Container Alarm Events
Updated on 2024-07-12 GMT+08:00
After node protection is enabled, an agent is deployed on each container host to monitor the running status of containers in real time. The agents support escape detection, high-risk system calls, abnormal processes, abnormal files, and container environment detection. You can learn alarm events comprehensively on the Container Alarms page, and eliminate security risks in your assets in a timely manner.
  • Only HSS container edition supports the container security alarm function.
  • Intrusion detection alarms can be generated only for Docker containers.
Container Alarm Types
Event Type
Alarm Name
Mechanism
Malware
Unclassified malware
Check malware, such as web shells, Trojan horses, mining software, worms, and other viruses and variants. The malware is found and removed by analysis on program characteristics and behaviors, AI image fingerprint algorithms, and cloud scanning and killing.
Ransomware
Check for ransomware in web pages, software, emails, and storage media.
Ransomware can encrypt and control your data assets, such as documents, emails, databases, source code, images, and compressed files, to leverage victim extortion.
Web shells
Check whether the files (often PHP and JSP files) in the web directories on containers are web shells.
Vulnerability Exploits
Vulnerability escapes
HSS reports an alarm if it detects container process behavior that matches the behavior of known vulnerabilities (such as Dirty COW, brute-force attack, runC, and shocker).
File escapes
HSS reports an alarm if it detects that a container process accesses a key file directory (for example, /etc/shadow or /etc/crontab). Directories that meet the container directory mapping rules can also trigger such alarms.
Abnormal System Behaviors
Reverse shells
Reverse shells can be detected for protocols including TCP, UDP, and ICMP.
You can configure the reverse shell detection rule in the Malicious File Detection rule on the Policies page. HSS will check for suspicious or remotely executed commands.
Process privilege escalations
After hackers intrude containers, they will try exploiting vulnerabilities to grant themselves the root permissions or add permissions for files. In this way, they can illegally create system accounts, modify account permissions, and tamper with files.
HSS can detect the following abnormal privilege escalation operations:
  • Root privilege escalation by exploiting SUID program vulnerabilities
  • Root privilege escalation by exploiting kernel vulnerabilities
  • File privilege escalation
High-risk system calls
Users can run tasks in kernels by Linux system calls. CGS reports an alarm if it detects a high-risk call, such as open_by_handle_at, ptrace, setns, and reboot.
High-risk command executions
Check executed commands in containers and generate alarms if high-risk commands are detected.
Abnormal container processes
  • Malicious container program
    HSS monitors container process behavior and process file fingerprints. It reports an alarm if it detects a process whose behavior characteristics match those of a predefined malicious program.
  • Abnormal processes
    Container services are usually simple. If you are sure that only specific processes run in a container, you can whitelist the processes on the Policy Groups page, and associate the policy with the container.
    HSS reports an alarm if it detects that a process not in the whitelist is running in the container.
Sensitive file access
HSS monitors the container image files associated with file protection policies, and reports an alarm if the files are modified.
Abnormal container startups
HSS monitors container startups and reports an alarm if it detects that a container with too many permissions is started. This alarm does not indicate an actual attack. Attacks exploiting this risk will trigger other HSS container alarms.
HSS container check items include:
  • Privileged container startup (privileged:true)
    Alarms are triggered by the containers started with the maximum permissions. Settings that can trigger such alarms include the –privileged=true parameter in the docker run command, and privileged: true in the securityContext of the container in a Kubernetes pod.
    If the alarm name is Container Security Options and the alarm content contains privileged:true, it indicates that the container is started in privileged container mode.
  • Too many container capabilities (capability:[xxx])
    In Linux OSs, system permissions are divided into groups before assigned to containers. A container only has a limited number of permissions, and the impact scope of this container is limited in the case of an incident. However, malicious users can grant all the system permissions to a container by modifying its startup configurations.
    If the alarm name is Container Security Options and the alarm content contains capabilities:[xxx], it indicates that the container is started with an overlarge capability set, which poses risks.
