DMS for RocketMQ Metrics
Introduction
This section describes the metrics that DMS for RocketMQ reports to Cloud Eye. You can view metrics and alarms by using the DMS for RocketMQ console.
Namespace
SYS.DMS
Instance Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Monitored Object |
Monitoring Period (Raw Data) |
instance_produce_msg |
Created Messages |
Number of messages received by the instance per minute Unit: count |
> 0 |
RocketMQ instance |
1 minute |
instance_consume_msg |
Retrieved Messages |
Number of messages retrieved from the instance per minute Unit: count |
> 0 |
RocketMQ instance |
1 minute |
current_topics |
Topics |
Number of topics in the instance Unit: count |
≥ 0 |
RocketMQ instance |
1 minute |
Broker Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Monitored Object |
broker_produce_msg |
Created Messages |
Number of messages received by the broker per minute Unit: count |
> 0 |
RocketMQ instance broker |
1 minute |
broker_consume_msg |
Number of messages retrieved from the broker per minute Unit: count |
> 0 |
1 minute |
broker_produce_rate |
Message Creation Rate |
Number of messages received by the broker per second Unit: count/s |
> 0 |
1 minute |
broker_consume_rate |
Message Retrieval Rate |
Number of messages retrieved from the broker per second Unit: count/s |
> 0 |
1 minute |
broker_total_bytes_in_rate |
Inbound Traffic |
Inbound traffic to the broker per second Unit: byte/s |
> 0 |
1 minute |
broker_total_bytes_out_rate |
Outbound Traffic |
Outbound traffic from the broker per second Unit: byte/s |
> 0 |
1 minute |
broker_cpu_core_load |
Average Load per CPU Core |
Average load of each CPU core in the broker VM |
> 0 |
1 minute |
broker_disk_usage |
Disk Capacity Usage |
Disk usage of the broker VM Unit: % |
0–100 |
1 minute |
broker_memory_usage |
Memory Usage |
Memory usage of the broker VM Unit: % |
0–100 |
1 minute |
broker_alive |
Broker Status |
Indicates whether the broker is alive. |
1: alive 0: not alive |
1 minute |
broker_connections |
Connections |
Number of connections used by the VM Unit: count |
≥ 0 |
1 minute |
broker_cpu_usage |
CPU Usage |
CPU usage on the VM Unit: % |
≥ 0 |
1 minute |
broker_disk_read_await |
Average Disk Read Time |
Average time for each disk I/O read Unit: ms |
≥ 0 |
1 minute |
broker_disk_write_await |
Average Disk Write Time |
Average time for each disk I/O write Unit: ms |
≥ 0 |
1 minute |
broker_produce_success_rate |
Creation Success Rate |
Percentage of creations that were successfully requested on the broker Unit: % |
≥ 0 |
1 minute |
broker_disk_read_rate |
Disk Read Speed |
Read traffic on the disk Unit: byte/s |
≥ 0 |
1 minute |
broker_disk_write_rate |
Disk Write Speed |
Write traffic on the disk Unit: byte/s |
≥ 0 |
1 minute |
Topic Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Monitored Object |
topic_produce_msg |
Created Messages |
Number of messages received by the topic per minute Unit: count |
> 0 |
RocketMQ instance queue |
1 minute |
topic_consume_msg |
Number of messages retrieved from the topic per minute Unit: count |
> 0 |
1 minute |
topic_produce_rate |
Number of messages received by the topic per second Unit: count/s |
> 0 |
1 minute |
topic_consume_rate |
Number of messages retrieved from the topic per second Unit: count/s |
> 0 |
1 minute |
topic_bytes_in_rate |
Message Creation |
Message creation traffic of the topic Unit: byte/s |
≥ 0 |
1 minute |
topic_bytes_out_rate |
Message Retrieval |
Message retrieval traffic of the topic Unit: byte/s |
≥ 0 |
1 minute |
Consumer Group Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Monitored Object |
group_consume_msg |
Number of messages retrieved by the consumer group per minute Unit: count
This metric is available only when Topic is set to All topics on the By Consumer Group tab page. |
> 0 |
Consumer group of a RocketMQ instance |
1 minute |
group_accumulation |
Available Messages |
Number of messages accumulated in the consumer group Unit: count
> 0 |
1 minute |
group_topic_consume_msg |
Number of messages in the specified topic that are retrieved by the consumer group per minute Unit: count
This metric is available only when Topic is set to a specified topic on the By Consumer Group tab page. |
> 0 |
1 minute |
group_topic_consume_rate |
Number of messages in the specified topic that are retrieved by the consumer group per second Unit: count/s
> 0 |
1 minute |
group_topic_accumulation |
Number of messages in a specific topic Unit: count
> 0 |
1 minute |
Dead Letter Queue Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Monitored Object |
dlq_accumulation |
Messages in the Dead Letter Queue |
Number of messages in the dead letter queue Unit: count |
> 0 |
Dead letter queue of a RocketMQ instance |
1 minute |
Dimensions
Key |
Value |
reliablemq_instance_id |
RocketMQ instance |
reliablemq_broker |
reliablemq_topics |
reliablemq_groups |
reliablemq_groups_topics |
Consumer group of a RocketMQ instance queue |
reliablemq_dlq_topics |
