Help Center/
Distributed Message Service for RocketMQ/
User Guide (ME-Abu Dhabi Region)/
Managing Users/
Deleting a User
Updated on 2023-06-14 GMT+08:00
Deleting a User
Delete users if they are no longer needed.
Deleting a user will remove its authorization relationship and disconnect it from the instance.
- Click
in the upper left corner to select a region.
Select the region where your RocketMQ instance is located.
- Click
and choose Application > Distributed Message Service for RocketMQ to open the console of DMS for RocketMQ.
- Click a RocketMQ instance to go to the instance details page.
- In the navigation pane, choose Users.
- In the row containing the user to delete, click Delete.
- Click Yes.
Parent topic: Managing Users
