- What's New
- Function Overview
- Product Bulletin
Service Overview
- Infographics
- What Is DMS for Kafka?
- Product Advantages
- Application Scenarios
- Kafka Instance Specifications
- Comparing Single-node and Cluster Kafka Instances
- Comparing Kafka, RabbitMQ, and RocketMQ
- Comparing DMS for Kafka and Open-Source Kafka
- Security
- Notes and Constraints
- Related Services
- Basic Concepts
- Permissions
- Billing
- Getting Started
User Guide
- Process of Using Kafka
- Permissions Management
- Buying a Kafka Instance
- Configuring Topics
- Connecting to an Instance
- Managing Messages
- Managing Consumer Groups
- Managing Quotas
Managing Instances
- Viewing and Modifying Basic Information of a Kafka Instance
- Viewing Kafka Disk Usage
- Viewing Kafka Background Tasks
- Viewing Sample Code of Kafka Production and Consumption
- Modifying Kafka Instance Configuration Parameters
- Configuring Kafka Instance Tags
- Configuring Kafka Recycling Policies
- Upgrading the Kafka Instance Kernel
- Exporting the Kafka Instance List
- Restarting a Kafka Instance
- Deleting Kafka Instances
- Using Kafka Manager
- Modifying Instance Specifications
- Migrating Data
- Testing Instance Performance
- Applying for Increasing Kafka Quotas
- Monitoring and Alarms
- Viewing Kafka Audit Logs
Best Practices
- Kafka Best Practices
- Improving Kafka Message Processing Efficiency
- Optimizing Consumer Polling
- Interconnecting Logstash to Kafka to Produce and Consume Messages
- Using MirrorMaker to Synchronize Data Across Clusters
- Handling Message Accumulation
- Handling Service Overload
- Handling Uneven Service Data
- Configuring Message Accumulation Monitoring
- Suggestions on Using DMS for Kafka Securely
- Developer Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs V2 (Recommended)
- Managing Lifecycle
Instance Management
- Resetting the Password
- Resetting Kafka Manager Password
- Restarting Kafka Manager
- Configuring Automatic Topic Creation
- Modifying the Private IP Address for Cross-VPC Access
- Querying Kafka Cluster Metadata
- Querying Coordinator Details of a Kafka Instance
- Reassigning Replicas of a Topic for a Kafka Instance
- Modifying Kafka Access Modes
- Querying the Disk Usage Status of Topics
- Initiating Partition Reassignment for a Kafka Instance
- Disabling Kafka Manager
- Deleting a User or Client Quota
- Querying User or Client Quotas
- Creating User or Client Quotas
- Modifying User or Client Quotas
Smart Connect
- Enabling Smart Connect (Pay-per-Use Instance)
- Disabling Smart Connect (Pay-per-Use Instance)
- Creating a Smart Connect Task
- Querying Smart Connect Tasks
- Querying Smart Connect Task Details
- Deleting a Smart Connect Task
- Pausing a Smart Connect Task
- Restarting a Smart Connect Task
- Starting a Smart Connect Task or Restarting a Paused or Running Smart Connect Task
- Specification Modification Management
- Topic Management
- Querying Consumer Group Details
- Querying All Consumer Groups
- Deleting Consumer Groups of a Kafka Instance in Batches
- Creating a Consumer Group
- Resetting Consumer Group Offset to the Specified Position
- Querying the Offset of a Consumer Group
- Modifying All Consumer Groups
- Querying a Specified Consumer Group
- Deleting a Specified Consumer Group
- Modifying a Specified Consumer Group
- Querying Topics of a Specified Consumer Group
- Querying Consumers in a Specified Consumer Group
- User Management
- Managing Messages
- Background Task Management
- Tag Management
- Diagnosis Management
- Other APIs
- Out-of-Date APIs
- Appendix
- Change History
- SDK Reference
Instances
- Why Can't I Select Two AZs?
- Why Can't I View the Subnet and Security Group Information When Creating a DMS Instance?
- How Do I Select Storage Space for a Kafka Instance?
- How Do I Choose Between High I/O and Ultra-high I/O?
- Which Capacity Threshold Policy Should I Use?