  • Seccomp not enabled (seccomp=unconfined)
    Secure computing mode (seccomp) is a Linux kernel feature. It can restrict system calls invoked by processes to reduce the attack surface of the kernel. If seccomp=unconfined is configured when a container is started, system calls will not be restricted for the container.
    If the alarm name is Container Security Options and the alarm content contains seccomp=unconfined, it indicates that the container is started without seccomp, which poses risks.
    If seccomp is enabled, permissions will be verified for every system call. The verifications will probably affect services if system calls are frequent. Before you decide whether to enable seccomp, you are advised to test-enable it and analyze the impact on your services.
  • Container privilege escalation (no-new-privileges:false)
    Processes can escalate permissions by running the sudo command and using SUID or SGID bits. Default container configurations do not allow privilege escalation.
    If –no-new-privileges=false is specified when a container is started, the container can escalate privileges.
    If the alarm name is Container Security Options and the alarm content contains no-new-privileges:false, it indicates that privilege escalation restriction is disabled for the container, which poses risks.
  • High-risk directory mapping (mounts:[...])
    For convenience purposes, when a container is started on a server, the directories of the server can be mapped to the container. In this way, services in the container can directly read and write resources on the server. However, this mapping incurs security risks. If any critical directory in the server OS is mapped to the container, improper operations in the container will probably damage the server OS.
    HSS reports an alarm if it detects that a critical server path (/boot, /dev, /etc, /sys, and /var/run) is mounted during container startup.
    If the alarm name is Container Mount Point and the alarm content contains mounts:[{"source":"xxx","destination":"yyy"...], it indicates that a file path mapped to the container is unsafe. In this case, check for risky directory mappings. You can configure the mount paths that are considered secure in the container information collection policy.
    Alarms will not be triggered for the files that need to be frequently accessed by Docker containers, such as /etc/hosts and /etc/resolv.conf.
  • Startup of containers in the host namespace
    The namespace of a container must be isolated from that of a server. If a container and a server use the same namespace, the container can access and modify the content on the server, which incurs container escape risks. To prevent such problems, HSS checks the container PID, network, and whether the container namespace is host.
    If the alarm name is Container Namespace and the alarm content contains Container PID Namespace Mode, Container IPC Namespace Mode, or Container Network Namespace Mode, it indicates that a container whose namespace is host is started. In this case, check the container startup options based on the alarm information. If you are sure that the container can be trusted, you can ignore the alarm.
Container Image blocking
If a container contains insecure images specified in the , before the container is started, an alarm will be generated for the insecure images.
You need to .
Abnormal User Behavior
Invalid accounts
Hackers can probably crack unsafe accounts on your containers and control the containers.
HSS checks for suspicious hidden accounts and cloned accounts and generates alarms on them.
Brute-force attacks
Detect and report alarms for brute-force attack behaviors, such as brute-force attack attempts and successful brute-force attacks, on containers.
Detect SSH, web, and Enumdb brute-force attacks on containers.
Currently, brute-force attacks can be detected only in the Docker runtime.
Abnormal Cluster Behaviors
Abnormal pod behaviors
Detect abnormal operations such as creating privileged pods, static pods, and sensitive pods in a cluster and abnormal operations performed on existing pods and report alarms.
User information enumerations
Detect the operations of enumerating the permissions and executable operation list of cluster users and report alarms.
Binding cluster roles
Detect operations such as binding or creating a high-privilege cluster role or service account and report alarms.
Kubernetes event deletions
Detect the deletion of Kubernetes events and report alarms.
Monitored important file paths
Type
Linux
bin
/bin/ls
/bin/ps
/bin/bash
/bin/login
usr
/usr/bin/ls
/usr/bin/ps
/usr/bin/bash
/usr/bin/login
/usr/bin/passwd
/usr/bin/top
/usr/bin/killall
/usr/bin/ssh
/usr/bin/wget
/usr/bin/curl
