- What's New
- Function Overview
- Product Bulletin
- Technology Poster
- Billing
- Getting Started
User Guide
- Using IAM to Grant Access to HSS
- Accessing HSS
- Checking the Dashboard
- Asset Management
- Risk Management
- Server Protection
Container Protection
Container Firewalls
- Container Firewall Overview
- Configuring a Network Defense Policy (for a Cluster Using the Container Tunnel Network Model)
- Configuring a Network Defense Policy (for a Cluster Using the VPC Tunnel Network Model)
- Configuring a Network Defense Policy (for a Cluster Using the Cloud Native Network 2.0 Model)
- Container Cluster Protection
Container Firewalls
- Detection and Response
- Security Operations
- Installation and Configuration on Servers
- Installation and Configuration on Containers
- Account Management
- Plug-in Settings
- Authorization
- Monitoring and Auditing
- Enterprise Project Management
Best Practices
- HSS Best Practices You May Need
Suggestions on How to Fix Official Disclosed Vulnerabilities Provided by HSS
- Git Credential Disclosure Vulnerability (CVE-2020-5260)
- SaltStack Remote Command Execution Vulnerabilities (CVE-2020-11651 and CVE-2020-11652)
- OpenSSL High-risk Vulnerability (CVE-2020-1967)
- Adobe Font Manager Library Remote Code Execution Vulnerability (CVE-2020-1020/CVE-2020-0938)
- Windows Kernel Elevation of Privilege Vulnerability (CVE-2020-1027)
- Windows CryptoAPI Spoofing Vulnerability (CVE-2020-0601)
- Third-Party Servers Accessing HSS Through a Direct Connect and Proxy Servers
- Connecting Third-Party Servers to HSS Through Direct Connect and VPC Endpoint
- Installing the HSS Agent Using CBH
- Using HSS to Improve Server Login Security
- Using HSS and CBR to Defend Against Ransomware
- Using HSS to Scan and Fix Vulnerabilities
- Using HSS to Prevent Weak Passwords
- Using HSS to Scan for Trojans
- Using HSS to Handle Mining Attacks
- Using HSS to Monitor the Integrity of Linux Server Files
- Whitelist Can Be Used to Avoid False Alarm Reporting
API Reference
- Before You Start
- Calling APIs
API Description
Asset Management
- Collecting Asset Statistics, Including Accounts, Ports, and Processes
- Querying the Account List
- Querying Open Port Statistics
- Querying the Process List
- Querying the Software List
- Querying Automatic Startup Item Information
- Querying the Server List of an Account
- Querying the Open Port List of a Single Server
- Querying the Server List of the Software
- Querying the Service List of Auto-Started Items
- Obtaining the Account Change History
- Obtaining the Historical Change Records of Software Information
- Obtaining the Historical Change Records of Auto-started Items
- Asset Fingerprints - Process - Server List
- Asset Fingerprints - Port - Server List
- Querying the Middleware List
- Querying the Server List of a Specified Middleware
Ransomware Prevention
- Querying the Servers Protected Against Ransomware
- Querying the Protection Policy List of Ransomware
- Modifying Ransomware Protection Policies
- Enabling Ransomware Prevention
- Disabling Ransomware Prevention
- Querying the Backup Policy Bound to HSS Protection Vault
- Modifying the Backup Policy Bound to Vault
Baseline Management
- Querying the Weak Password Detection Result List
- Querying the Password Complexity Policy Detection Report
- Querying the Result List of Server Security Configuration Check
- Querying the Check Result of a Security Configuration Item
- Querying the Checklist of a Security Configuration Item
- Querying the List of Affected Servers of a Security Configuration Item
- Querying the Report of a Check Item in a Security Configuration Check
- Ignoring, Unignoring, Repairing, or Verifying the Failed Configuration Check Items
- Quota Management
- Container Management
- Event Management
- Intrusion Detection
- Server Management
Container Image
- Querying the Image List in the SWR Image Repository
- Scanning Images in the Image Repository in Batches
- Querying the Local Image List
- Querying Image Vulnerability Information
- CVE Information Corresponding to the Vulnerability
- Synchronizing the Image List from SWR
- Querying the List of Image Security Configuration Detection Results
- Querying the Check Item List of a Specified Security Configuration Item of an Image
- Querying the Mirror Configuration Check Report
- Policy Management
Vulnerability Management
- Querying the Vulnerability List
- Exporting Information About Vulnerabilities and Their Affected Servers
- Querying the Servers Affected by a Vulnerability
- Changing the Status of a Vulnerability
- Querying Vulnerability Information About a Server
- Creating a Vulnerability Scan Task
- Querying a Vulnerability Scan Policy
- Modifying a Vulnerability Scan Policy
- Querying the Vulnerability Scan Tasks
- Querying the List of Servers Corresponding to a Vulnerability Scan Task
- Querying Vulnerability Management Statistics
- Web Tamper Protection
- Tag Management
- Cluster Management
Asset Management
- Appendixes
- SDK Reference
About HSS
- What Is Host Security?
- What Is Container Security?
- What Is Web Tamper Protection?