- Which Kafka Versions Are Supported?
- What Is the ZooKeeper Address of a Kafka Instance?
- Are Kafka Instances in Cluster Mode?
- Can I Modify the Port for Accessing a Kafka Instance?
- How Long Are Kafka SSL Certificates Valid for?
- How Do I Synchronize Data from One Kafka Instance to Another?
- How Do I Change the SASL_SSL Setting of a Kafka Instance?
- How Do I Modify the SASL Mechanism?
- How Do I Change the Security Protocol?
- Will a Kafka Instance Be Restarted After Its Enterprise Project Is Modified?
- Are Kafka Brokers and ZooKeeper Deployed on the Same VM or on Different VMs?
- Can I Delete a Kafka Instance Billed in Yearly/Monthly Mode?
- Which Cipher Suites Are Supported by Kafka?
- Can I Change Single-AZ Deployment to Multi-AZ Deployment for an Instance?
- Does DMS for Kafka Support Cross-AZ Disaster Recovery? Where Can I Check Whether an Existing Instance is Across-AZs?
- Do Kafka Instances Support Disk Encryption?
- Can I Change the VPC and Subnet After a Kafka Instance Is Created?
- Where Can I Find Kafka Streams Use Cases?
- Can I Upgrade Kafka Instances?
- How Do I Bind an EIP Again?
Connections
- How Do I Select and Configure a Security Group?
- Can I Access a Kafka Instance Over a Public Network?
- How Many Connection Addresses Does a Kafka Instance Have by Default?
- Do Kafka Instances Support Cross-Region Access?
- Do Kafka Instances Support Cross-VPC Access?
- Do Kafka Instances Support Cross-Subnet Access?
- Does DMS for Kafka Support Authentication with Kerberos?
- Does DMS for Kafka Support Password-Free Access?
- How Do I Obtain the Public Access Address After Public Access Is Enabled?
- Does DMS for Kafka Support Authentication on Clients by the Server?
- Can I Use PEM SSL Truststore When Connecting to a Kafka Instance with SASL_SSL Enabled?
- What Are the Differences Between JKS and CRT Certificates?
- Which TLS Version Does DMS for Kafka Support?
- Is There a Limit on the Number of Client Connections to a Kafka Instance?
- How Many Connections Are Allowed from Each IP Address?
- Can I Change the Private Network Addresses of a Kafka Instance?
- Is the Same SSL Certificate Used for Different Instances?
- Why Is It Not Recommended to Use a Sarama Client for Messaging?
Topics and Partitions
- Is There a Limit on the Number of Topics in a Kafka Instance?
- Why Is Partition Quantity Limited?
- Can I Reduce the Partition Quantity?
- Why Do I Fail to Create Topics?
- Do Kafka Instances Support Batch Importing Topics or Automatic Topic Creation?
- Why Do Deleted Topics Still Exist?
- Can I View the Disk Space Used by a Topic?
- Can I Add ACL Permissions for Topics?
- What Should I Do If Kafka Storage Space Is Used Up Because Retrieved Messages Are Not Deleted?
- How Do I Increase the Partition Quantity?
- Will a Kafka Instance Be Restarted After Its Automatic Topic Creation Setting Is Modified?
- What Can I Do If a Consumer Fails to Retrieve Messages from a Topic Due to Insufficient Permissions?
Consumer Groups
- Do I Need to Create Consumer Groups, Producers, and Consumers for Kafka Instances?
- Will a Consumer Group Without Active Consumers Be Automatically Deleted in 14 Days?
- Why Does a Deleted Consumer Group Still Exist?
- Why Can't I View Consumers When Instance Consumption Is Normal?
- Can I Delete Unnecessary Topics in a Consumer Group?
Messages
- What Is the Maximum Size of a Message that Can be Created?
- Why Does Message Poll Often Fail During Rebalancing?
- Why Can't I Query Messages on the Console?
- What Can I Do If Kafka Messages Are Accumulated?
- Why Do Messages Still Exist After the Retention Period Elapses?
- Do Kafka Instances Support Delayed Message Delivery?
- How Do I View the Number of Accumulated Messages?
