Managing Protection Policies
Updated on 2024-07-12 GMT+08:00
NOTICE:
Currently, you can create a ransomware prevention policy only when enabling ransomware prevention.
Only premium, WTP, and container editions support ransomware protection.
Creating a Policy
  2. Click in the upper left corner of the page, select a region, and choose Security > Host Security Service.
  3. In the navigation pane, choose Prevention > Ransomware Prevention. Click the Protected Servers tab. Click Add Server.
  4. In the slide pane that is displayed, select Linux or Windows, enable protection, and select Create new. For more information, see Table 1.
    The following uses a Linux server as an example.
    Table 1 Protection policy parameters
    Example Value
    Policy
    Policy name
    test
    Action
    Indicates how an event is handled.
    • Report alarm and isolate
    • Report alarm
    Bait File
    After bait protection is enabled, the system deploys bait files in protected directories and key directories (unless otherwise specified by users). A bait file occupies only a few resources and does not affect your server performance.
    If ransomware prevention is enabled, this function is enabled by default.
    Currently, Linux servers support dynamic generation and deployment of bait files. Windows servers support only static deployment of bait files.
    Enabled
    Bait File Directories
    Protected directories (excluding subdirectories).
    Separate multiple directories with semicolons (;). You can configure up to 20 directories.
    This parameter is mandatory for Linux servers and optional for Windows servers.
    Linux: /etc/lesuo
    Windows: C:\Test
    Excluded Directory (Optional)
    Directories where bait files are not deployed.
    Separate multiple directories with semicolons (;). You can configure up to 20 excluded directories.
    Linux: /test
    Windows: C:\ProData
    Protected File Type
    Types of files to be protected.
    More than 70 file formats can be protected, including databases, containers, code, certificate keys, and backups.
    This parameter is mandatory for Linux servers only.
    Select all
  5. Click Next and select servers. You can search for a server by its name or by filtering.
  6. Click OK to enable ransomware protection and create the policy.
  7. In the navigation pane, choose Prevention > Ransomware Prevention. Click the Policies tab and check the new policy.
Modifying a Policy
  1. Log in to the management console and go to the HSS page.
  2. In the navigation pane, choose Prevention > Ransomware Prevention. Click the Policies tab.
  3. Click Edit in the Operation column of a policy. Edit the policy configurations and associated servers. For more information, see Protection policy parameters.
    The following uses a Linux server as an example. On the Protected Servers tab, you can also click the name of the policy associated with the server to edit the policy.
    Table 2 Protection policy parameters
    Example Value
    Policy
    Policy name
    test
    Action
    • Report alarm
    Bait File
    Enabled
    Linux: /etc/lesuo
    Windows: C:\Test
    Linux: /test
    Windows: C:\ProData
    Protected File Type
    Select all
  4. Confirm the policy information and click OK.
Deleting a Policy
  3. Click Delete in the Operation column of the target policy.
    After a policy is deleted, the associated servers are no longer protected. Before deleting a policy, you are advised to bind its associated servers to other policies.
