- What's New
- Function Overview
- Product Bulletin
- Technology Poster
- Billing
- Getting Started
User Guide
- Using IAM to Grant Access to HSS
- Accessing HSS
- Checking the Dashboard
- Asset Management
- Risk Management
- Server Protection
Container Protection
Container Firewalls
- Container Firewall Overview
- Configuring a Network Defense Policy (for a Cluster Using the Container Tunnel Network Model)
- Configuring a Network Defense Policy (for a Cluster Using the VPC Tunnel Network Model)
- Configuring a Network Defense Policy (for a Cluster Using the Cloud Native Network 2.0 Model)
- Container Cluster Protection
Container Firewalls
- Detection and Response
- Security Operations
- Installation and Configuration on Servers
- Installation and Configuration on Containers
- Account Management
- Plug-in Settings
- Authorization
- Monitoring and Auditing
- Enterprise Project Management
Best Practices
- HSS Best Practices You May Need
Suggestions on How to Fix Official Disclosed Vulnerabilities Provided by HSS
- Git Credential Disclosure Vulnerability (CVE-2020-5260)
- SaltStack Remote Command Execution Vulnerabilities (CVE-2020-11651 and CVE-2020-11652)
- OpenSSL High-risk Vulnerability (CVE-2020-1967)
- Adobe Font Manager Library Remote Code Execution Vulnerability (CVE-2020-1020/CVE-2020-0938)
- Windows Kernel Elevation of Privilege Vulnerability (CVE-2020-1027)
- Windows CryptoAPI Spoofing Vulnerability (CVE-2020-0601)
- Third-Party Servers Accessing HSS Through a Direct Connect and Proxy Servers
- Connecting Third-Party Servers to HSS Through Direct Connect and VPC Endpoint
- Installing the HSS Agent Using CBH
- Using HSS to Improve Server Login Security
- Using HSS and CBR to Defend Against Ransomware
- Using HSS to Scan and Fix Vulnerabilities
- Using HSS to Prevent Weak Passwords
- Using HSS to Scan for Trojans
- Using HSS to Handle Mining Attacks
- Using HSS to Monitor the Integrity of Linux Server Files
- Whitelist Can Be Used to Avoid False Alarm Reporting
API Reference
- Before You Start
- Calling APIs
API Description
Asset Management
- Collecting Asset Statistics, Including Accounts, Ports, and Processes
- Querying the Account List
- Querying Open Port Statistics
- Querying the Process List
- Querying the Software List
- Querying Automatic Startup Item Information
- Querying the Server List of an Account
- Querying the Open Port List of a Single Server
- Querying the Server List of the Software
- Querying the Service List of Auto-Started Items
- Obtaining the Account Change History
- Obtaining the Historical Change Records of Software Information
- Obtaining the Historical Change Records of Auto-started Items
- Asset Fingerprints - Process - Server List
- Asset Fingerprints - Port - Server List
- Querying the Middleware List
- Querying the Server List of a Specified Middleware
Ransomware Prevention
- Querying the Servers Protected Against Ransomware
- Querying the Protection Policy List of Ransomware
- Modifying Ransomware Protection Policies
- Enabling Ransomware Prevention
- Disabling Ransomware Prevention
- Querying the Backup Policy Bound to HSS Protection Vault
- Modifying the Backup Policy Bound to Vault
Baseline Management
- Querying the Weak Password Detection Result List
- Querying the Password Complexity Policy Detection Report
- Querying the Result List of Server Security Configuration Check
- Querying the Check Result of a Security Configuration Item
- Querying the Checklist of a Security Configuration Item
- Querying the List of Affected Servers of a Security Configuration Item
- Querying the Report of a Check Item in a Security Configuration Check
- Ignoring, Unignoring, Repairing, or Verifying the Failed Configuration Check Items
- Quota Management
- Container Management
- Event Management
- Intrusion Detection
- Server Management
Container Image
- Querying the Image List in the SWR Image Repository
- Scanning Images in the Image Repository in Batches
- Querying the Local Image List
- Querying Image Vulnerability Information
- CVE Information Corresponding to the Vulnerability
- Synchronizing the Image List from SWR
- Querying the List of Image Security Configuration Detection Results
- Querying the Check Item List of a Specified Security Configuration Item of an Image
- Querying the Mirror Configuration Check Report
- Policy Management
Vulnerability Management
- Querying the Vulnerability List
- Exporting Information About Vulnerabilities and Their Affected Servers
- Querying the Servers Affected by a Vulnerability
- Changing the Status of a Vulnerability
- Querying Vulnerability Information About a Server
- Creating a Vulnerability Scan Task
- Querying a Vulnerability Scan Policy
- Modifying a Vulnerability Scan Policy
- Querying the Vulnerability Scan Tasks
- Querying the List of Servers Corresponding to a Vulnerability Scan Task
- Querying Vulnerability Management Statistics
- Web Tamper Protection
- Tag Management
- Cluster Management
Asset Management
- Appendixes
- SDK Reference
About HSS
- What Is Host Security?