- What Are the Relationships Between Images, Containers, and Applications?
- How Do I Use HSS?
- Can HSS Protect Local IDC Servers?
- Is HSS in Conflict with Any Other Security Software?
- What Are the Differences Between HSS and WAF?
- Can HSS Be Used Across Accounts?
- What Is the HSS Agent?
- Can HSS Be Used Across Clouds?
- Does HSS Support Version Upgrade?
- Can HSS Automatically Detect and Remove Viruses?
Agent
- Do I Need to Install the HSS Agent After Purchasing HSS?
- Is the Agent in Conflict with Any Other Security Software?
- How Do I Uninstall the Agent?
- What Should I Do If Agent Installation Failed?
- How Do I Fix an Abnormal Agent?
- What Is the Default Agent Installation Path?
- How Many CPU and Memory Resources Are Occupied by the Agent When It Performs Scans?
- Do Different HSS Editions Share the Same Agent?
- How Do I View Servers Where No Agents Have Been Installed?
- How Do I Upgrade the Agent?
- What Do I Do If the HSS Upgrade Fails?
- What Resources Will Be Accessed by the Agent After It Is Installed on a Server?
- How Do I Use Images to Install Agents in Batches?
- What Do I Do If I Cannot Access the Download Link of the Windows Or Linux Agent?
- What Do I Do If Agent Upgrade Fails and the Message "File replacement failed" Is Displayed?
- What Can I Do If Agents Failed to Be Installed in Batches and a Message Is Displayed Indicating that the Network Is Disconnected?
- How Do I Verify the Connection Between My Server and the HSS Server?
- Protection
- How Do I Fix Vulnerabilities?
- What Do I Do If an Alarm Still Exists After I Fixed a Vulnerability?
- Why a Server Displayed in Vulnerability Information Does Not Exist?
- Do I Need to Restart a Server After Its Vulnerabilities Are Fixed?
- Can I Check the Vulnerability and Baseline Fix History on HSS?
- What Do I Do If Vulnerability Fix Failed?
- Why Can't I Select a Server During Manual Vulnerability Scanning or Batch Vulnerability Fixing?
- What Do I Do If a Vulnerability Scan Failed?
- Do I Need to Subscribe to Ubuntu Pro to Fix Ubuntu Vulnerabilities?
Detection & Response
- How Do I View and Handle HSS Alarm Notifications?
- What Do I Do If My Servers Are Subjected to a Mining Attack?
- Why a Process Is Still Isolated After It Was Whitelisted?
- Why an Attack Is Not Detected by HSS?
- Can I Unblock an IP Address Blocked by HSS, and How?
- Why a Blocked IP Address Is Automatically Unblocked?
- How Often Is Malware Scan and Removal?
- How Often Are the HSS Virus Database and Vulnerability Database Updated?
- What Do I Do If an IP Address Is Blocked by HSS?
- How Do I Defend Against Ransomware Attacks?
- Why Can't I Receive Alarms After the HSS Is Upgraded?
- How Do I Add High-risk Command Execution Alarms to the Whitelist?
- Why Doesn't HSS Generate Alarms for Some Web Shell Files?
- Abnormal Logins
Brute-force Attack Defense
- How Does HSS Intercept Brute Force Attacks?
- How Do I Handle a Brute-force Attack Alarm?
- How Do I Defend Against Brute-force Attacks?
- How Do I Unblock an IP Address?
- What Do I Do If HSS Frequently Reports Brute-force Alarms?
- What Do I Do If a Huawei Cloud IP Address Trigger a Brute-force Attack Alarm?
- What Do I Do If the Port in Brute-force Attack Records Is Not Updated?
Baseline Inspection
- Why Are Weak Password Alarms Generated After the Weak Password Detection Policy Is Disabled?
- How Do I Install a PAM and Set a Proper Password Complexity Policy in a Linux OS?
- How Do I Set a Proper Password Complexity Policy in a Windows OS?
- How Do I Handle Unsafe Configurations?
- How Do I View Configuration Check Reports?
- How Do I Handle a Weak Password Alarm?
- How Do I Set a Secure Password?
- Why Do I Need to Add a Protected Directory?
- How Do I Modify a Protected Directory?
- What Should I Do If WTP Cannot Be Enabled?
- How Do I Modify a File After WTP Is Enabled?
- What Can I Do If I Enabled Dynamic WTP But Its Status Is Enabled but not in effect?
- What Are the Differences Between the Web Tamper Protection Functions of HSS and WAF?
Container Security
- How Do I Disable Node Protection?
- How Do I Switch from CGS to HSS?
- How Do I Enable Node Protection?
- How Do I Enable the API Server Audit for an On-Premises Kubernetes Container?
- What Do I Do If the Container Cluster Protection Plug-in Fails to Be Uninstalled?
- What Do I Do If the Cluster Connection Component (ANP-Agent) Failed to Be Deployed?
- What Do I Do If Cluster Permissions Are Abnormal?
- Failed to Upload the Image to the Private Image Repository
- What Do I Do If I Failed to Enable Protection for a CCE Cluster?