- Why Is the Message Creation Time Displayed as Year 1970?
- How Do I Modify message.max.bytes?
- Why Are Offsets Not Continuous?
Kafka Manager
- Can I Configure a Kafka Manager Account to Be Read-Only?
- Why Can't I See Broker Information After Logging In to Kafka Manager?
- Yikes! Insufficient partition balance when creating topic : projectman_project_enterprise_project Try again.
- Can I Query the Body of a Message by Using Kafka Manager?
- Can I Change the Port of the Kafka Manager Web UI?
- Which Topic Configurations Can Be Modified on Kafka Manager?
- Why Is Information Displayed on Kafka Manager Inconsistent with Cloud Eye Monitoring Data?
- How Do I Change a Partition Leader for a Topic in Kafka Manager?
- Why Is the Version on the Console Different from That in Kafka Manager?
- Why Does an Instance Contain Default Topics __trace and __consumer_offsets?
- Why Do I See a Deleted Consumer Group on Kafka Manager?
Monitoring & Alarm
- Why Can't I View the Monitoring Data?
- Why Is the Monitored Number of Accumulated Messages Inconsistent with the Message Quantity Displayed on the Kafka Console?
- Why Is a Consumer Group Still on the Monitoring Page After Being Deleted?
- Why Do Metrics Fluctuate Significantly (Disk Read/Write Speed, Average Disk Read/Write Time, and CPU Usage)?
- Why Does JVM Heap Memory Usage of JVM Fluctuate Significantly?
- Why Is Production Rate Still 0 When There Are Produced Messages?
Instances
Troubleshooting
- Troubleshooting Kafka Connection Exceptions
- Troubleshooting 6-Min Latency Between Message Creation and Retrieval
- Troubleshooting Message Creation Failures
- Troubleshooting Topic Deletion Failures
- Troubleshooting Failure to Log In to Kafka Manager in Windows
- Troubleshooting Error "Topic {{topic_name}} not present in metadata after 60000 ms" During Message Production or Consumption
- Flink 1.15 Consumption Progress Submission Failure
- Videos
More Documents
- Getting Started
- Preparing Required Resources
- Buying an Instance
- Accessing a Kafka Instance
- Managing Instances
- Managing Topics
- Managing Messages
- Managing Users
- Managing Kafka Quotas
- Modifying Kafka Parameters
- Quotas
- Monitoring
- Auditing
Instances
- Can I Change an Instance from Single-AZ Deployment to Multi-AZ Deployment?
- Does DMS for Kafka Support Cross-AZ Disaster Recovery? Where Can I View the AZs Configured for an Existing Instance?
- Does Specification Modification Affect Services?
Connections
- Can I Change the Partition Quantity?
- How Do I Disable Automatic Topic Creation?
- Consumer Groups
Messages
Kafka Manager
- Monitoring & Alarm
Instances
Troubleshooting
- Change History
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris Region)
- Getting Started
- Creating an Instance
- Managing Topics
- Managing Messages
- Managing Users
- Quotas
- Monitoring
- Auditing
Instances
Connections
- Consumer Groups
Messages
Kafka Manager
Instances
Troubleshooting
- Change History
API Reference (Paris Region)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- Lifecycle Management
Instance Management
- Adding Partitions to a Topic for a Kafka Instance
- Querying a Specific Consumer Group
- Deleting a Consumer Group from a Kafka Instance
- Batch Deleting Consumer Groups of a Kafka Instance
- Initiating Partition Reassigning for a Kafka Instance
- Topic Management
- User Management
- Message Query
- Tag Management
- Other APIs
- Out-of-Date APIs
- Appendix
- Change History
- Developer Guide (Paris Region)
- Getting Started
- Managing Messages
- Managing Quotas
Managing Instances
- Modifying Kafka Instance Specifications
- Migrating Data
Instances
Connections
- Consumer Groups
Messages
Kafka Manager
Instances
Troubleshooting
- Change History
- API Reference (Kuala Lumpur Region)
Partition reassignment is to reassign replicas of a partition to different brokers to solve the problem of unbalanced broker load.
Partition reassignment is required in the following scenarios:
- After the broker quantity is increased for an instance, the replicas of the original topic partitions are migrated to the new brokers.
