list. However, when you enter a built-in field, the drop-down list is automatically associated and matched with the field.
- NOT, AND, OR, :, and :* keywords can be displayed. Keywords other than NOT are displayed in the drop-down list only after you enter the keyword in the search box.
- When entering a keyword, you can press Tab to automatically add the first keyword displayed in the drop-down list.
- Keywords are case-insensitive.
- Historical records: A maximum of 20 historical records can be retained, but only the latest three records are displayed in the drop-down list.
- Quick search: quick search fields that have been created.
- Search syntax: common search syntax.
Enter a keyword, or select a field and keyword from the drop-down list, and click Query.
Logs that contain the keyword are displayed.
- Built-in fields include appName, category, clusterId, clusterName, collectTime, containerName, hostIP, hostIPv6, hostId, hostName, nameSpace, pathFile, podName and serviceID. By default, the fields are displayed in simplified mode, and hostIP, hostName, and pathFile are displayed at the beginning.
- The structured fields are displayed in key:value format.
- On the Raw Logs page, click a field in blue in the log content. You can select Copy, Add To Search, and Exclude from Search from the displayed drop-down list.
- Click a field for which quick analysis has been created to add it to the search box.
If the field you click already exists in the search box, it will be replaced by this newly added one. If the field is added for the first time, fields in the search box are searched using the AND operator.
- In the search area, press the up and down arrows on the keyboard to select a keyword or search syntax from the drop-down list, press Tab or Enter to select a keyword or syntax, and click Query.
- Under the log content, click
in front of the time. Structured fields can be displayed in table or JSON format.
- On the Table tab page, you can search for logs by adding a field to a query or excluding a field from a query, or through whether a field exists, whether a field does not exist, or whether a field is hidden. For details, see Search Syntax.
- On the JSON tab page, you can view or copy a log.
- Set the layout.
- Select All layouts from the drop-down list. The layout setting page is displayed. The layout list contains the default layout and pure layout. You can set whether to display fields on the layout.
Cloud: This mode is applicable to users who have the write permission. Layout information is stored on the cloud.
Local Cache: This mode is applicable to users who have only the read permission. Layout information is cached in the local browser.
- Click
to add a custom layout and set the layout name and visibility of layout fields.
- After the setting is complete, click OK. The new custom layout is displayed in the drop-down list.
Common Log Search Operations
Log search operations include sharing logs and refreshing logs.
Operation |
Description |
Interactive search |
Click |
Creating quick search criteria |
Click |
Sharing logs |
Click |
Refreshing logs |
You can click
Copying logs |
Click |
Viewing context of a log |
Click You can select Simple View to view the log context. |
Simplifying field details |
Click |
Unfold/Fold |
Click ![]() ![]() Unfold is enabled by default. |
Downloading logs |
Click Direct Download: Download log files to the local PC. Up to 5000 logs can be downloaded at a time. Select .csv or .txt from the drop-down list and click Download to export logs to the local PC.
Collapse all/Expand all |
Click By default, logs are not collapsed, and two rows of logs are shown after collapsing. You can display up to six rows. |
JSON |
Move the cursor over Formatting is enabled by default. The default number of expanded levels is 2.
Collapse configuration |
Move the cursor over If the number of characters in a log exceeds the maximum, the extra characters will be hidden. Click Expand to view all. Logs are collapsed by default, with a default character limit of 400. |
Invisible fields ( |
This list displays the invisible fields configured in the layout settings.