- What Is Container Security?
- What Is Web Tamper Protection?
- What Are the Relationships Between Images, Containers, and Applications?
- How Do I Use HSS?
- Can HSS Protect Local IDC Servers?
- Is HSS in Conflict with Any Other Security Software?
- What Are the Differences Between HSS and WAF?
- Can HSS Be Used Across Accounts?
- What Is the HSS Agent?
- Can HSS Be Used Across Clouds?
- Does HSS Support Version Upgrade?
- Can HSS Automatically Detect and Remove Viruses?
Agent
- Do I Need to Install the HSS Agent After Purchasing HSS?
- Is the Agent in Conflict with Any Other Security Software?
- How Do I Uninstall the Agent?
- What Should I Do If Agent Installation Failed?
- How Do I Fix an Abnormal Agent?
- What Is the Default Agent Installation Path?
- How Many CPU and Memory Resources Are Occupied by the Agent When It Performs Scans?
- Do Different HSS Editions Share the Same Agent?
- How Do I View Servers Where No Agents Have Been Installed?
- How Do I Upgrade the Agent?
- What Do I Do If the HSS Upgrade Fails?
- What Resources Will Be Accessed by the Agent After It Is Installed on a Server?
- How Do I Use Images to Install Agents in Batches?
- What Do I Do If I Cannot Access the Download Link of the Windows Or Linux Agent?
- What Do I Do If Agent Upgrade Fails and the Message "File replacement failed" Is Displayed?
- What Can I Do If Agents Failed to Be Installed in Batches and a Message Is Displayed Indicating that the Network Is Disconnected?
- How Do I Verify the Connection Between My Server and the HSS Server?
- Protection
- How Do I Fix Vulnerabilities?
- What Do I Do If an Alarm Still Exists After I Fixed a Vulnerability?
- Why a Server Displayed in Vulnerability Information Does Not Exist?
- Do I Need to Restart a Server After Its Vulnerabilities Are Fixed?
- Can I Check the Vulnerability and Baseline Fix History on HSS?
- What Do I Do If Vulnerability Fix Failed?
- Why Can't I Select a Server During Manual Vulnerability Scanning or Batch Vulnerability Fixing?
- What Do I Do If a Vulnerability Scan Failed?
- Do I Need to Subscribe to Ubuntu Pro to Fix Ubuntu Vulnerabilities?
Detection & Response
- How Do I View and Handle HSS Alarm Notifications?
- What Do I Do If My Servers Are Subjected to a Mining Attack?
- Why a Process Is Still Isolated After It Was Whitelisted?
- Why an Attack Is Not Detected by HSS?
- Can I Unblock an IP Address Blocked by HSS, and How?
- Why a Blocked IP Address Is Automatically Unblocked?
- How Often Is Malware Scan and Removal?
- How Often Are the HSS Virus Database and Vulnerability Database Updated?
- What Do I Do If an IP Address Is Blocked by HSS?
- How Do I Defend Against Ransomware Attacks?
- Why Can't I Receive Alarms After the HSS Is Upgraded?
- How Do I Add High-risk Command Execution Alarms to the Whitelist?
- Why Doesn't HSS Generate Alarms for Some Web Shell Files?
- Abnormal Logins
Brute-force Attack Defense
- How Does HSS Intercept Brute Force Attacks?
- How Do I Handle a Brute-force Attack Alarm?
- How Do I Defend Against Brute-force Attacks?
- How Do I Unblock an IP Address?
- What Do I Do If HSS Frequently Reports Brute-force Alarms?
- What Do I Do If a Huawei Cloud IP Address Trigger a Brute-force Attack Alarm?
- What Do I Do If the Port in Brute-force Attack Records Is Not Updated?
Baseline Inspection
- Why Are Weak Password Alarms Generated After the Weak Password Detection Policy Is Disabled?
- How Do I Install a PAM and Set a Proper Password Complexity Policy in a Linux OS?
