Configuring Remote Backup
By default, HSS backs up the files from the protected directories (excluding specified subdirectories and file types) to the local backup directory you specified when adding protected directories. To protect the local backup files from tampering, you must enable the remote backup function.
If a file directory or backup directory on the local server becomes invalid, you can use the remote backup service to restore the tampered web page.
Only the servers that are protected by the HSS WTP edition support the operations described in this section.
The following servers can be used as remote backup servers:
Linux servers whose Server Status is Running and Agent Status is Online
- The remote backup function can be used when the Linux backup server is connected to your cloud server. To ensure a proper backup, you are advised to select a backup server on the same intranet as your cloud server.
- You are advised to use intranet servers least exposed to attacks as the remote backup servers.
Adding a Remote Backup Server
- Click
in the upper left corner of the page, select a region, and choose Security > Host Security Service.
- Choose Prevention > Web Tamper Protection, click Servers tab page and click Configure Protection in the Operation column.
- Click Settings under Protected Directory Settings.
- Click Manage Remote Backup. In the dialog box that is displayed, click Add Backup Server. For details, see Table 1.
- Click OK.
Setting remote backup
- Click Enable Remote Backup and select a remote backup server.
- Click OK to start remote backup.
Changing a Remote Backup Server
- Click Change Remote Backup Server. Select a remote backup server from the drop-down list.
On the Change Remote Backup Server dialog box, the Backup Server you selected must have been Enabled.
- Click OK.
Follow-Up Procedure
Disabling remote backup
Exercise caution when performing this operation. If remote backup is disabled, HSS will no longer back up files in your protected directories.
