On this page
Cross-Account Ingestion
Updated on 2023-11-29 GMT+08:00
If you choose Cross-Account Ingestion > Log Stream Mapping as the log ingestion type, you can create an agency to map the log stream of the delegator account to that of the delegated account (the current LTS account).
After you configure cross-account ingestion, if account A deletes the agency from IAM, LTS cannot detect the deletion and the cross-account ingestion still takes effect. If the cross-account ingestion configuration is no longer used, notify account B to delete it.
An agency relationship has been created.
Restrictions
  • Log stream mapping cannot be performed for log cleaning logs.
  • Before data synchronization is complete, data in the target and source log streams may be different. Check back later in one hour.
If you choose Cross-Account Ingestion as the log ingestion type, perform the following operations to configure the ingestion:
  1. Log in to the LTS console.
  2. In the navigation pane on the left, choose Log Ingestion and click Cross-Account Ingestion.
  3. Select an agency.
    Set parameters by referring to Table 1 and click Next: Log Stream Mapping.
    Table 1 Agency parameters
    Agency Name
    Enter the name of an agency created by the delegator in IAM. A delegator account can create an agency to delegate resource management permissions to another account.
    Delegator Account Name
    Enter the name of the delegator account to verify the delegation.
  4. Map log streams.
    On the Log Stream Mapping page, there are two ways to configure ingestion rules: automatic and manual configuration.
    • Automatic configuration
      1. Click Auto Configure.
      2. On the displayed page, set the required parameters and click OK.
        Table 2 Parameters of automatic ingestion rule configuration
        Rule Name Prefix
        Enter the rule name prefix. In automatic configuration, this prefix is used to generate multiple ingestion rules.
        Can contain only letters, digits, underscores (_), hyphens (-), and periods (.). The prefix cannot start with a period or underscore, or end with a period. If you do not specify a prefix, the default rule name prefix rule will be used.
        Select the log groups or log streams that you want to ingest from the delegator account.
        Up to 20 log groups or log streams can be selected.
        By default, the names of the target log groups and target log streams of the delegated account are the same as those of the source log groups and source log streams of the delegator account. You can also manually change the names of the target log groups and target log streams.
      3. Click Preview.
        1. There are two types of preview results:
          • A new target log stream will be created: A target log group or log stream will be created in the delegated account.
          • An existing target log stream will be ingested: The target log group or log stream already exists in the delegated account.
        2. Preview error messages are as follows:
          • Source log stream xxx has been configured as the target log stream.
          • Target log stream xxx has been configured as the source log stream.
          • Target log stream xxx already exists in another log group.
          • Target log stream xxx exists in different target log groups.
          • Duplicate rule names.
          • The source log stream xxx is already mapped.
          • The number of log groups or log streams exceeds the upper limit.
          If any of the preceding error messages is displayed, delete the corresponding ingestion rule of the log stream.
      4. After the preview is complete, click Submit.
    • Manual configuration
      1. On the Log Stream Mapping page, click Add Rule.
        Table 3
        Rule Name
        The default value is rule_xxx. You can also specify a name as needed.
        Can contain only letters, digits, underscores (_), hyphens (-), and periods (.). The name cannot start with a period or underscore, or end with a period.
        Delegator Account
        Source Log Group
        Log group of the delegator account. Select an existing log group.
        Source Log Stream
        Log stream of the delegator account. Select an existing log stream.
        Delegated Account
        Target Log Group
        Log group of the delegator account. You can select an existing log group or enter a name to create one.
        Target Log Stream
        Log stream of the delegated account. You can select an existing log stream or enter a name to create one.
      2. Click Preview.
        2. There are five types of preview errors:
      3. After the preview is complete, click Submit and wait until the log ingestion task is created.
  5. Finish the configuration.
    After the configuration is complete, data will be synchronized within one hour. Please check back later.
    • If multiple log streams are ingested, you can click Back to Ingestion Configurations to view the log ingestion list.
    • If a single log stream is ingested, click Back to Ingestion Configurations to view the log ingestion list. Click View Log Stream to view details about the ingested log stream.