- How Do I Set a Proper Password Complexity Policy in a Windows OS?
- How Do I Handle Unsafe Configurations?
- How Do I View Configuration Check Reports?
- How Do I Handle a Weak Password Alarm?
- How Do I Set a Secure Password?
- Why Do I Need to Add a Protected Directory?
- How Do I Modify a Protected Directory?
- What Should I Do If WTP Cannot Be Enabled?
- How Do I Modify a File After WTP Is Enabled?
- What Can I Do If I Enabled Dynamic WTP But Its Status Is Enabled but not in effect?
- What Are the Differences Between the Web Tamper Protection Functions of HSS and WAF?
Container Security
- How Do I Disable Node Protection?
- How Do I Switch from CGS to HSS?
- How Do I Enable Node Protection?
- How Do I Enable the API Server Audit for an On-Premises Kubernetes Container?
- What Do I Do If the Container Cluster Protection Plug-in Fails to Be Uninstalled?
- What Do I Do If the Cluster Connection Component (ANP-Agent) Failed to Be Deployed?
- What Do I Do If Cluster Permissions Are Abnormal?
- Failed to Upload the Image to the Private Image Repository
- What Do I Do If I Failed to Enable Protection for a CCE Cluster?
- Ransomware Prevention
- Region and AZ
Security Configurations
- How Do I Clear the SSH Login IP Address Whitelist Configured in HSS?
- What Can I Do If I Cannot Remotely Log In to a Server via SSH?
- How Do I Use 2FA?
- What Do I Do If I Cannot Enable 2FA?
- Why Can't I Receive a Verification Code After 2FA Is Enabled?
- Why Does My Login Fail After I Enable 2FA?
- How Do I Add a Mobile Number or Email Address for 2FA?
- Do I Use a Fixed Verification Code for 2FA?
- Will I Be Billed for Alarm Notifications and SMS?
- How Do I Modify Alarm Notification Recipients?
- Why No Topics Are Available for Me to Choose When I Configure Alarm Notifications?
- Can I Disable HSS Alarm Notifications?
- How Do I Modify Alarm Notification Items?
- How Do I Disable the SELinux Firewall?
Protection Quota
- How Do I Extend the Validity Period of HSS Quotas?
- How Do I Filter Unprotected Servers?
- Why Can't I Find the Servers I Purchased on the Console?
- What Do I Do If My Quotas Are Insufficient and I Failed to Enable Protection?
- How Do I Allocate My Quota?
- If I Change the OS of a Protected Server, Does It Affect My HSS Quota?
- Why Doesn't an HSS Edition Take Effect After Purchase?
- How Do I Change the Protection Quota Edition Bound to a Server?
- Can I Bind a Server to an HSS Quota If They Are in Different Enterprise Projects?
- Billing, Renewal, and Unsubscription
- How Do I Use the Windows Remote Desktop Connection Tool to Connect to a Windows Server?
- How Do I Check HSS Log Files?
- How Do I Enable Logging for Login Failures?
- How Do I Clear an Alarm on Critical File Changes?
- Why Can't I View All Projects in the Enterprise Project Drop-down List?
- How Do I Enable or Disable HSS Self-protection?
- What Do I Do If Windows Self-Protection Cannot Be Disabled?
- Why Is a Deleted ECS Still Displayed in the HSS Server List?
About HSS
- Videos
More Documents
User Guide (Ankara Region)
- Introduction
- Enabling HSS
- Server Security Dashboard
- Asset Management
- Risk Prevention
- Prevention
- Security Report
- Installation & Configuration
- Permissions Management
About HSS
- What Is HSS?
- What Is Container Security Service?
- How Do I Use HSS?
Agent FAQs
- How Do I Install the Agent?
- Do WTP and HSS Use the Same Agent?
- How Do I Do If the Account Cracking Prevention Function Does Not Take Effect on Some Linux Accounts?
- What Do I Do If My Remote Server Port Is Not Updated in Brute-force Attack Records?
- Weak Passwords and Unsafe Accounts
Intrusions
- What Do I Do If a Mining Process Is Detected on a Server?
- Why Some Attacks on Servers Are Not Detected?
- How Often Does HSS Detect, Isolate, and Kill Malicious Programs?
- Abnormal Logins
- Unsafe Settings
- Vulnerability Management
- Container Guard Service
- Ransomware Protection
- How Do I Use 2FA?
- How Do I Add a Mobile Phone Number or Email Address for Receiving 2FA Verification Notifications?