- Ransomware Prevention
- Region and AZ
Security Configurations
- How Do I Clear the SSH Login IP Address Whitelist Configured in HSS?
- What Can I Do If I Cannot Remotely Log In to a Server via SSH?
- How Do I Use 2FA?
- What Do I Do If I Cannot Enable 2FA?
- Why Can't I Receive a Verification Code After 2FA Is Enabled?
- Why Does My Login Fail After I Enable 2FA?
- How Do I Add a Mobile Number or Email Address for 2FA?
- Do I Use a Fixed Verification Code for 2FA?
- Will I Be Billed for Alarm Notifications and SMS?
- How Do I Modify Alarm Notification Recipients?
- Why No Topics Are Available for Me to Choose When I Configure Alarm Notifications?
- Can I Disable HSS Alarm Notifications?
- How Do I Modify Alarm Notification Items?
- How Do I Disable the SELinux Firewall?
Protection Quota
- How Do I Extend the Validity Period of HSS Quotas?
- How Do I Filter Unprotected Servers?
- Why Can't I Find the Servers I Purchased on the Console?
- What Do I Do If My Quotas Are Insufficient and I Failed to Enable Protection?
- How Do I Allocate My Quota?
- If I Change the OS of a Protected Server, Does It Affect My HSS Quota?
- Why Doesn't an HSS Edition Take Effect After Purchase?
- How Do I Change the Protection Quota Edition Bound to a Server?
- Can I Bind a Server to an HSS Quota If They Are in Different Enterprise Projects?
- Billing, Renewal, and Unsubscription
- How Do I Use the Windows Remote Desktop Connection Tool to Connect to a Windows Server?
- How Do I Check HSS Log Files?
- How Do I Enable Logging for Login Failures?
- How Do I Clear an Alarm on Critical File Changes?
- Why Can't I View All Projects in the Enterprise Project Drop-down List?
- How Do I Enable or Disable HSS Self-protection?
- What Do I Do If Windows Self-Protection Cannot Be Disabled?
- Why Is a Deleted ECS Still Displayed in the HSS Server List?
About HSS
- Videos
More Documents
User Guide (Ankara Region)
- Introduction
- Enabling HSS
- Server Security Dashboard
- Asset Management
- Risk Prevention
- Prevention
- Security Report
- Installation & Configuration
- Permissions Management
About HSS
- What Is HSS?
- What Is Container Security Service?
- How Do I Use HSS?
Agent FAQs
- How Do I Install the Agent?
- Do WTP and HSS Use the Same Agent?
- How Do I Do If the Account Cracking Prevention Function Does Not Take Effect on Some Linux Accounts?
- What Do I Do If My Remote Server Port Is Not Updated in Brute-force Attack Records?
- Weak Passwords and Unsafe Accounts
Intrusions
- What Do I Do If a Mining Process Is Detected on a Server?
- Why Some Attacks on Servers Are Not Detected?
- How Often Does HSS Detect, Isolate, and Kill Malicious Programs?
- Abnormal Logins
- Unsafe Settings
- Vulnerability Management
- Container Guard Service
- Ransomware Protection
- How Do I Use 2FA?
- How Do I Add a Mobile Phone Number or Email Address for Receiving 2FA Verification Notifications?
- If I Choose to Use Verification Code for 2FA, How Do I Get the Code?
- Quotas
- How Do I Use the Windows Remote Desktop Connection Tool to Connect to a Server?
- Is HSS Available as Offline Software?
- How Do I Enable HSS Self-Protection?
- What Do I Do If HSS Self-Protection Cannot Be Disabled?
About HSS
- Change History
- Introduction
- Enabling HSS
- Asset Management
- Risk Prevention
Prevention
- Application Protection
- WTP
- File Integrity Monitoring
Container Firewalls
- Creating a Policy (for a Cluster Using the Container Tunnel Network Model)
- Creating a Policy (for a Cluster Using the VPC Network Model)
- Managing Policies (for a Cluster Using the Container Tunnel Network Model)
- Managing Policies (for a Cluster Using the VPC Network Model)
- Security Report
- Audit
- Manually Upgrading HSS
- About HSS
Agent FAQs
- What Can I Do If the Agent Status Is Still "Not installed" After Installation?
- What Do I Do If the Account Cracking Prevention Function Does Not Take Effect on Some Accounts for Linux Servers?
Intrusions
- Abnormal Logins
- Unsafe Settings
- How Do I Use 2FA?
- Others
- Change History
User Guide (Paris)
- Introduction
- Enabling HSS
Asset Management
- Asset Management
- Server Fingerprints
- Container Fingerprints
- Server Management
- Risk Prevention
Prevention
- WTP
Container Firewalls
- Security Report
- Audit
- About HSS
Agent FAQs
- What Addresses Do ECSs Access After the Agent Is Installed?
Intrusions
- Abnormal Logins
- Unsafe Settings
- Do I Need to Restart a Server After Fixing its Vulnerabilities?
- How Do I Use 2FA?
- Change History
On this page
Show all
Help Center/
Host Security Service/
User Guide (ME-Abu Dhabi Region)/
Prevention/
Container Firewalls
Container Firewalls
Parent topic: Prevention
