Resetting Kafka Manager Password
You can reset the password of Kafka Manager of a Kafka instance if you forget it.
You can reset the password of Kafka Manager only for a Kafka instance in the Running state.
A Kafka instance has been created.
- Click
in the upper left corner to select a region.
Select the region where your Kafka instance is located.
- Click
and choose Application > Distributed Message Service for Kafka to open the console of DMS for Kafka.
- Reset the Kafka Manager password using either of the following methods:
- In the row containing the desired Kafka instance, choose More > Reset Manager Password.
- Click the desired Kafka instance to view its details. In the upper right corner, choose More > Reset Manager Password.
- Click the desired Kafka instance to view its details. On the Basic Information tab page, click Reset Manager Password next to Manager Username in the Connection section.
- Enter and confirm a new password, and click OK.
- If the password is successfully reset, a success message is displayed.
- If the password fails to be reset, a failure message is displayed. Reset the password again. If you still fail to reset the password after multiple attempts, contact customer service.
The system will display a success message only after the password is successfully reset on all brokers.
