Updated on 2025-03-05 GMT+08:00
Monitoring Metrics
By using the O&M monitoring function of the graph instance, you can check the instance status, available resources, and real-time resource consumption.
Table 1 lists the monitoring metrics for GES.
Table 1 GES monitoring metrics
Monitored Object
Metric
Value Range
Monitoring Period (Original Metric)
Instance overview metrics
Cluster Information
Size and CPU architecture
String
Cluster Capacity
Total and used vertices and edges, and usage
≥ 0
Real-time
Cluster Node
Node type, available quantity, and total quantity
≥ 0
Real-time
Cluster Request Statistics
Number of waiting and running read and write requests on an instance
≥ 0
Real-time
Instance alarm metrics
Alarm Statistics
Number of critical, major, minor, and info alarms on an instance
≥ 0
5 min
Instance workload metrics
QPS
Number of requests processed by an instance per second
≥ 0
5 min
Resource consumption metrics of graph instances
Average CPU Usage
Average CPU usage of the active node
0%–100%
5 min
Memory Usage
Average memory usage of the active node
0%–100%
5 min
Disk Usage
Average disk usage of the active node
0%–100%
5 min
Disk I/O Usage
Average disk I/O usage of the active node
0%–100%
5 min
Network I/O Usage
Average network I/O usage of the active node
0%–100%
5 min
Overview
Node Name
Name of a node
String
CPU Usage (%)
CPU usage of a node
0%–100%
5 min
Memory Usage (%)
Memory usage of a node
0%–100%
5 min
Average Disk Usage (%)
Disk usage of a node
0%–100%
5 min
IP Address
Service IP address of a node
String
5 min
Disk I/O (KB/S)
Disk I/O of a node, in KB/s
≥ 0KB/s
5 min
TCP Protocol Stack Retransmission Rate (%)
Retransmission rate of TCP packets per unit time
0%–100%
5 min
Status
Status of a node
Running/Faulty
5 min
Disks
Node Name
Name of a node
String
5 min
Disk Name
Name of a disk on a node
String
5 min
Disk Capacity (GB)
Capacity of a disk on a node, in GB
≥ 0 GB
5 min
Disk Usage (%)
0%–100%
5 min
Disk Read Rate (KB/S)
Disk read rate of a node, in KB/s
≥ 0KB/S
5 min
Disk Write Rate (KB/S)
Disk write rate of a node, in KB/s
≥ 0KB/S
5 min
I/O Wait Time (ms)
Average waiting time for each I/O request, in ms
≥ 0 ms
5 min
I/O Service Time (ms)
Average processing time for each I/O request, in ms
≥ 0 ms
5 min
I/O Usage (%)
Disk I/O usage of a host
0%–100%
5 min
Networks
Node Name
Name of a node
String
5 min
NIC Name
Name of the NIC on a node
String
5 min
NIC Status
NIC status
up/down
5 min
NIC Speed
Working rate of a NIC, in Mbit/s
≥ 0
5 min
Received Packets
Number of packets received by a NIC
≥ 0
5 min
Transmitted Packets
Number of packets transmitted by a NIC
≥ 0
5 min
Lost Received Packets
Number of lost packets received by a NIC
≥ 0
5 min
Receive Rate (KB/S)
Number of bytes received by a NIC per unit time, in KB/s
≥ 0KB/s
5 min
Transmit Rate (KB/S)
Number of bytes transmitted by a NIC per unit time, in KB/s
≥ 0KB/s
5 min
Performance
Cluster CPU Usage
0%–100%
5 min
Cluster Memory Usage
0%–100%
5 min
Cluster Disk Usage
0%–100%
5 min
Cluster Disk I/O
Average disk I/O of the active node
0%–100%
5 min
Cluster Network I/O
Average network I/O of the NIC of the active node
0%–100%
5 min
Tomcat Connection Usage
HTTP connection usage of the active node
0%–100%
5 min
Cluster Swap Disk Usage
Swap partition disk usage of the active node
0%–100%
5 min
JVM Heap Memory Usage
JVM heap memory usage of the active node
0%–100%
5 min
Read Requests in Running Queue
Number of running read requests on the current instance
≥ 0
5 min
Read Requests in Blocked Queue
Number of blocked read requests on the current instance
≥ 0
5 min
Real-Time Queries
Request ID
ID of the current query request
String
Real-time
Job Name
Name of the current query job
String
Real-time
Request Parameters
Request parameters for the current query
String
Real-time
Progress
Progress of the current query
0%–100%
Real-time
Blocking Duration (S)
Blocking duration of the current query, in seconds
≥ 0
Real-time
Started
Start time of the current query
String
Real-time
Ended
End time of the current query
String
Real-time
Running Duration
Running duration of the current query, in seconds
≥ 0
Real-time
Historical Queries
Job ID
ID of a historical query job
String
Real-time
Type
Type of a historical query job
String
Real-time
Original Request
Original request for a historical query
String
Real-time
Status
Status of a historical query job
String
Real-time
Progress
Execution progress of a historical query job
0%–100%
Real-time
Start Time
Start time of a historical query job
String
Real-time
End Time
End time of a historical query job
String
Real-time
Running Result
Execution results of a historical query job
String
Real-time
