Viewing Server Protection Status
Updated on 2024-07-12 GMT+08:00
The server list on the Servers page displays the protection status of only the servers used in the selected region.
  2. Click in the upper left corner of the page, select a region, and choose Security > .
  3. In the navigation pane, choose Asset Management > Servers & Quota. On the Servers tab, view the protection status of the server. For more information, see Table 1.
    You can check the server name, ID, IP address, OS, running status, and enterprise project. To set the items to be displayed in the server protection list, click in the upper right corner.
    • To check the protection status of a server, enter a server name, server ID, or IP address in the search box above the server protection list, and click .
    • On the left of the server protection list, select a server protection edition or an asset importance category to view the protection status of each type of servers.
    Table 1 Protection status description
    Agent Status
    • Not installed: The agent has not been installed or successfully started.
      Click Install Agent and install the agent as prompted.
    • Online: The agent is running properly.
    • Offline: The communication between the agent and the HSS server is abnormal, and HSS cannot protect your servers.
    Protection Status
    • Enabled: The server is fully protected by HSS.
    • Unprotected: HSS is disabled for the server. Click Enable in the Operation column to enable HSS for the server.
    Scan Results
    • Risky: The host has risks.
    • Safe: No risks are found.
    • Pending risk detection: HSS is not enabled for the server.
Viewing the WTP Status
  1. Log in to the management console and go to the HSS page.
  2. Choose Prevention > Web Tamper Protection and click Servers to view the protection status of the servers.
    To check the protection status of a target server, enter a server name, server ID, or IP address in the search box above the protection list, and click .
    Table 2 Statuses
    Protection Status
    Protected: HSS provides static web tamper protection (WTP) for the server.
    Dynamic WTP
    Status of dynamic WTP, which can be:
    • : Dynamic WTP is enabled.
    • : Dynamic WTP is disabled. (After enabling dynamic WTP, restart Tomcat to make this setting take effect.)
    Static Tampering Attacks
    Number of times that static web page files are attacked and tampered with.
    Dynamic Tampering Attacks
    Number of web application vulnerability exploits and injection attacks.
Exporting the Server List
  2. Choose Asset Management > Servers & Quota. The Servers tab page is displayed.
  3. Click in the upper right corner of the Server tab page to export the details of the server list.
    The details of up to 1000 servers can be exported at a time.