- The leader partition is degraded to be a follower on a heavily loaded broker.
- The number of replicas is increased or decreased.
The DMS for Kafka console provides automatic and manual reassignment. Automatic reassignment is recommended because it ensures that leaders are evenly distributed.
Operation Impact
- Partition reassignment on topics with a large amount of data consumes a large amount of network and storage bandwidth. As a result, service requests may time out or the latency may increase. Therefore, you are advised to perform reassignment during off-peak hours.
- A throttle refers to the upper limit of the bandwidth for replication of a topic, to ensure that other topics on the instance are not affected. Note that throttles apply to replication triggered by both normal message production and partition reassignment. If the throttle is too small, normal message production may be affected, and partition reassignment may never complete.
- You cannot delete topics whose reassignment tasks have started. Otherwise, the tasks will never complete.
- You cannot modify the partition quantity of topics whose reassignment tasks have started.
- Reassignment tasks cannot be manually stopped. Please wait until they complete.
- After partition reassignment, the metadata of the topic changes. If the producer does not support the retry mechanism, a few requests will fail, causing some messages to fail to be produced.
- Reassignment takes a long time if the topic has a large amount of data. You are advised to decrease the topic aging time based on the topic consumption so that historical data of the topic can be deleted in a timely manner to accelerate the migration.
Preparing for Partition Reassignment
- To reduce the amount of data to be migrated, decrease the topic aging time without affecting services and wait for messages to age. After the reassignment is complete, you can restore the aging time.
- Ensure that the target broker has sufficient disk capacity. If the remaining disk capacity of the target broker is close to the amount of data to be migrated to the broker, expand the disk capacity before the reassignment.
Auto Reassignment
- Click
in the upper left corner to select a region.
Select the region where your Kafka instance is located.
- Click
and choose Application > Distributed Message Service for Kafka to open the console of DMS for Kafka.
- Click the desired Kafka instance to view the instance details.
- In the navigation pane, choose the Topics tab.
- Reassign partitions using either of the following methods:
- Select one or more topics and choose Reassign > Auto above the topic list.
- In the row that contains the desired topic, choose More > Reassign > Auto.
- Set automatic reassignment parameters.
- In the Brokers area, select the brokers to assign the topic's partition replicas to.
- In the Topics area, enter the number of replicas to be automatically reassigned. The number of replicas must be less than or equal to the number of brokers.
- Specify throttle. The default value is -1, indicating that there is no throttle (recommended if the instance load is light). If a throttle is required, you are advised to set it to a value greater than or equal to the total production bandwidth of the to-be-reassigned topic multiplied by the maximum number of replicas of the to-be-reassigned topic. For details, see Calculating a Throttle.
Figure 1 Setting automatic reassignment parameters - Click OK. The topic list is displayed.
In the upper left corner of the topic list, click View details to view the reassignment task status on the Background Tasks page that is displayed. When the task status is Successful, reassignment has completed.
Manual Reassignment
- Click
- Click
- Select the desired topic and choose Reassign > Manual above the topic list.
- In the row that contains the desired topic, choose More > Reassign > Manual.
- Set manual reassignment parameters.
- In the upper right corner of the Manual dialog box, click Delete Replica or Add Replica to reduce or increase the number of replicas for each partition of the topic.
- Under the name of the replica to be reassigned, click the broker name or
and select the target broker to migrate the replica to. Assign replicas of the same partition to different brokers.
Figure 2 Setting manual reassignment parameters - Click OK. The topic list is displayed.
Throttles are affected by the execution duration of the reassignment, leader/follower distribution of partition replicas, and message production rate.
- A throttle limits the replication traffic of all partitions in a broker.
- Replicas added after the assignment are regarded as followers, and existing replicas are regarded as leaders. Throttles on leaders and followers are separated.
- Throttles do not distinguish between replication caused by normal message production and that caused by partition reassignment. Therefore, the traffic generated in both cases is throttled.
Assume that the partition reassignment task needs to be completed within 200s and each replica has 100 MB data. Calculate the throttle in the following scenarios:
Scenario 1: Topic 1 has two partitions and two replicas, and Topic 2 has one partition and one replica. All leader replicas are on the same broker. One replica needs to be added for Topic 1 and Topic 2 respectively.
