Deleting an Instance
With a few clicks on the console, you can delete one or multiple RocketMQ instances that have been created or multiple RocketMQ instances that failed to be created.
After a RocketMQ instance is deleted, the instance data will be deleted without backup.
The RocketMQ instances you want to delete are in the Running or Faulty state.
Deleting a RocketMQ Instance
- Click
in the upper left corner to select a region.
Select the region where your RocketMQ instance is located.
- Click
and choose Application > Distributed Message Service for RocketMQ to open the console of DMS for RocketMQ.
- Delete instances using any of the following methods:
- In the row containing the RocketMQ instance you want to delete, click Delete.
- Click a RocketMQ instance to go to the instance details page. In the upper right corner, choose More > Delete.
- To delete multiple instances at a time, select the instances, and click Delete above the instance list.
RocketMQ instances in the Creating or Restarting state cannot be deleted.
- Click Yes.
It takes 1 to 60 seconds to delete a RocketMQ instance.
Deleting a RocketMQ Instance That Failed to Be Created
- Click
- Click
- If there are RocketMQ instances that failed to be created, Instance Creation Failures and quantity information will be displayed. Click Instance Creation Failures or the icon or quantity next to it.
Figure 1 Instance creation failures
- Delete RocketMQ instances that failed to be created in either of the following ways:
- To delete all RocketMQ instances that failed to be created, click Clear Failed Instance.
- To delete a single RocketMQ instance that failed to be created, click Delete in the row containing the instance.
