Operations Logged by CTS
With Cloud Trace Service (CTS), you can record DMS for RocketMQ operations for later query, audit, and backtrack operations.
Operation |
Resource Type |
Trace Name |
Successfully creating a topic |
reliability |
Reliability_Topic_CreationSuccess |
Failing to create a topic |
reliability |
Reliability_Topic_CreationFailure |
Successfully modifying a topic |
reliability |
Reliability_Topic_ModifySuccess |
Failing to modify a topic |
reliability |
Reliability_Topic_ModifyFailure |
Successfully deleting a topic |
reliability |
Reliability_Topic_DeletionSuccess |
Failing to delete a topic |
reliability |
Reliability_Topic_DeletionFailure |
Successfully creating a consumer group |
reliability |
Reliability_Create_GroupSuccess |
Failing to create a consumer group |
reliability |
Reliability_Create_GroupFailure |
Successfully editing a consumer group |
reliability |
Reliability_Group_ModifySuccess |
Failing to edit a consumer group |
reliability |
Reliability_Group_ModifyFailure |
Successfully deleting a consumer group |
reliability |
Reliability_Group_DeletionSuccess |
Failing to delete a consumer group |
reliability |
Reliability_Group_DeletionFailure |
Successfully deleting a background task |
reliability |
deleteDMSBackendJobSuccess |
Failing to delete a background task |
reliability |
deleteDMSBackendJobFailure |
Successfully creating an order for creating an instance |
reliability |
createDMSInstanceOrderSuccess |
Failing to create an order for creating an instance |
reliability |
createDMSInstanceOrderFailure |
Successfully submitting a request to modify an instance order |
reliability |
modifyDMSInstanceOrderSuccess |
Failing to submit a request to modify an instance order |
reliability |
modifyDMSInstanceOrderFailure |
Successfully submitting a request to scale up an instance |
reliability |
extendDMSInstanceSuccess |
Failing to submit a request to scale up an instance |
reliability |
extendDMSInstanceFailure |
Successfully deleting an instance that failed to be created |
reliability |
deleteDMSCreateFailureInstancesSuccess |
Failing to delete an instance that failed to be created |
reliability |
deleteDMSCreateFailureInstancesFailure |
Successfully submitting a request to delete multiple instances at a time |
reliability |
batchDeleteDMSInstanceSuccess |
Failing to submit a request to delete multiple instances at a time |
reliability |
batchDeleteDMSInstanceFailure |
Successfully submitting a request to modify instance information |
reliability |
modifyDMSInstanceInfoSuccess |
Failing to submit a request to modify instance information |
reliability |
modifyDMSInstanceInfoFailure |
Deleting multiple instance tasks at a time |
reliability |
batchDeleteDMSInstanceTask |
Successfully deleting an instance |
reliability |
deleteDMSInstanceTaskSuccess |
Failing to delete an instance |
reliability |
deleteDMSInstanceTaskFailure |
Successfully creating an instance |
reliability |
createDMSInstanceTaskSuccess |
Failing to create an instance |
reliability |
createDMSInstanceTaskFailure |
Successfully scaling up an instance |
reliability |
extendDMSInstanceTaskSuccess |
Failing to scale up an instance |
reliability |
extendDMSInstanceTaskFailure |
Successfully modifying instance information |
reliability |
modifyDMSInstanceInfoTaskSuccess |
Failing to modify instance information |
reliability |
modifyDMSInstanceInfoTaskFailure |