- If I Choose to Use Verification Code for 2FA, How Do I Get the Code?
- Quotas
- How Do I Use the Windows Remote Desktop Connection Tool to Connect to a Server?
- Is HSS Available as Offline Software?
- How Do I Enable HSS Self-Protection?
- What Do I Do If HSS Self-Protection Cannot Be Disabled?
About HSS
- Change History
- Introduction
- Enabling HSS
- Asset Management
- Risk Prevention
Prevention
- Application Protection
- WTP
- File Integrity Monitoring
Container Firewalls
- Creating a Policy (for a Cluster Using the Container Tunnel Network Model)
- Creating a Policy (for a Cluster Using the VPC Network Model)
- Managing Policies (for a Cluster Using the Container Tunnel Network Model)
- Managing Policies (for a Cluster Using the VPC Network Model)
- Security Report
- Audit
- Manually Upgrading HSS
- About HSS
Agent FAQs
- What Can I Do If the Agent Status Is Still "Not installed" After Installation?
- What Do I Do If the Account Cracking Prevention Function Does Not Take Effect on Some Accounts for Linux Servers?
Intrusions
- Abnormal Logins
- Unsafe Settings
- How Do I Use 2FA?
- Others
- Change History
User Guide (Paris)
- Introduction
- Enabling HSS
Asset Management
- Asset Management
- Server Fingerprints
- Container Fingerprints
- Server Management
- Risk Prevention
Prevention
- WTP
Container Firewalls
- Security Report
- Audit
- About HSS
Agent FAQs
- What Addresses Do ECSs Access After the Agent Is Installed?
Intrusions
- Abnormal Logins
- Unsafe Settings
- Do I Need to Restart a Server After Fixing its Vulnerabilities?
- How Do I Use 2FA?
- Change History
Viewing Ransomware Protection
After ransomware protection is enabled, if a ransomware attack event occurs on the server, the event will be recorded and displayed in the ransomware event list. You can handle the events based on your service requirements.
You have enabled HSS premium, WTP, or container edition.
- After ransomware protection is enabled, you need to handle ransomware alarms and fix the vulnerabilities in your systems and middleware in a timely manner.
Checking the Ransomware Prevention Overview
- Click
in the upper left corner of the page, select a region, and choose Security > Host Security Service.
- In the navigation pane, choose Prevention > Ransomware Prevention. Check ransomware prevention details.
Table 1 Ransomware prevention parameters Parameter
Example Value
Enterprise Project
After an enterprise project is selected, the overview page will display the data in the project only.
You can select an existing enterprise project. By default, data of all servers is displayed.
Time range
Select a time range to check ransomware defense statistics.
Valid values: Last 24 hours, Last 3 days, Last 7 days, Last 30 days
Last 30 days
Protection Statistics
Protected Servers
Number of servers protected against ransomware.
Events
Number of ransomware-related events detected within the specified time range.
Backup Statistics
Backed Up Servers
Number of servers whose data has been backed up.
Backup and Restoration Tasks
Number of server data restoration tasks. You can click the number to view the task progress.
Protected Servers
Server Name/ID
Server name and ID. You can click a server name to view its details.
IP Address
EIP and private IP address of a server.
OS
Server OS.
Linux
Server Status
Server status. It can be:
- Running
- Stopped
Ransomware Protection Status
Ransomware protection status of a server. Its value can be:
- Enabling
- Enabled
- Disabling
- Disabled
Enabled
Policy
Policy used for the server.
Events
Number of events detected within the selected time range.
Backup
Status of the backup function. Its value can be:
- Enabled: Automatic full data backup has been enabled for a server.
- Disabled: Automatic full data backup is disabled for a server.
Enabled
Backup Policy Status
Status of the backup policy associated with the target server
Enabled
Vault Status
Status of the vault associated with the backup on the target server
Available
Associated Vault
Name of the vault bound to the target server
Bound Servers
Number of servers associated with the backup vault
3
Used/Total Vault Capacity (GB)
The used capacity and total capacity of the vault associated with the target server
30/400
Backups
Number of backups generated in the vault
18
Policies
Policy
Policy name.
Action
Action of a policy. Its value can be:
- Report alarm: If a virus is detected, an alarm will be reported.
- Report alarm and isolate: If a virus is detected, an alarm will be reported and the virus will be isolated.
Honeypot Protection
Files and directories that store invalid data on servers and are used as honeypots.
If ransomware prevention is enabled, this function is enabled by default.
