Resetting the SASL_SSL Password
If you forget the password of a SASL_SSL user created on the Users tab page, you can reset the password and use the new password to connect to the Kafka instance.
- You can reset the SASL_SSL password only if Kafka SASL_SSL has been enabled for the instance.
- You can reset the SASL_SSL password only when the instance is in the Running state.
- Click
in the upper left corner to select a region.
Select the region where your Kafka instance is located.
- Click
and choose Application > Distributed Message Service for Kafka to open the console of DMS for Kafka. - Click the name of the desired Kafka instance.
- On the Users tab page, click Reset Password in the row containing the desired user.
- Enter and confirm a new password, and click OK.
- If the password is successfully reset, a success message is displayed.
- If the password fails to be reset, a failure message is displayed. In this case, reset the password again. If you still fail to reset the password after multiple attempts, contact customer service.
The system will display a success message only after the password is successfully reset on all brokers.
