Viewing Baseline Check Details
HSS checks your software for weak password complexity policies and other unsafe settings, and provides suggestions for fixing detected risks.
Prerequisite
Only the servers protected by the enterprise edition or above are checked.
Check Items
Item |
Description |
Unsafe configurations |
Currently, the following check standards and types are supported:
Password complexity policies |
Password complexity policies on system accounts. |
Common weak passwords |
Weak passwords defined in the common weak password library. Common weak passwords of MySQL, FTP, and system accounts. |
Viewing Unsafe Configurations
View the risk statistics of unsafe configurations and the corresponding suggestions.
- Click
in the upper left corner of the page, select a region, and choose Security > Host Security Service.
- In the navigation pane on the left, choose Prediction > Baseline Checks.
- Click the Unsafe Configurations tab to view the risk items. For more information, see Table 2.
To view the server configuration check results under a specified baseline check policy, select a policy in the Baseline Check Policy drop-down list.
Table 2 Parameter description Parameter
Risk Level
Level of a detection result.
- High
- Low
- Medium
- Safe
Baseline Name
Name of the baseline that is checked.
Type
Policy type of the baseline that has been checked.
- Cloud security practices
Check Item
Total number of configuration items that are checked.
Risky Item
Total number of the risky configurations.
Affected Servers
Total number of servers affected by the detected risks in a baseline.
Last Scanned
Time when the last detection was performed.
Description of a baseline.
- Click the target baseline name in the list to view the baseline description, affected servers, and details about all check items.
- Click View Details in the Operation column of the target check item to view the description, audit description, and handling suggestions.
You need to check whether a risk item is critical or need to be handled.
If yes, modify the check item according to the handling suggestions. If no, click Ignore in the Operation column of the check item.
Viewing Password Complexity Policy Detection
View the risk statistics and handling suggestions of password complexity policy detection.
- Log in to the management console and go to the HSS page.
- Click the Password Complexity Policy Detection tab to view the risk statistical items and handling suggestions. For more information, see Table 3.
Table 3 Parameter description Parameter
Server
Name and IP address of the detected server.
Password Length
Whether the password length of the target server meets the requirements.
- Passed
- Failed
Uppercase Letters
Whether the uppercase letters used in the target server password meet the requirements.
- Passed
- Failed
Lowercase Letters
Whether the lowercase letters used in the target server password meet the requirements.
- Passed
- Failed
Digits
Whether the digits used in the target server password meet the requirements.
- Passed
- Failed
Special characters
Whether the special characters used in the target server password meet the requirements.
- Passed
- Failed
Suggestion
Suggestion for fixing unsafe passwords
Viewing Common Weak Password Detection
View the risk statistics of weak password detection and the corresponding handling suggestions.
- Click the Common Weak Password Detection tab to view the statistics of risky weak password accounts on the server. For more information, see Table 4.
Table 4 Parameter description Parameter
Server
Account Name
Accounts with weak passwords that are detected on the target server.
Account Type
Type of an account.
Usage Duration (Days)
Period for using a weak password.
- To enhance server security, you are advised to modify the accounts with weak passwords for logging in to the system in a timely manner, such as SSH accounts.
- To protect internal data of your server, you are advised to modify software accounts that use weak passwords, such as MySQL accounts and FTP accounts.
After modifying weak passwords, you are advised to perform manual detection immediately to verify the result. If you do not perform manual verification, HSS will automatically check the settings the next day in the early morning.
- A password should contain more than eight characters, including uppercase letters, lowercase letters, digits, and special characters.
Exporting the Baseline Check Report
- The check result of a single cloud server cannot be separately exported.
- Up to 5000 alarm records can be exported at a time.
