Viewing Server Asset Information
Updated on 2024-07-12 GMT+08:00
HSS proactively checks open ports, processes, and auto-startup entries on your servers. You can check all the assets on your servers and their risks in a timely manner.
HSS does not touch your assets. You need to manually eliminate the risks.
Your servers are protected by HSS enterprise, premium, WTP, or container edition.
Check Frequency
Accounts and open ports are detected in real time. The open port detection result is updated every six hours.
Processes, web directories, software, and auto-startup items are automatically checked in the early morning every day.
Viewing Asset Information of All Servers
  2. In the upper left corner of the page, click , select a region, and choose Security > Host Security Service.
  3. Choose Asset Management > Asset Fingerprints to view all server assets.
Table 1 Asset fingerprints
Item
Check Frequency
Account information
Check and manage all accounts on your servers to keep them secure.
You can check real-time and historical account information to find suspicious accounts.
  • Real-time account information includes the account name, number of servers, server name/IP address, login permission, root permission, user group, user directory, shell started by the user, and the last scan time.
  • Historical account change records include the server name/IP address, change status, login permission, root permission, user group, user directory, shell started by the user, and the last scan time.
Real-time check
Open ports
Check open ports on your servers, including risky and unknown ports.
You can easily find high-risk ports by checking local ports, protocol types, server names, IP addresses, statuses, PIDs, and program files.
  • Manually disabling high-risk ports
    If HSS detects open high-risk ports or unused ports, check whether they are really used by your services. For high-risk ports, check program files. If there are risks, delete or isolate the source files.
    It is recommended that you handle the ports at the Dangerous risk level promptly and handle the ports at the Unknown level based on the actual service conditions.
  • Ignore risks: If a detected high-risk port is actually a normal port used for services, you can ignore it. The port will no longer be regarded risky or generate alarms.
Real-time check
Processes
Check processes on your servers and find abnormal processes.
You can easily identify abnormal processes based process paths, server names, IP addresses, startup parameters, startup time, users who run the processes, file permissions, PIDs, and file hashes.
If a suspicious process has not been detected in the last 30 days, its information will be automatically deleted from the process list.
Real-time check
Installed software
Check and manage all software installed on your servers, and identify insecure versions.
You can check real-time and historical software information to determine whether the software is risky.
  • Real-time software information includes the software name, number of servers, server names, IP addresses, software versions, software update time, and the last scan time.
  • Historical software change records include the server names, IP addresses, change statuses, software versions, software update time, and the last scan time.
Automatic check every day
Auto-startup
Check for auto-startup items and quickly locate Trojans.
  • Real-time information about auto-started items includes their names, types (auto-started service, startup folder, pre-loaded dynamic library, Run registry key, or scheduled task), number of servers, server names, IP addresses, paths, file hashes, users, and the last scan time.
  • The historical change records of auto-started items include server names, IP addresses, change statuses, paths, file hashes, users, and the last scan time.
Real-time check
Websites
You can check statistics about web directories and sites that can be accessed from the Internet. You can view the directories and permissions, access paths, external ports, certificate information (to be provided later), and key processes of websites.
Once a week (06:00 a.m. every Monday)
Web frameworks
You can check statistics about frameworks used for web content presentation, including their versions, paths, and associated processes.
You can check information about servers, versions, paths, and processes associated with middleware.
Web services
You can check details about the software used for web content access, including versions, paths, configuration files, and associated processes of all software.
Web applications
You can check details about software used for web content push and release, including versions, paths, configuration files, and associated processes of all software.
You can check details about software that provides data storage, including versions, paths, configuration files, and associated processes of all software.
Viewing Asset Information of a Single Server
  3. In the navigation pane, choose Asset Management > Servers & Quota. Click the Servers tab.
  4. Click the name of the target server. On the server details page that is displayed, click the Asset Fingerprint tab.
  5. Click a fingerprint in the fingerprint list to view its asset information. Table 2 describes the types of asset fingerprints.
    Table 2 Asset fingerprints
    Item
    Check Frequency
    Account information
    Real-time check
    Open ports
    Real-time check
    Processes
    Real-time check
    Installed software
    Auto-startup
    Real-time check
    Websites
    Web frameworks
    Web services
    Web applications