After honeypot protection is enabled, the system deploys honeypot files in protected directories and key directories (unless otherwise specified by users). A honeypot file occupies only a few resources and does not affect your server performance.
Enabled
OS
OS of the server to which the target policy is bound.
Windows
Associated Servers
Number of servers associated with the policy.
Viewing Backup and Restoration Tasks
The backup of HSS ransomware protection depends on Cloud Backup and Recovery (CBR). Before enabling server backup, ensure that you have applied for CBR.
- Log in to the management console and go to the HSS page.
- In the navigation pane, choose Prevention > Ransomware Prevention. Click the number of backup and restoration tasks.
- In the dialog box that is displayed, view the backup and restoration task details. You can filter or search for a server by its name or status. For more information, see Table 2.
Table 2 Backup and restoration task parameters Parameter
Example Value
Server Name/ID
Name or ID of a server that executes a restoration task.
Backup Name
Name of a backup file.
Restoration Status
Restoration status of a server. It can be:
- Succeeded
- Skipped
- Failed
- In progress
- Timed out
- Waiting
If a task was skipped, failed, or timed out, perform restoration again.
Succeeded
Start/End Time
Start and end time of backup and restoration.
Restoring Server Data
- In the navigation pane, choose Prevention > Ransomware Prevention. Click the Protected Servers tab. In the Operation column of the target server, click More > Restore Data.
- In the dialog box that is displayed, view information about the server to be restored. You can search for the backup data source to be restored by filtering the backup status and searching for the backup name. For more information, see Table 3.
Table 3 Backup data source parameters Parameter
Example Value
Backup Name
Backup Status
Backup status. It can be:
- Available
- Creating
- Deleting
- Restoring
- Error
A backup in Available state can be used for restoration.
Available
Execution Time
Time when the data source was backed up.
- In the Operation column of a backup, click Restore Data.
Only a backup in the available state can be restored.
- In the dialog box that is displayed, confirm the server information and click OK.
Modifying a Backup Policy
- In the navigation pane, choose Prevention > Ransomware Prevention. The protected server list is displayed. Click the policy name in the Backup Policy Status column of the target server.
- Configure the policy in the dialog box that is displayed. For more information, see Table 4.
Table 4 Policy parameters Parameter
Example Value
Backup Frequency
Data can be automatically backed up on specific days in a week, or at a fixed interval.
- Weekly: Select one or more days in a week to back up data.
- Day based: The range of the backup interval is 1 to 30 days.
Weekly
Execution Time
Time when automated backup is started.
Example of policy configurations
Policy 1: Set Backup Frequency to Weekly, select Wednesday and Saturday, and set Execution Time to 00:00 and 13:00. Data will be automatically backed up at 00:00 and 13:00 every Wednesday and Saturday.
Policy 2: Set Backup Frequency to Day based and set the interval to two days. Set Execution Time to 02:00 and 14:00. Data will be automatically backed up at 02:00 and 14:00 at an interval of two days.
00:00, 07:00
Timezone
Select the time zone of the backup time.
UTC+08:00
- Confirm the settings and click Next. Configure the backup retention rule.
- Type: Backup Quantity
Configure the backup policy. For more information, see Table 5.
Table 5 Parameters for data retention by quantity Parameter
Example Value
Rule
Number of latest backups to be retained.
NOTICE:This setting takes effect no matter how you configure advanced options.
For example, if the rule is configured to keep the most recent 30 backups, and Advanced Options are configured to keep the latest backup in the last 3 months (90 days), the latest 30 backups will be retained.
30
(Optional) Advanced Options
You can retain the latest backup in a day, a week, a month, or a year.
- Daily backup: The latest backup on each of the specified days is retained.
- Weekly backup: The latest backup on each day of the specified weeks is retained.
- Monthly backup: The latest backup on each day of the specified months is retained.
- Yearly backup: The latest backup on each day of the specified years is retained.
Keep the most recent backup from each of the last three months
- Type: Time period
Configure the backup policy. For more information, see Table 6.
Table 6 Parameters for data retention by time period Parameter
Example Value
Rule
Select or customize a backup retention period. The system will automatically retain backups and delete old ones based on your settings. The retention period can be:
- Days
- 1 month
- 3 months
- 6 months
- 1 year
3 months
- Type: Permanent
Backup data will be permanently stored.
If the Retention Type of a rule is changed from Time period to Permanent, historical backups will still be deleted by following based on the Time period settings.
- Click OK.