Topic Name |
Partition Name |
Broker of Leader Replica |
Broker of Follower Replica |
Topic 1 |
0 |
0 |
0, 1 |
Topic 1 |
1 |
0 |
0, 2 |
Topic 2 |
0 |
0 |
0 |
Topic Name |
Partition Name |
Topic 1 |
0 |
0 |
0, 1, 2 |
Topic 1 |
1 |
0 |
0, 1, 2 |
Topic 2 |
0 |
0 |
0, 2 |
As shown in Figure 3, three replicas fetch data from Broker 0. Each replica on Broker 0 has 100 MB data. Broker 0 has only leader replicas, and Broker 1 and Broker 2 have only follower replicas.
- Bandwidth required by Broker 0 to complete partition reassignment within 200s = (100 MB + 100 MB + 100 MB)/200s = 1.5 MB/s
- Bandwidth required by Broker 1 to complete partition reassignment within 200s = 100 MB/200s = 0.5 MB/s
- Bandwidth required by Broker 2 to complete partition reassignment within 200s = (100 MB + 100 MB)/200s = 1 MB/s
In conclusion, to complete the partition reassignment task within 200s, set the throttle to a value greater than or equal to 1.5 MB/s.
Scenario 2: Topic 1 has two partitions and one replica, and Topic 2 has two partitions and one replica. Leader replicas are on different brokers. One replica needs to be added for Topic 1 and Topic 2 respectively.
Topic Name |
Partition Name |
Topic 1 |
0 |
0 |
0 |
Topic 1 |
1 |
1 |
1 |
Topic 2 |
0 |
1 |
1 |
Topic 2 |
1 |
2 |
2 |
Topic Name |
Partition Name |
Topic 1 |
0 |
0 |
0, 2 |
Topic 1 |
1 |
1 |
1, 2 |
Topic 2 |
0 |
1 |
1, 2 |
Topic 2 |
1 |
2 |
2, 0 |
As shown in Figure 4, Broker 1 has only leader replicas, and Broker 0 and Broker 2 have both leader and follower replicas. Leader and follower replicas on Broker 0 and Broker 2 are throttled separately.
- Bandwidth required by Broker 0 (leader) to complete partition reassignment within 200s = 100 MB/200s = 0.5 MB/s
- Bandwidth required by Broker 0 (follower) to complete partition reassignment within 200s = 100 MB/200s = 0.5 MB/s
- Bandwidth required by Broker 1 to complete partition reassignment within 200s = (100 MB + 100 MB)/200s = 1 MB/s
- Bandwidth required by Broker 2 (leader) to complete partition reassignment within 200s = 100 MB/200s = 0.5 MB/s
- Bandwidth required by Broker 2 (follower) to complete partition reassignment within 200s = (100 MB + 100 MB + 100 MB)/200s = 1.5 MB/s
Scenario 3: Both Topic 1 and Topic 2 have one partition and two replicas. All leader replicas are on the same broker. One replica needs to be added to Topic 1. Messages are produced on Topic 1, causing replication.
Topic Name |
Partition Name |
Topic 1 |
0 |
0 |
0, 1 |
Topic 2 |
0 |
0 |
0, 1 |
Topic Name |
Partition Name |
Topic 1 |
0 |
0 |
0, 1, 2 |
Topic 2 |
0 |
0 |
0, 1 |
As shown in Figure 5, one replica needs to fetch data from Broker 0 for partition reassignment, and the other replica needs to fetch data from Broker 0 for message production. Since the throttle does not distinguish between message production and partition reassignment, the traffic caused by both is limited and counted.
- Bandwidth required by Broker 0 to complete partition reassignment within 200s = (100 MB + 700 KB/s x 200s)/200s + 700 KB/s= 1.9 MB/s
- Bandwidth required by Broker 2 to complete partition reassignment within 200s = 100 MB/200s = 0.5 MB/s
In conclusion, to complete the partition reassignment task within 200s, set the throttle to a value greater than or equal to 1.9 MB/s.
