Enterprise/Premium Edition
Updated on 2024-07-12 GMT+08:00
The basic, professional, enterprise, and premium editions provide different levels of protection for your servers. You can and enable them as needed.
Check Frequency
HSS performs a full scan in the early morning every day.
After you enable server protection, you can view scan results after the automatic scan in the next early morning, or perform a manual scan immediately.
Prerequisite
The agent has been installed on the servers to be protected, the agent status is Online, and the protection status is Unprotected.
  • Linux
    On servers running the EulerOS with ARM, HSS does not block the IP addresses suspected of SSH brute-force attacks, but only generates alarms.
  • Windows
    • Authorize the Windows firewall when you enable protection for a Windows server. Do not disable the Windows firewall during the HSS in-service period. If the Windows firewall is disabled, HSS cannot block brute-force attack IP addresses.
    • If the Windows firewall is manually enabled, HSS may also fail to block brute-force attack IP addresses.
  2. Click in the upper left corner of the page, select a region, and choose Security > Host Security Service.
  3. In the navigation pane, choose Asset Management > Servers & Quota. Click the Servers tab.
  4. Enable protection for one or multiple servers.
    • Enabling protection for a server
      Click Enable in the Operation column of a server. In the dialog box that is displayed, confirm the server information.
      Table 1 Protection parameters
      Example Value
      Edition
      Select the enterprise or premium edition.
      • Enterprise edition: It provides support for the DJCP MLPS certification. Main features include asset fingerprint management, vulnerability management, malicious program detection, web shell detection, and abnormal process behavior detection.
      • Premium edition: It helps you with the DJCP MLPS certification and provides advanced features, including application protection, ransomware prevention, high-risk command detection, privilege escalation detection, and abnormal shell detection.
      Enterprise
    • Enabling protection in batches
      Select multiple servers and click Enable above the server list. In the dialog box that is displayed, confirm the server information.
      Table 2 Protection parameters
      Example Value
      Edition
      Enterprise
  5. Confirm the information and click OK. If the protection status of the target servers is Protected, the protection has been enabled.
