Modifying Kafka Parameters
Your Kafka instances, topics, and consumers come with default configuration parameter settings. You can modify common parameters on the Kafka console. For details about parameters that are not listed on the console, see the Kafka official website.
Parameters of v1.1.0 instances are all static parameters. v2.3.0/v2.7 instances have both dynamic and static parameters.
- Dynamic parameters: Modifying dynamic parameters will not restart the instance.
- Static parameters: After static parameters are modified, you must manually restart the instance.
Configuration parameters of some old instances cannot be modified. Check whether your instance parameters can be modified on the console. If they cannot be modified, contact customer service.
You can modify configuration parameters of a Kafka instance when the instance is in the Running state.
- Click
in the upper left corner to select a region.
Select the region where your Kafka instance is located.
- Click
and choose Application > Distributed Message Service for Kafka to open the console of DMS for Kafka.
- Click the desired Kafka instance to view the instance details.
- On the Parameters tab page, click Edit in the row containing the parameter to modify. The parameters of v1.1.0 instances are described in Table 1. The parameters of v2.3.0/v2.7 instances are described in Table 2 and Table 3.
Table 1 Static parameters (v1.1.0 instances) Parameter
Value Range
Default Value
min.insync.replicas
If a producer sets the acks parameter to all (or -1), the min.insync.replicas parameter specifies the minimum number of replicas that must acknowledge a write for the write to be considered successful.
1–3
message.max.bytes
Maximum length of a single message, in bytes.
0–10,485,760
10,485,760
unclean.leader.election.enable
Indicates whether to allow replicas not in the ISR set to be elected as the leader as a last resort, even though doing so may result in data loss.
true or false
true
connections.max.idle.ms
Idle connection timeout (in ms). Connections that are idle for the duration specified by this parameter will be closed.
5000–600,000
600,000
log.retention.hours
Duration (in hours) for retaining a log file.
This parameter takes effect only for topics that have no aging time configured. If there is aging time configured for topics, it overrides this parameter.
1–168
72
max.connections.per.ip
The maximum number of connections allowed from each IP address. Request for new connections will be rejected once the limit is reached.
100–20,000
1000
group.max.session.timeout.ms
The maximum session timeout (in ms) for consumers. A longer timeout gives consumers more time to process messages between heartbeats but results in a longer time to detect failures.
6000–1,800,000
1,800,000
default.replication.factor
The default number of replicas configured for an automatically created topic.
1–3
3
num.partitions
The default number of partitions configured for each automatically created topic.
1–100
3
group.min.session.timeout.ms
The minimum session timeout (in ms) for consumers. A shorter timeout enables quicker failure detection but results in more frequent consumer heartbeating, which can overwhelm broker resources.
6000–300,000
6000
Table 2 Dynamic parameters (v2.3.0/v2.7 instances) Parameter
Value Range
Default Value
min.insync.replicas
1–3
message.max.bytes
0–10,485,760
10,485,760
100–20,000
1000
true or false
true
Table 3 Static parameters (v2.3.0/v2.7 instances) Parameter
Value Range
Default Value
5000–600,000
600,000
log.retention.hours
1–168
72
6000–1,800,000
1,800,000
1–3
3
num.partitions
1–100
3
6000–300,000
6000
- To modify multiple dynamic or static parameters at a time, click Modify above the parameter list.
- If you want to restore the default values, click Restore Default in the row containing the desired parameter.
- Click Save.
Modifying dynamic parameters will not restart the instance. Static parameter modification requires manual restart of the instance.
