Permissions Management
You can use Identity and Access Management (IAM) to manage DMS for Kafka permissions and control access to your resources. IAM provides identity authentication, permissions management, and access control.
You can create IAM users for your employees, and assign permissions to these users on a principle of least privilege (PoLP) basis to control their access to specific resource types. For example, you can create IAM users for software developers and assign specific permissions to allow them to use Kafka instance resources but prevent them from being able to delete resources or perform any high-risk operations.
If your account does not require individual IAM users for permissions management, skip this section.
IAM can be used free of charge. You pay only for the resources in your account.
For more information, see IAM Service Overview.
Permissions policies of DMS for Kafka are based on DMS. Therefore, when assigning permissions, select DMS permissions policies.
DMS for Kafka Permissions
By default, new IAM users do not have any permissions assigned. To assign permissions to these new users, add them to one or more groups, and attach permissions policies or roles to these groups.
DMS for Kafka is a project-level service deployed and accessed in specific physical regions. When assigning DMS for Kafka permissions to a user group, specify region-specific projects where the permissions will take effect. If you select All projects, the permissions will be granted for all region-specific projects. When accessing DMS for Kafka, the users need to switch to a region where they have been authorized to use this service.
- Roles: A type of coarse-grained authorization mechanism that provides only a limited number of service-level roles. When using roles to grant permissions, you also need to assign dependency roles. However, roles are not an ideal choice for fine-grained authorization and secure access control.
- Policies: A type of fine-grained authorization mechanism that defines permissions required to perform operations on specific cloud resources under certain conditions. This mechanism allows for more flexible policy-based authorization for securer access control. For example, you can grant DMS for Kafka users only the permissions for managing instances. Most policies define permissions based on APIs. For the API actions supported by DMS for Kafka, see Permissions Policies and Supported Actions.
Table 1 lists all the system-defined roles and policies supported by DMS for Kafka.
| Role/Policy Name | Description | Type | Dependency |
| DMS FullAccess | Administrator permissions for DMS. Users granted these permissions can perform all operations on DMS. | System-defined policy | None |
| DMS UserAccess | Common user permissions for DMS, excluding permissions for creating, modifying, deleting, dumping, and scaling up instances. | System-defined policy | None |
| DMS ReadOnlyAccess | Read-only permissions for DMS. Users granted these permissions can only view DMS data. | System-defined policy | None |
| DMS VPCAccess | VPC operation permissions to assign to DMS agencies. | System-defined policy | None |
| DMS KMSAccess | KMS operation permissions to assign to DMS agencies. | System-defined policy | None |
| DMS Administrator | Administrator permissions for DMS. | System-defined role | This role depends on the Tenant Guest and VPC Administrator roles. |
System-defined policies contain OBS actions. Due to data caching, the policies take effect five minutes after they are attached to a user, user group, or enterprise project.
Table 2 lists the common operations supported by each DMS for Kafka system policy. Select the policies as required.
| Operation | DMS FullAccess | DMS UserAccess | DMS ReadOnlyAccess |
| Creating instances | √ | × | × |
| Modifying instances | √ | × | × |
| Deleting instances | √ | × | × |
| Modifying instance specifications | √ | × | × |
| Enabling Smart Connect | √ | × | × |
| Creating a Smart Connect task | √ | √ | × |
| Restarting instances | √ | √ | × |
| Querying instance information | √ | √ | √ |
Fine-grained Authorization
To use a custom fine-grained policy, log in to the IAM console as an administrator and select the desired fine-grained permissions for DMS. Table 3 describes fine-grained permission dependencies of DMS for Kafka.
| Permission | Description | Dependency |
| dms:instance:get | Viewing instance details | None |
| dms:instance:getConnectorSinkTask | Viewing dumping task details | None |
| dms:instance:getBackgroundTask | Viewing background task details | None |
| dms:instance:modifyAuthInfo | Changing an instance password | None |
| dms:instance:resetAuthInfo | Resetting an instance password | None |
| dms:instance:scale | Scaling up an instance |
| dms:instance:connector | Enabling dumping |
| dms:instance:deleteConnectorSinkTask | Deleting a dumping task | None |
| dms:instance:modify | Modifying an instance |
| dms:instance:deleteBackgroundTask | Deleting a background task | None |
| dms:instance:modifyStatus | Restarting an instance | None |
| dms:instance:createConnectorSinkTask | Creating a dumping task | None |
| dms:instance:delete | Deleting an instance | None |
| dms:instance:create | Creating an instance |
| dms:instance:listConnectorSinkTask | Viewing the dumping task list | None |
| dms:instance:list | Viewing the instance list | None |
