How Many CPU and Memory Resources Are Occupied by the Agent When It Performs Scans?
HSS uses lightweight agents, which occupy only a few resources and do not affect your services.
The CPU and memory usage is as follows.
Maximum CPU Usage
A running agent occupies a maximum of 20% of a vCPU. The actual usage depends on your server specifications. For details, see Resource Usage of Different Specifications While the Agent Is Running.
If the CPU usage exceeds 20% of a vCPU, the agent will automatically reduce CPU usage, spending more time on scans. This does not affect your services. If the CPU usage exceeds 25% of a vCPU, the agent will be automatically restarted.
The agent is scheduled to scan your servers from 00:00 to 04:00 every day. It does not affect the normal running of the server system.
Peak Memory Usage
A running agent occupies about 500 MB memory. If the memory usage reaches 500 MB, the agent will be automatically restarted within 5 minutes.
The following table describes the CPU and memory usage of different specifications when the agent is running.
vCPUs |
Max. CPU Usage of Agent |
Max. Memory Usage |
1 vCPU |
20% |
500MB |
2 vCPUs |
10% |
500MB |
4 vCPUs |
5% |
500MB |
8 vCPUs |
2.5% |
500MB |
12 vCPUs |
About 1.67% |
500MB |
16 vCPUs |
About 1.25% |
500MB |
24 vCPUs |
About 0.84% |
500MB |
32 vCPUs |
About 0.63% |
500MB |
48 vCPUs |
About 0.42% |
500MB |
60 vCPUs |
About 0.34% |
500MB |
64 vCPUs |
About 0.32% |
500MB |
