On this page
Show all
What Is Web Tamper Protection?
Updated on 2024-07-12 GMT+08:00
Web Tamper Protection (WTP) monitors website directories in real time, backs up files, and restores tampered files using the backup. WTP protects your websites from Trojans, illegal links, and tampering.
Web Tamper Protection (WTP) can detect and prevent tampering of files in specified directories, including web pages, documents, and images, and quickly restore them using valid backup files.
Table 1 WTP operation process and function description
Type
Operation
Description and Reference
Preparations
If no VDC operator account is available, contact an operations administrator to create a VDC administrator account, and then use the VDC administrator account to create a VDC operator.
Getting Started with WTP
Applying for Quota
Apply for WTP quota.
Installing an Agent
The agent is provided by HSS. It runs scan tasks to scan all servers, monitors server security, and reports collected server information to the cloud protection center.
You can enable WTP only after the agent is installed.
Parameters required for configuring alarm notifications
After alarm notification is enabled, you can receive alarm notifications sent by HSS to learn about security risks facing your servers and web pages.
Without this function, you have to log in to the management console to view alarms.
Enabling HSS
Allocate a quota to a server and enable HSS for the server.
Enable WTP
Adding a Protected Directory
Add a directory to be protected by WTP.
Create remote backup
By default, HSS backs up the files from the protected directories to the local backup directory you specified when you added protected directories. To protect the local backup files from tampering, you must enable the remote backup function.
Adding a privileged process
After WTP is enabled, the content in the protected directories is read-only. To allow certain processes to modify files in the directories, add them to the privileged process list.
Set scheduled WTP protection
You can schedule WTP protection to allow website updates in specific periods.
Enabling dynamic WTP
Dynamic WTP protects your data while Tomcat is running, detecting dynamic data tampering in databases.
View WTP reports
After WTP is enabled, HSS will immediately check the protected directories you specified. You can check records about detected tampering.
