On this page
HSS Actions
Updated on 2024-07-12 GMT+08:00
This section describes fine-grained permissions management for your HSS instances. If your account does not need individual IAM users, then you may skip over this section.
By default, new IAM users do not have any permissions assigned. You need to add a user to one or more groups, and assign policies or roles to these groups. The user then inherits permissions from the groups it is a member of. This process is called authorization. After authorization, the user can perform specified operations on cloud services based on the permissions.
You can grant users permissions by using roles and policies. Roles are provided by IAM to define service-based permissions depending on user's job responsibilities. IAM uses policies to perform fine-grained authorization. A policy defines permissions required to perform operations on specific cloud resources under certain conditions.
Supported Actions
HSS provides system-defined policies that can be directly used in IAM. You can also create custom policies and use them to supplement system-defined policies, implementing more refined access control. The following are related concepts:
  • Permissions: Allow or deny certain operations.
  • Actions: Specific operations that are allowed or denied.
  • Dependent actions: When assigning permissions for an action, you also need to assign permissions for the dependent actions.
HSS supports the following actions that can be defined in custom policies:
Actions
Permission
Action
Related Action
Query the protected server list
hss:hosts:list
vpc:ports:get
vpc:publicIps:list
ecs:cloudServers:list
Enable or disable protection on servers
hss:hosts:switchVersion
Manual scan
hss:hosts:manualDetect
Check the status of a manual scan
hss:manualDetectStatus:get
Query weak password scan reports
hss:weakPwds:list
Query account cracking protection reports
hss:accountCracks:list
Unblock an IP address that was blocked during account cracking prevention
hss:accountCracks:unblock
Query malicious program scan results
hss:maliciousPrograms:list
Query remote login scan results
hss:abnorLogins:list
Query important file change reports
hss:keyfiles:list
Query the open port list
hss:ports:list
Query the vulnerability list
hss:vuls:list
Perform batch operations on vulnerabilities
hss:vuls:operate
Query the account list
hss:accounts:list
Query the software list
hss:softwares:list
Query the web path list
hss:webdirs:list
Query the process list
hss:processes:list
Query configuration scan reports
hss:configDetects:list
Query web shell scan results
hss:Webshells:list
Query risky account scan reports
hss:riskyAccounts:list
Obtain server risk statistics
hss:riskyDashboard:get
Query password complexity policy scan reports
hss:complexityPolicys:list
Perform batch operations on malicious programs
hss:maliciousPrograms:operate
Perform batch operations on open ports
hss:ports:operate
Perform operations on detected unsafe settings
hss:configDetects:operate
Perform batch operations on web shells
hss:Webshells:operate
Configure common login locations
hss:commonLocations:set
Query common login locations
hss:commonLocations:list
Configure common login IP addresses
hss:commonIPs:set
Query common login IP addresses
hss:commonIPs:list
Configure the login IP address whitelist
hss:whiteIps:set
Query the login IP address whitelist
hss:whiteIps:list
Configure weak passwords
hss:weakPwds:set
Query weak passwords
hss:weakPwds:get
Configure web paths
hss:webDirs:set
Query web paths
hss:webDirs:get
Obtain the list of servers where 2FA is enabled
hss:twofactorAuth:list
Enable 2FA
hss:twofactorAuth:set
Enable or disable automatic isolation and killing of malicious programs
hss:automaticKillMp:set
Query the programs that have been automatically isolated and killed
hss:automaticKillMp:get
Query the agent download address
hss:installAgent:get
Uninstall an agent
hss:agent:uninstall
Query HSS alarms
hss:alertConfig:get
Configure HSS alarms
hss:alertConfig:set
Query the WTP list
hss:wtpHosts:list
vpc:ports:get
vpc:publicIps:list
Enable or disable WTP
hss:wtpProtect:switch
Configure backup servers
hss:wtpBackup:set
Query backup servers
hss:wtpBackup:get
Configure protected directories
hss:wtpDirectorys:set
Query the protected directory list
hss:wtpDirectorys:list
Query WTP records
hss:wtpReports:list
Configure privileged processes
hss:wtpPrivilegedProcess:set
Query the privileged process list
hss:wtpPrivilegedProcesses:list
Configure a protection mode
hss:wtpProtectMode:set
Query the protection mode
hss:wtpProtectMode:get
Configure a protected file system
hss:wtpFilesystems:set
Query the protected file system list
hss:wtpFilesystems:list
Configure scheduled protection
hss:wtpScheduledProtections:set
Query scheduled protection
hss:wtpScheduledProtections:get
Configure WTP alarms
hss:wtpAlertConfig:set
Query WTP alarms
hss:wtpAlertConfig:get
Query WTP statistics
hss:wtpDashboard:get
Query policy group
hss:policy:get
Configure a policy group
hss:policy:set
Query the detected intrusion list
hss:event:get
Perform operations on intrusions
hss:event:set
Query server groups
hss:hostGroup:get
Configure server groups
hss:hostGroup:set
Monitor file integrity
hss:keyfiles:set
hss:keyfiles:list
Query the auto-startup list
hss:launch:list
