On this page
Upgrading a Plug-in
Updated on 2024-07-12 GMT+08:00
You can upgrade plug-ins of a target server.
  • Only Docker containers are supported. Containerd containers are not supported.
  • The Docker engine version is 18.06.0 or later.
  • The Docker API version is 1.38 or later.
  • Only Linux servers are supported.
  • Only the x86 and Arm hardware architectures are supported.
  • The HSS container edition has been enabled.
  2. Click in the upper left corner of the page, select a region, and choose Security > Host Security Service.
  3. In the navigation tree on the left, choose Installation & Configuration and click the Plug-in Settings > Docker plug-in tab. Click Plug-in upgrade guide, obtain the upgrade commands from the slide-out panel, and click Copy.
  4. Remotely log in to the server where the plug-in is to be upgraded as the root user.
    • If your server has an EIP bound, you can also use a remote management tool, such as PuTTY or Xshell, to log in to the server and upgrade the plug-in on the server as user root.
  5. Run the following command to access the /tmp directory:
    cd /tmp/
  6. Create linux-host-list.txt, which will contain the server private IP addresses where the plug-in is to be upgraded:
    Command syntax:
    echo 127.8.8.8 22 root rootPassword >> linux-host-list.txt
    Or echo 127.8.8.8 22 user userPassword rootPassword >> linux-host-list.txt
    To specify multiple IP addresses, write multiple commands, each in a separate line.
    Example:
    echo 127.8.8.1 22 root rootPassword >> linux-host-list.txt
    echo 127.8.8.2 22 user userPassword rootPassword >> linux-host-list.txt
    echo 127.8.8.3 22 root rootPassword >> linux-host-list.txt
  7. Press Enter to save the IP address. Run the cat linux-host-list.txt command to verify the IP addresses have been added.
  8. Copy the batch upgrade commands to the command box and press Enter. The upgrade starts automatically.
  9. If remote_upgrade finished. [OK] is displayed, the upgrade is successful. Wait for 3 to 5 minutes and choose Installation & Configuration and click the Plug-in Settings tab to check the Docker plug-in status of the panel server.
