On this page
How Do I Fix an Abnormal Agent?
Updated on 2024-07-12 GMT+08:00
Your agent is probably abnormal if it is in Not installed or Offline state. Agent statuses and their meaning are as follows:
  • Uninstalled: No agent has been installed on the server, or the agent has been installed but not started.
  • Offline: The communication between the agent and the server is abnormal. The agent on the server has been deleted, or a server is offline.
  • Online: The agent on the server is running properly.
Possible Causes
  • The agent status on the console is not updated.
    The agent status has not been updated. After the agent is installed, it takes 5 to 10 minutes for the console to update its status.
  • OS version not supported.
    For details, see .
  • The network is faulty.
    The agent or the cloud protection center is abnormal. For example, the NIC is faulty, the IP address changes, or the bandwidth is low.
  • The agent process is abnormal.
Solution
  1. Check whether the agent status remains Offline on the console for more than 10 minutes after the agent was installed.
    • If yes, go to 2.
    • If no, wait until the agent goes online. No further action is required. After the agent was installed, it takes 5 to 10 minutes for the console to update its status.
  2. Check whether your server OS is within the scope of support in "Constraints" in "Service Overview".
    • If yes, go to 3.
    • If no, the HSS agent cannot be installed or run on your server. Upgrade the OS to a version supported by HSS and try again.
  3. Check whether the server network is normal.
    • If yes, go to 4.
    • If no, After the server can access the network, check the agent status.
  4. Restart the agent process.
    • Windows
      1. Log in to the server as user administrator.
      2. Open the Task Manager.
      3. On the Services tab page, select HostGuard.
      4. Right-click the service and choose Restart.
    • Linux
      Run the following command in the CLI as user root to restart the agent:
      service hostguard restart
      If the following information is displayed, the restart is successful:
      root@HSS-Ubuntu32:~#service hostguard restart
      Stopping Hostguard...
      Hostguard stopped
      Hostguard restarting...
      Hostguard is running
    After the process is restarted, wait for about 2 minutes.
    • If the agent status is Online, no further action is required.
    • If the agent status is still Not installed or Offline, uninstall the agent and install it again.
