Enabling Message Tracing
To query message traces, you must first enable message tracing on clients.
The following procedures describe how to enable message tracing in Java and Go.
Procedure (Java)
Do as follows to enable message tracing on clients:
- Enabling message tracing on a producer client (tracing messages other than transactional messages)
Set enableMsgTrace of the constructor to true. For example:
DefaultMQProducer producer = new DefaultMQProducer("ProducerGroupName", true); - Enabling message tracing on a producer client (tracing transactional messages)
TransactionMQProducer producer = new TransactionMQProducer(null, "ProducerGroupName", null, true, null);
Transactional message tracing is supported only if the producer client is v4.9.0 or later. If your client is earlier than v4.9.0, upgrade it to a later version.
- Enabling message tracing on a consumer
DefaultMQPushConsumer consumer = new DefaultMQPushConsumer("ConsumerGroupName", true);
Procedure (Go)
- Run the following command to check whether Go has been installed:
go version
If the following information is displayed, Go has been installed.
[root@ecs-test sarama]# go version go version go1.16.5 linux/amd64
If Go is not installed, download and install it.
- Create a go.mod file and add the following code to it to add the dependency:
module rocketmq-example-go go 1.13 require ( github.com/apache/rocketmq-client-go/v2 v2.1.0 )
- Enable message tracing on the producer. Replace the information in bold with the actual values.
package main import ( "context" "fmt" "os" "time" "github.com/apache/rocketmq-client-go/v2" "github.com/apache/rocketmq-client-go/v2/primitive" "github.com/apache/rocketmq-client-go/v2/producer" ) func main() { namesrvs := []string{"192.168.0.1:8100"} traceCfg := &primitive.TraceConfig{ Access: primitive.Local, Resolver: primitive.NewPassthroughResolver(namesrvs), } p, _ := rocketmq.NewProducer( producer.WithNsResolver(primitive.NewPassthroughResolver([]string{"192.168.0.1:8100"})), producer.WithRetry(2), producer.WithTrace(traceCfg)) err := p.Start() if err != nil { fmt.Printf("start producer error: %s", err.Error()) os.Exit(1) } res, err := p.SendSync(context.Background(), primitive.NewMessage("topic1", []byte("Hello RocketMQ Go Client!"))) if err != nil { fmt.Printf("send message error: %s\n", err) } else { fmt.Printf("send message success: result=%s\n", res.String()) } time.Sleep(10 * time.Second) err = p.Shutdown() if err != nil { fmt.Printf("shutdown producer error: %s", err.Error()) } } - Enable message tracing on the consumer. Replace the information in bold with the actual values.
package main import ( "context" "fmt" "os" "time" "github.com/apache/rocketmq-client-go/v2" "github.com/apache/rocketmq-client-go/v2/consumer" "github.com/apache/rocketmq-client-go/v2/primitive" ) func main() { namesrvs := []string{"192.168.0.1:8100"} traceCfg := &primitive.TraceConfig{ Access: primitive.Local, Resolver: primitive.NewPassthroughResolver(namesrvs), } c, _ := rocketmq.NewPushConsumer( consumer.WithGroupName("testGroup"), consumer.WithNsResolver(primitive.NewPassthroughResolver([]string{"192.168.0.1:8100"})), consumer.WithTrace(traceCfg), ) err := c.Subscribe("TopicTest", consumer.MessageSelector{}, func(ctx context.Context, msgs ...*primitive.MessageExt) (consumer.ConsumeResult, error) { fmt.Printf("subscribe callback: %v \n", msgs) return consumer.ConsumeSuccess, nil }) if err != nil { fmt.Println(err.Error()) } // Note: start after subscribe err = c.Start() if err != nil { fmt.Println(err.Error()) os.Exit(-1) } time.Sleep(time.Hour) err = c.Shutdown() if err != nil { fmt.Printf("shutdown Consumer error: %s", err.Error()) } }
