How to Switch from CGS to HSS Console?
Updated on 2024-07-12 GMT+08:00
You can integrate CGS into the HSS console to centrally manage servers and use the new functions.
Functions of the New and Old CGS
Currently, CGS has been integrated into the HSS console for unified management. The existing functions have been optimized and some new functions have been added.
Table 1 Functions of the new and old CGS
Function
Old CGS
New CGS (New HSS)
Container asset fingerprint management
Container node management
Private image management
Local image management
Official image management
Shared image management
Image vulnerability detection
Malicious image file detection
Image baseline check
Vulnerability escape detection
File escape detection
Abnormal container process detection
Abnormal container configuration detection
Abnormal container startup detection
Malicious container program detection
High-risk system call detection
Sensitive file access detection
Container software information check
Container file information check
Whitelist management
Container policy management
Switchover Process
To switch from CGS to HSS, disable CGS, apply for the HSS container edition, and enable protection.
Step 1: Disabling the Original CGS Protection.
  2. In the upper left corner of the page, select a region, click , and choose Security & Compliance > Container Guard Service. The Container Guard Service console is displayed.
  3. Choose Clusters & Quotas under Container Guard Service to view the cluster protection list.
  4. Click Disable Protection in the Operation column of the target cluster.
    For easy management, you are advised to disable protection for all clusters.
Step 2: Installing an Agent
CGS (old) and HSS (new) are independent of each other. To use the HSS container edition, install a new agent.
  2. Click in the upper left corner of the page, select a region, and choose Security > Host Security Service.
  3. In the navigation pane, choose Asset Management > Containers & Quota.
  4. Click Nodes to check whether the nodes whose protection has been disabled exist in the node list.
    NOTICE:
    • If the nodes are displayed on the HSS console (new), you do not need to install the agent.
    • If the nodes are not displayed on the HSS console (new), you need to .
Step 3: Enabling Protection
  4. In the Operation column of the node list, click Enable Protection.
  5. Click OK. If the Protection Status of the server changes to Protected, protection has been enabled.
    A CGS quota protects one cluster node.
